查看: 3357|回复: 0
[招聘] 上海某ASIC公司招聘
发表于 2013-8-29 14:53:34 | 显示全部楼层 |阅读模式
欢迎把简历发给我,进一步电话沟通.
我一般上班时间不打电话,就是先发mail和短信飞信介绍一下基本情况。然后下班时候打电话的
1.
云计算工程师
上海或杭州
2.
数字前端
IC
设计和验证
上海
3.
数字后端
经理
上海
4.
射频
模拟
职位RFIC
RF FAE
上海深圳
贵司有招聘需求的,欢迎和我联系;
如果你和你朋友有需要看工作机会的,发简历给我HR@Hi-Talent.net
Best Regards,
Apple
Principal Consultant & General Manager @ Hi-Talent Consulting Co.,Ltd.
上海芯相会企业管理咨询有限公司
Skype:
ScarlettJaneJin
E-Mail:
Jane-Jin@Hi-Talent.net
QQ:         983144394
Blog:
http://blog.sina.com.cn/u/1716864892
Weibo:
http://weibo.com/u/1716864892
Linkedin:
jj_seu@hotmail.com
如果你对以下职位感兴趣可以主动回复mail告诉我,或者吧简历发给我,然后我们电话沟通一下细节;
具体jd看下面表格;
具体jd看下面表格;
Position: (Sr.) ASIC Engineer of SOC and Video system
Responsibilities:-
SOCn
Chip architecture define and coordinate including clock/reset structure definition, low power partition definition, etcn
STA (define SDC and sign off timing)n
Low power (define UPF/CPF, verify low power structure from RTL to netlist)n
Understand DFT/synthesis flow, provide necessary support-
Designn
IP level micro-architecture definition, RTL design, co-work with verification ownern
Experience on video/DMA/CPU IP design and verificationRequirements:Must have:n
BSEE Degree or aboven
3 or 5 years of experience in ASIC designn
Familiar with industry synthesis/STA/formal/LP/DFT toolsn
Familiar with at least one of script language such as perl/tcl/shelln
Solid RTL design experience, better in video/DMA/CPU systemn
Self-motivated in solving problemsn
Good communication skills and fluent in English.n
Good team player. Position: Sr. ASIC Engineer 1. This candidate should have mobile/high speed interface background and should be interesting in R&D on Video related technologies.2. IC/IP background. Be interesting in developing and improving New IP.3. Integration experience, be able to own testchip tapeout.4.  With at least 3-years IP/Product R&D experience. Job Description-
RTL coding, new logic design, simulation, synthesis.-
Work closely with algorithm engineer to develop/debug new IP/product. Supports FPGA engineer debugging issues on FPGA system.-
Work closely with system/SW engineer to verificate/validate new IP/product on FPGA/System platform.-
Deliver design/verification/application documents.Qualification and Experience-     Very familiar with the Verilog HDL language;-     Create the RTL architecture for the algorithm;-     Very familiar with C and C++;-     Familiar with FPGA tool, ModelSim, and Synplify.-     Familiar with the flow of the IC design. Requirements:-    Bachelor/Master degree in electronic/computer engineering-    Demonstrated abilities in working independently-    Strong communication skills 1、资深IC设计工程师(图形图象方向)主要工作职责(图形图象处理和视频编解码方向)
1
、根据市场需求和芯片定位,参与并带领团队完成图形图像处理或视频编解码等复杂IP的设计、验证和交付;
2
、对项目进度和质量负责,组织具体技术难点的讨论和攻关;
职位要求:
1
、硕士及以上学历,电子、通信、计算机或微电子专业;
2
、有至少两年以上图形图像或视频编解码等领域的ASIC设计经验;
3
、具备丰富的图形图像处理或视频编解码等相关领域的系统知识
4
、具有扎实的数字芯片设计基础,熟悉IC设计的整个流程;
5
、具有良好的沟通能力,较强的协调能力,以及团队合作意识;
6
、有团队管理经验者优先考虑;
