查看: 7955|回复: 5
Cadence Allegro SPB 16.6 Hotfix S014
发表于 2013-8-19 22:28:39 | 显示全部楼层 |阅读模式
DATE: 08-9-2013    HOTFIX VERSION: 014
CCRID   PRODUCT        PRODUCTLEVEL2   TITLE
1155569 APD            MODULES          P1_U1 and P1_U3 Die pins are missing after Place Module.
1158528 CONCEPT_HDL    OTHER            Dual Monitor issue: Retain Hard Packaging option is missing and attribute test distorted
1160968 ALLEGRO_EDITOR SKILL            Text Subclass change difference in Edit > Change and axlChangeLayer Skill command
1161986 SIG_INTEGRITY  SIMULATION       Flatline waveform seen when via model is set to detailed closed form or analytical solution
1162323 SIP_LAYOUT     DIE_EDITOR       Die Editor is incorrectly leaving an unassigned function pin in the die during refresh from die abstract
1162752 ALLEGRO_EDITOR SKILL            axlDBChangeText doesnt recognize ?layer as a valid argument as documented
1165002 GRE            CORE             GRE Crashes during Plan Spatial giving "Memory Allocation Failure" Error.
1165469 CONCEPT_HDL    CORE             Import Design loses design library name
1165708 ALLEGRO_EDITOR TESTPREP         Test point router failing when attempting to insert new TP via's
1165801 CONCEPT_HDL    PDF              Pin texts of spun symbol overlap in publish PDF.
1166020 SIP_LAYOUT     WIREBOND         Bondpads created with shapes do not follow the orthogonal pattern when adding wirebonds.
1166371 ALLEGRO_EDITOR DATABASE         File locked for writing in 16.5 cannot be unlocked in 16.6
1166482 ALLEGRO_EDITOR INTERFACES       Step orientation for y-rotated component is not exported correctly.
1167519 ALLEGRO_EDITOR DATABASE         Uprev dbdoctor does not log warnings about renaming properties.
1167588 SIP_LAYOUT     DIE_ABSTRACT_IF  do not create a new pad stack for each I/O pad
1168496 ALLEGRO_EDITOR SCHEM_FTB        Export Physical Crashes when netreving the board
1169510 SIP_LAYOUT     WIZARDS          Netlist in Wizard is crashing with this text file where the Net Name for one of the assignments is blank, meaning dummy
1169593 CONCEPT_HDL    PDF              Published PDF file's hyperlinks do not work fine when user click 1D10 or 2A10.
1169984 F2B            PACKAGERXL       Error Mapping cset when packaging but not in CM Audit
1171008 SIP_LAYOUT     OTHER            SiP Layout - Beta feature Void Adjacent Layer Shapes - changes or modifies "priority" of other/all shapes
1171411 ALLEGRO_EDITOR OTHER            Enh - Break in Step 3D view in latest hotfix v16.6s013
Hotfix_SPB16.60.014_wint_1of1.part20.rar
14.31 MB, 下载次数: 62 , 下载积分: 资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.014_wint_1of1.part01.rar
14.31 MB, 下载次数: 61 , 下载积分: 资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.014_wint_1of1.part02.rar
14.31 MB, 下载次数: 56 , 下载积分: 资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.014_wint_1of1.part03.rar
14.31 MB, 下载次数: 77 , 下载积分: 资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.014_wint_1of1.part04.rar
14.31 MB, 下载次数: 38 , 下载积分: 资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.014_wint_1of1.part05.rar
14.31 MB, 下载次数: 59 , 下载积分: 资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.014_wint_1of1.part06.rar
14.31 MB, 下载次数: 63 , 下载积分: 资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.014_wint_1of1.part07.rar
14.31 MB, 下载次数: 51 , 下载积分: 资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.014_wint_1of1.part08.rar
14.31 MB, 下载次数: 65 , 下载积分: 资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.014_wint_1of1.part09.rar
