楼主: 飞扬紫百合
VCS-201306 网盘链接
 楼主| 发表于 2013-9-4 15:12:57 | 显示全部楼层
回复 10# toad
    用systemC开发的平台:
Synphony C Compiler reduces development time and cost by shifting the focus of hardware implementation from designing at the RTL level to designing at the algorithmic level. Designers describe hardware in algorithmic C/C++, using Synphony C Compiler to fine-tune the architecture for tradeoffs in performance, power, and area, and generate highly optimized RTL implementations for ASIC or FPGA. The tool infers the necessary interfaces and memory structures to implement an optimized architecture, eliminating the need to code explicit parallelism and control logic. It is capable of handling multimillion gate hierarchical designs with efficient hardware sharing across layers of hierarchy.
期待你的上传,呵呵!谢谢!
发表于 2013-9-4 19:01:20 | 显示全部楼层
下下来之后解压不了,这是什么问题
发表于 2013-9-9 21:35:13 | 显示全部楼层
回复 1# 飞扬紫百合
压缩文件有问题啊,无法解压
发表于 2013-11-1 20:54:17 | 显示全部楼层
楼主好人
发表于 2013-11-4 15:09:51 | 显示全部楼层
太好了,谢谢!
发表于 2013-11-5 01:33:46 | 显示全部楼层
非常感谢提供!
发表于 2013-11-5 06:03:44 | 显示全部楼层
vcs好东西
发表于 2013-11-7 12:28:40 | 显示全部楼层
楼主好人
11
发表于 2013-11-7 13:04:24 | 显示全部楼层
回复 1# 飞扬紫百合
   谢谢楼主分享
发表于 2013-11-25 21:16:10 | 显示全部楼层
semma share
GMT+8, 2025-12-21 06:41 , Processed in 0.016744 second(s), 2 queries , Gzip On, Redis On.