热招后端经理和资深后端工程师Physical design Leader/staff engineer
这个是带团队的,需要技术和team leader结合的职位 1. lead soc design team;2. be able to interface &communicate with internal colleague and external customer; 3. be able to provide design guidance and instruction to engineers; 4. be able to hands-on work on Top level/block level physical design independently
JR:
1. minimum of 5 yrs of working experience; 2. master degree of EE or related field is preferred; 3. team leader or functional leader experience is preferred;4. familiar with either Synopsys or Cadence design flow and EDA tools; 5. fluent in both Chinese and EnglishSOC后端设计和验证-
参与IC设计布局布线, STA等环节的环境和流程维护-
从事后端设计从netlist到GDSii的实现-
编写相关脚本或约束,进行布局布线,时钟树生成,物理验证,功耗/电压降分析,
寄生参数提取等
产生并分析运行报告并给出解决方法 专业背景要求:-
电子工程、计算机科学或相关学科本科3年、硕士3年以上工作经验-
熟悉IC设计流程和常识,特别是当前流行的后端设计流程-
熟练使用下面一种或几种EDA开发工具-
擅长IC版图规划,电源规划,布局布线,时钟树生成、DRC/LVS经验者优先;有一些定制设计和模拟IP使用经验者优先;有功耗分析电压降分析经验者优先;有串扰和信号完整性分析经验者优先-
有90nm或65nm或.13工艺成功流片经历综合素质要求:-
良好的沟通能力和团队合作精神-
高度的责任心和敬业精神-
较强的逻辑思维能力,善于发现问题,具有良好的自学能力和解决问题的能力-
英语熟练应用。-本专业优先。下面的职位要求,有其中之一最好没有也不强调:1. Responsible for all aspects of physical design and implementation of integrated circuits and other ASIC. 2. Responsibilities include: Participating in the efforts in establishing CAD and physical design methodologies;3. Focusing on full chip layout planning (partitioning, planning clock distribution and other structure, methodology);4, Chip floor plan; Power/clock distribution; 5. Chip assembly and P&R; Timing closure; 6. Power and noise analysis; 7. Back-end verification across multiple projects; Requirements: 1. BSEE 5+years,MSEE 3+years experience in large VLSI physical design implementation; 2. Successful track record of delivering products to production is a must; 3. Understanding of custom Macro blocks such as RAMs, PLLs, high-speed IO drivers; 4. Prior experience in Timing closure, clock/power Distribution and analysis, RC Extraction and correlation, place and route and tapeout issues; 5. Working knowledge of deep sub-micron routing issues as they relate to power and timing; 6. Circuit level comprehension of time critical paths. Spice experience a plus; 7. Should be a power user of Apollo/Astro for routing, PhysOpt (Physical Compiler) for placement, PrimeTime for Timing Verification, dc_shell etc. PR Engneer Responsibilities: 1. Layout database creation : layout library and Milkyway database creation; 2. Initial floorplan : Initial chip or subchip level floorplan;3. Place & Route: Perform cells placement; Perform global route and detail route;4.  DRC/LVS corrections; Layout script creation: Create script to perform layout modification; 5. Create Apollo scheme file to maintain and update Apollo database; 6. Layout modification: Follow signal integration report to perform necessary modification; 7. Requirements: Bachelor Degree or higher in EE major;8. 0-3 years P&R working experience; 9. Knowledge about Solaris/Unix/Linux operating system; Good command of English in both written and oral format.
