查看: 11527|回复: 18
2012 silvaco win7 “extract”不能用,怎么办?
发表于 2013-8-26 20:51:30 | 显示全部楼层 |阅读模式
2012win7 silvaco atlas每次使用extract语句,都会出现:
EXTRACT> init infile="solarex02_0.log"
Can't read file 'solarex02_0.log': No such file or directory
EXTRACT> extract name="Jsc" y.val from curve(v."anode", i."anode") where x.val=0
initialization has not been performed
EXTRACT> extract name="Voc" x.val from curve(v."anode", i."anode") where y.val=0
或者:
EXTRACT> extract name="Electron" curve(depth,impurity="Electron Conc" material="All" x.val=0.5) outfile="ledex01_3p5_Electron.dat"
Extracting existing "Electron Conc" from structure, no re-calculations required
EXTRACT> extract name="Electron" curve(depth,impurity="Hole Conc" material="All" x.val=0.5) outfile="ledex01_3p5_Hole.dat"
Extracting existing "Hole Conc" from structure, no re-calculations required
请问该怎么解决?
发表于 2014-10-12 14:46:58 | 显示全部楼层
medici用户同求解答,发现很相似,这两个软件
发表于 2017-2-15 16:17:51 | 显示全部楼层
问题解决没  大神
发表于 2017-2-15 21:15:24 | 显示全部楼层
回复 3# 521gains
    看样子你也没解决吧
发表于 2017-2-23 17:24:15 | 显示全部楼层
朋友们,我解决了,看我刚发的帖子
发表于 2017-3-1 04:38:31 | 显示全部楼层
ttttttttttttt
发表于 2017-4-19 18:11:58 | 显示全部楼层
回复 5# 8421
   系统告诉我没有看您那个解决问题的帖子的权限,能发个链接吗谢谢~~
发表于 2017-4-19 18:14:31 | 显示全部楼层
回复 5# 8421
   找到了谢谢~~
发表于 2017-4-19 18:15:12 | 显示全部楼层
发表于 2017-5-19 15:52:14 | 显示全部楼层
回复 1# leesnowy
   楼主解决了吗,求急救
GMT+8, 2025-12-14 11:42 , Processed in 0.025556 second(s), 8 queries , Gzip On, Redis On.
