查看: 15026|回复: 70
[资料] A 14b 80 MS/s SAR ADC With 73.6 dB SNDR in 65 nm CMOS
发表于 2013-8-13 14:59:42 | 显示全部楼层 |阅读模式
Ron Kapusta, Senior Member, IEEE, Junhua Shen, Member, IEEE, Steven Decker, Member, IEEE, Hongxing Li,
Eitake Ibaragi, and Haiyang Zhu
Abstract—A 14-bit SAR ADC is presented that achieves 73.6
dB SNDR at 80 MSPS while using a 1.2-V-only supply. In order
to overcome throughput limitations common to conventional SAR
ADCs, several techniques are proposed. First, a flash sub-ADC is
utilized to resolve the 5 MSBs quickly prior to SAR sequential
decisions of the LSBs. Second, the DAC operation is time-interleaved
by a factor of 2, increasing speed while allowing a single
comparator to be shared between all DACs. Third, fully on-chip
DAC charge redistribution allows the DAC settling time to be improved
by more than an order of magnitude compared to conventional
techniques. Finally, the ADC is fully self-timed through the
use of a replica timer circuit in order to take full advantage of the
fast DAC settling and comparator decisions. Despite the increased
speed, the ADC consumes only 31.1 mW and occupies a core area
of 0.55 mm2.
Index Terms—ADC, CMOS, double-sampling, flash, reference
reservoir, self-timed, successive approximation.
A 14b 80 MSs SAR ADC With 73.6 dB SNDR.rar
1.66 MB, 下载次数: 866 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2013-8-13 15:04:57 | 显示全部楼层
kankan !!!!tnx!!!!
发表于 2013-8-13 20:03:10 | 显示全部楼层
很想知道为啥直接出现在了december,2013的论文……
发表于 2013-8-13 20:56:24 | 显示全部楼层
這是JSSC的early access,是提前刊出的文章,還不算是正式出版
发表于 2013-12-10 10:04:04 | 显示全部楼层
kankan
发表于 2014-1-22 15:40:45 | 显示全部楼层
dingdign
发表于 2014-1-26 16:28:55 | 显示全部楼层
I know this paper
发表于 2014-1-29 13:42:05 | 显示全部楼层
very good material
发表于 2014-1-30 23:55:51 | 显示全部楼层
gfgfgdfgdfgdfgd
发表于 2014-3-26 10:33:59 | 显示全部楼层
dingding
GMT+8, 2025-11-16 18:19 , Processed in 0.018789 second(s), 4 queries , Gzip On, Redis On.