云计算职位
上海和杭州北京都有 1
对云计算云存储/HADOOP/HBASE有深入理解;
2
熟悉LINUX系统
JAVA/C++/python/bash编程;
3
熟练掌握SOCKET/TCPIP
编程,
有成熟网络通讯中间件开发经验优先;
4
熟悉大规模高性能数据处理平台设计;
5
熟悉Amazon云计算平台,对相关服务有深入研究和应用;
6
熟悉NOSQL
相关开源项目,
有实际开发经验尤佳;
7
熟悉主流网络通讯协议框架,如REST/SOAP/RPC 1、本科以上学历,5年以上开发工作经验;
2、熟悉Oracle或Sql Server数据库架构,原理及其脚本编程,具备分布式存储的设计与开发能力。
3、熟悉NoSQL、PostgreSQL、MongoDB等数据库,具备较强的设计与开发能力,有一定的分布式处理经验;
4、具备一定的网络编程、多线程编程技术
5、大型网络服务项目的分析与设计经验,知名网络公司云计算、云服务、云存储相关事业部经验;
6、 熟悉Amazon云存储开发,对S3有一定的研究和使用。
7、 工作认真负责,有团队精神,良好的沟通能力、学习能力和动手能力。
RF IC
深圳和上海的FAE职位
职位描述
1
、WiFi模块/智能手机射频性能的调试和测试
2、协助客户进行射频电路设计
工作经验要求沟通能力良好,适应团队合作
有以下条件者优先采纳:
熟悉WiFi/3G综测仪(例如,IQ2010/Aglient8960),测试方法和测试指标
熟悉RF PA
相关的性能指标以及相关的测试方法
专业技能要求1、本科及以上学历,通信工程、电磁场与微波技术、电路与系统、电子工程等专业;
2、熟练掌握高频电子线路原理、具备射频电路的相关知识;
3、对现代无线通信系统有常识性了解;
5、熟练掌握电路设计软件Protel99/PAS/Candence其中一款或多款,能够独立进行射频电路原理图与PCB设计;
6、熟练操作各种射频测试设备(信号发生器,网络分析仪,频谱分析仪),能够进行射频电路的测试测量;
7、熟练使用焊接工具
中短期需求人才:A. 线性功放CMOS控制模块设计B. 线性HBT功放设计:3G/4G/WiFi/WiMAXC. 低噪声放大器LNA设计:(同时具备phemt及cmos工艺设计经验者为佳)D. 802.11ac功放及相关射频前端设计E.
高功率功放芯片设计(>4W,phemt实现)
设计工程师(PA/CMOS controller/Switch/Module
招聘要求:岗位要求:
1、熟练使用ADS,CDS,Cadence Spectre\SpectreRF,PADS, PowerPCB等EDA工具和Office办公软件;
2、具有扎实的射频电路、模拟电路设计基础,较好的掌握了半导体器件、半导体物理的理论,熟悉GaAs、SiGe、CMOS等工艺、器件特性,熟悉PA基板(Module)设计流程;
3、具有3年及以上PA\CMOS Controller\Switch
芯片设计和流片经验,或Module设计和调试经验;
4、熟悉IC设计流程和后端版图设计流程;
5、具有优秀的学习能力、分析能力、沟通能力和较好的团队合作精神。
RFIC设计工程师
上海1.硕士以上学历,通讯/电子工程/微波/微电子等相关专业;2.熟悉IC设计流程,熟练使用AWR、SpectreRF、ADS等EDA工具;3.熟悉射频和模拟电路设计理论基础,具有RFIC设计和模拟IC设计经验;4.有射频IC中收发链路射频前端的电路路设计和版图设计经验,或电路设计和版图设计经验;5.有LNA、Mixer、RFVGA、PA、PA Switch、PA CMOS controller等IC设计经验,或有PLL/VCO/DCXO等IC设计经验的优先考虑;6.有较强的学习能力、分析能力、沟通能力,有良好的团队合作精神。 模拟IC设计工程师
上海1.硕士以上学历,通讯/电子工程/微波/微电子等相关专业;2.熟悉IC设计流程,熟练使用AWR、Cadence、ADS、Synopsis、office等EDA工具;3.熟悉模拟电路设计、数模混合电路设计,有模拟IC设计、数模混合IC设计、Memory设计经验;4.有电路设计和版图设计经验;5.有ADC/DAC、AGC、DCOC、Filter、OPA、LDO、DC-DC、CP、DCXO、RFID、E2PROM、MTP/OTP、ROM/RAM、flash等设计经验优先考虑;6.有较强的学习能力、分析能力、沟通能力,有良好的团队合作精神。器件建模工程师
上海1.硕士以上学历,通讯/电子工程/微波/微电子等相关专业;2.熟悉IC设计流程,熟练使用AWR、Cadence、ADS、Matlab等EDA工具;3.具有较深入的射频、器件、工艺等知识和背景;4.具有器件(电感、电容、有源器件等)建模经验优先考虑;5.有较强的学习能力、分析能力、沟通能力,有良好的团队合作精神。
GMT+8, 2025-12-29 05:31 , Processed in 0.017763 second(s), 6 queries , Gzip On, Redis On.
