查看: 9029|回复: 20
CentOS 6.4安装IC615和MMSIM12的问题
发表于 2013-8-11 10:52:21 | 显示全部楼层 |阅读模式
操作系统版本为centos 6.4
IC615
Base_IC06.15.011
Hotfix_IC06.15.151
MMSIM12
Base_MMSIM12.10.272
Hotfix_MMSIM12.10.317
下面附件是我的安装过程
ic615 install process.zip (2.5 KB , 下载次数: 187 )
但是启动有问题
[wl@wl ~]$ license manager: can't initialize: Cannot find license file.
The license files (or license server system network addresses) attempted are
listed below.  Use LM_LICENSE_FILE to use a different license file,
or contact your software provider for a license file.
Filename:      /usr/local/flexlm/licenses/license.dat
License path:  /usr/local/flexlm/licenses/license.dat
FLEXnet Licensing error:-1,359.  System Error: 2 "No such file or directory"
For further information, refer to the FLEXnet Licensing End User Guide,
available at "www.macrovision.com".
17:08:26 (lmgrd) -----------------------------------------------
17:08:26 (lmgrd)   Please Note:
17:08:26 (lmgrd)
17:08:26 (lmgrd)   This log is intended for debug purposes only.
17:08:26 (lmgrd)   In order to capture accurate license
17:08:26 (lmgrd)   usage data into an organized repository,
17:08:26 (lmgrd)   please enable report logging. Use Macrovision's
17:08:26 (lmgrd)   software license administration  solution,
17:08:26 (lmgrd)   FLEXnet Manager, to  readily gain visibility
17:08:26 (lmgrd)   into license usage data and to create
17:08:26 (lmgrd)   insightful reports on critical information like
17:08:26 (lmgrd)   license availability and usage. FLEXnet Manager
17:08:26 (lmgrd)   can be fully automated to run these reports on
17:08:26 (lmgrd)   schedule and can be used to track license
17:08:26 (lmgrd)   servers and usage across a heterogeneous
17:08:26 (lmgrd)   network of servers including Windows NT, Linux
17:08:26 (lmgrd)   and UNIX. Contact Macrovision at
17:08:26 (lmgrd)   www.macrovision.com for more details on how to
17:08:26 (lmgrd)   obtain an evaluation copy of FLEXnet Manager
17:08:26 (lmgrd)   for your enterprise.
17:08:26 (lmgrd)
17:08:26 (lmgrd)
17:08:26 (lmgrd)
17:08:26 (lmgrd) Using license file "/usr/local/flexlm/licenses/license.dat"
请问
1.我的.bashrc设置有问题吗?我明明在bashrc里面设置了lmgrd路径,但是在上面的错误中license.dat却定向到另一个
2.mmsim12如何pojie?
多谢各位
发表于 2013-8-20 07:58:55 | 显示全部楼层
学点英文吧,上面已经说得很清楚了。
listed below. Use LM_LICENSE_FILE to use a different license file。
export LM_LICENSE_FILE=.....
到坛子去找吧,这是一个学习的过程。
 楼主| 发表于 2013-8-22 17:41:45 | 显示全部楼层
回复 2# YULONGUTK
    export LM_LICENSE_FILE 这步我已经设置到了我的LICENSE.DAT的位置了
 楼主| 发表于 2013-8-27 12:40:19 | 显示全部楼层
自己顶一下
 楼主| 发表于 2013-10-9 13:00:59 | 显示全部楼层
有指导的人吗?
发表于 2013-10-9 14:49:05 | 显示全部楼层
license 不光須要 license file ,
有的EDA  只看 file ,
有的須要 license file + lmgrd daemon ..
不同版本 lmgrd (synopsys 剛MERGE 別家就碰過)
還不能共用
會衝到
发表于 2014-3-14 10:10:21 | 显示全部楼层
发表于 2014-3-15 23:47:41 | 显示全部楼层
好谢谢!分享
发表于 2014-3-15 23:48:38 | 显示全部楼层
好谢谢!分享
发表于 2014-3-15 23:49:14 | 显示全部楼层
好谢谢!分享
GMT+8, 2025-12-23 11:50 , Processed in 0.033733 second(s), 7 queries , Gzip On, Redis On.