14.31 MB, 下载次数: 70 , 下载积分: 资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.014_wint_1of1.part10.rar
14.31 MB, 下载次数: 54 , 下载积分: 资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.014_wint_1of1.part11.rar
14.31 MB, 下载次数: 60 , 下载积分: 资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.014_wint_1of1.part12.rar
Hotfix_SPB16.60.014_wint_1of1.part13.rar
14.31 MB, 下载次数: 45 , 下载积分: 资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.014_wint_1of1.part14.rar
Hotfix_SPB16.60.014_wint_1of1.part15.rar
14.31 MB, 下载次数: 49 , 下载积分: 资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.014_wint_1of1.part16.rar
14.31 MB, 下载次数: 41 , 下载积分: 资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.014_wint_1of1.part17.rar
14.31 MB, 下载次数: 43 , 下载积分: 资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.014_wint_1of1.part18.rar
14.31 MB, 下载次数: 32 , 下载积分: 资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.014_wint_1of1.part19.rar
14.31 MB, 下载次数: 42 , 下载积分: 资产 -5 信元, 下载支出 5 信元
 楼主| 发表于 2013-8-19 23:08:11 | 显示全部楼层
21-55
Hotfix_SPB16.60.014_wint_1of1.part40.rar
Hotfix_SPB16.60.014_wint_1of1.part21.rar
Hotfix_SPB16.60.014_wint_1of1.part22.rar
14.31 MB, 下载次数: 47 , 下载积分: 资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.014_wint_1of1.part23.rar
14.31 MB, 下载次数: 40 , 下载积分: 资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.014_wint_1of1.part24.rar
Hotfix_SPB16.60.014_wint_1of1.part25.rar
Hotfix_SPB16.60.014_wint_1of1.part26.rar
Hotfix_SPB16.60.014_wint_1of1.part27.rar
14.31 MB, 下载次数: 44 , 下载积分: 资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.014_wint_1of1.part28.rar
Hotfix_SPB16.60.014_wint_1of1.part29.rar
Hotfix_SPB16.60.014_wint_1of1.part30.rar
Hotfix_SPB16.60.014_wint_1of1.part31.rar
14.31 MB, 下载次数: 52 , 下载积分: 资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.014_wint_1of1.part32.rar
14.31 MB, 下载次数: 50 , 下载积分: 资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.014_wint_1of1.part33.rar
14.31 MB, 下载次数: 48 , 下载积分: 资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.014_wint_1of1.part34.rar
14.31 MB, 下载次数: 28 , 下载积分: 资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.014_wint_1of1.part35.rar
Hotfix_SPB16.60.014_wint_1of1.part36.rar
Hotfix_SPB16.60.014_wint_1of1.part37.rar
14.31 MB, 下载次数: 46 , 下载积分: 资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.014_wint_1of1.part38.rar
Hotfix_SPB16.60.014_wint_1of1.part39.rar
Hotfix_SPB16.60.014_wint_1of1.part55.rar
2.28 MB, 下载次数: 25 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Hotfix_SPB16.60.014_wint_1of1.part41.rar
Hotfix_SPB16.60.014_wint_1of1.part42.rar
Hotfix_SPB16.60.014_wint_1of1.part43.rar
14.31 MB, 下载次数: 29 , 下载积分: 资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.014_wint_1of1.part44.rar
14.31 MB, 下载次数: 53 , 下载积分: 资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.014_wint_1of1.part45.rar
Hotfix_SPB16.60.014_wint_1of1.part46.rar
Hotfix_SPB16.60.014_wint_1of1.part47.rar
Hotfix_SPB16.60.014_wint_1of1.part48.rar
Hotfix_SPB16.60.014_wint_1of1.part49.rar
Hotfix_SPB16.60.014_wint_1of1.part50.rar
14.31 MB, 下载次数: 204 , 下载积分: 资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.014_wint_1of1.part51.rar
14.31 MB, 下载次数: 26 , 下载积分: 资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.014_wint_1of1.part52.rar
14.31 MB, 下载次数: 108 , 下载积分: 资产 -5 信元, 下载支出 5 信元
Hotfix_SPB16.60.014_wint_1of1.part53.rar
Hotfix_SPB16.60.014_wint_1of1.part54.rar
发表于 2013-9-5 20:59:58 | 显示全部楼层
谢谢楼主提供。
发表于 2013-9-21 18:33:37 | 显示全部楼层
太多包拉
发表于 2013-9-29 14:36:52 | 显示全部楼层
信元不够,木没下。
发表于 2017-11-21 13:33:34 | 显示全部楼层
Thanks
GMT+8, 2025-12-24 06:15 , Processed in 0.031233 second(s), 9 queries , Gzip On, Redis On.
