查看: 4326|回复: 0
[招聘] Cadence 北京招聘研发工程师
发表于 2013-8-16 10:04:57 | 显示全部楼层 |阅读模式
Cadence  北京招聘研发工程师
CadenceNasdaq: CDNS是全球领先的软件开发商以及电子设计自动化解决方案提供商.我们的产品涵盖了电子设计的整个流程,包括系统级设计,功能验证,IC综合及布局布线,模拟、混合信号及射频IC设计,全定制集成电路设计,IC物理验证,PCB设计和硬件仿真建模等。全球知名半导体与电子系统公司均将Cadence软件作为其全球设计的标准。公司网站www.cadence.com.cn
更多职位信息敬请关注Cadence公众微信平台:Cadence_Recruitment
If you haveinterest, PLS send your CV to job_china@cadence.com
1. Senior/ Software Engineer-Characterization
(Location:BJ)
Position Description:
Thepositions are for a developer who will be responsible for designing,implementing, and maintaining library characterization and validation softwarefor use with standard cells, memory and macro blocks, and IO cells
PositionRequirements:
1.Thecandidates should have two or more years of experiences in developing EDAsoftware.
2.Must beproficient in C, C++, TCL, and development in Linux/Unix.
3.Knowledge on semiconductor device is strong plus.
4.Experience with SPICE or SPICE-like circuit simulation is important.
5.Knowledgeof Verilog and VHDL is also highly desirable.
6.Have agood understanding of library characterization, IP design, static timinganalysis, power analysis, and signal integrity analysis flows.
7.MinimumEducation Required / Minimum Experience Required : MS, EE, CS, Math or Physics2
8.PreferredEducation / Preferred Experience: Ph.D. , EE, CS, Math or Physics 3-5
2. Senior Software Engineer- Virtuoso DesignEnvironment
PositionDescription:
Custom digital and analog circuit designersmust generate and interpret large amounts of complex simulation data. VirtuosoADE accelerates design by enabling setup reuse, parallelizing and distributingcompute-intensive simulation, and through extensive post-processing andvisualization capabilities.
As an ADE programmer, you will:
* Work closely with simulation andvisualization teams in order to streamline tool flow and deliver newcapabilities.
* Implement internal algorithms, provide APIsfor other tools to integrate, and provide GUI support for the end user.
* Carefully consider data structures to handlelarge data sets.
* Demonstrate strong OO knowledge using C++.
* Write tests to validate your implementation.
- Skilled in C++ programming, familiar withdevelopment under Linux/Unix environment;
- Familiarity with GUI development, especiallyusing the Qt toolkit is a plus
- Familiarity with XML and/or SQL is a plus
- Be familiar with Analog-signal design is aplus;
- Good English communication skill bothverbally and writing;
- Good problem solving skill and team workspirit;
3.Senior Software Engineer --- Simulation Integration
World’s leading design companies rely on Cadence technologies todeliver the latest
design innovations in consumer, mobile and enterprise electronics.We are looking for
exceptional software engineers to join our team and contribute tothe continued
growth and success of the company’s flagship products, such asVirtuoso Spectre and
Virtuoso ADE. In this high-impact career opportunity, you willdevelop cutting-edge
features of some of our most exciting new products, with anemphasis of scripting
language development and GUI integration. You will work with across-functional
team in Beijing and San Jose to ensure that our software isdeveloped, tested, and
documented with high quality.
Position Requirements:
1.Strong C++ programming and familiarity with development underLinux/Unix environment
2.Experience with GUI frameworks, such as Qt.
3.Strong scripting language skills in one or more of: Python, Perl,Lisp, Tcl
4.Proficiency with build and version-control systems.
5.Good English communication skill both verbally and writing.
6.Good problem solving skill and team work spirit.
4. Senior Software Engineer- simulator frontend
Research and design simulator front end
Strong C++ programming and familiarity with development underLinux/Unix environment.
Proficiency with linux/unix tools.
Skills in one or more of script such as Python, Perl.
Familiar with build and version-control systems.
GMT+8, 2025-12-23 20:52 , Processed in 0.020538 second(s), 6 queries , Gzip On, Redis On.
