查看: 4153|回复: 1
[求助] WARNING:Route:455 - CLK Net:commandinput may have excessive skew because
发表于 2013-8-9 08:25:31 | 显示全部楼层 |阅读模式
用ISE10.1 place&route 后,会出现如下警告:
      0 CLK pins and 2 NON_CLK pins failed to route using a CLK template.
如果不管上面的警告,程序运行的结果不对,请各位高手多多指教,谢谢!
发表于 2016-8-4 22:07:39 | 显示全部楼层
回复 1# zhongcaid
  怎么解决啊,我也遇到这个问题
GMT+8, 2025-12-26 02:40 , Processed in 0.021787 second(s), 6 queries , Gzip On, Redis On.
