查看: 14682|回复: 38
[资料] Springer 新书三连发NO2: EMI-Resilient Amplifier Circuits
发表于 2013-8-18 21:50:14 | 显示全部楼层 |阅读模式
第二本
http://www.springer.com/engineering/circuits+%26+systems/book/978-3-319-00592-8
van der Horst, Marcel J., Serdijn, Wouter A., Linnenbank, André C.
2014, XV, 307 p. 75 illus.
  • Describes design methods that incorporate electromagnetic interference (EMI) in the design of application specific negative-feedback amplifiers
  • Provides designers with a structured methodology to avoid the use of trial and error in meeting signal-to-error ratio (SER) requirements
  • Equips designers to increase EMI immunity of the amplifier itself, thus avoiding filtering at the input, reducing the number of components and avoiding detrimental effects on noise and stability
This book enables circuit designers to reduce the errors introduced by the fundamental limitations and electromagnetic interference (EMI) in negative-feedback amplifiers.  The authors describe a systematic design approach for application specific negative-feedback amplifiers, with specified signal-to-error ratio (SER).  This approach enables designers to calculate noise, bandwidth, EMI, and the required bias parameters of the transistors used in  application specific amplifiers in order to meet the SER requirements. ·         Describes design methods that incorporate electromagnetic interference (EMI) in the design of application specific negative-feedback amplifiers;·         Provides designers with a structured methodology to avoid the use of trial and error in meeting signal-to-error ratio (SER) requirements;·         Equips designers to increase EMI immunity of the amplifier itself, thus avoiding filtering at the input, reducing the number of components and avoiding detrimental effects on noise and stability.
EMI-Resilient Amplifier Circuits 10.1007_978-3-319-00593-5.pdf (5.89 MB , 下载次数: 1061 )
 楼主| 发表于 2013-8-18 22:22:18 | 显示全部楼层
之前在发第三本后分别编辑了下三个帖子,结果一三两贴现在被删了,为何,连系统提示也没?
发表于 2013-8-19 10:31:44 | 显示全部楼层
感謝大大的分享
发表于 2013-8-19 17:58:53 | 显示全部楼层
回复 1# jacobshen
多谢!
发表于 2013-8-19 20:35:57 | 显示全部楼层
好书,收藏
发表于 2013-8-19 21:20:16 | 显示全部楼层
好书,值得一看
发表于 2013-8-19 21:51:50 | 显示全部楼层
it is good book
发表于 2013-8-19 23:21:52 | 显示全部楼层
不错的书!
发表于 2013-8-20 11:05:17 | 显示全部楼层
非常不错的书,一定要收藏
发表于 2013-8-21 14:49:18 | 显示全部楼层
很好,是Springer2014
GMT+8, 2025-12-14 19:32 , Processed in 0.267194 second(s), 6 queries , Gzip On, Redis On.
