查看: 4187|回复: 5
请教达人:一个看不懂的xinlix官网问题解决方案!
发表于 2007-2-6 08:59:49 | 显示全部楼层 |阅读模式
During FPGA configuration, iMPACT generates the following errors:
ERROR:Bitstream:2 - The input file "top_level.msk" does not exist. Please check that the specified location is correct and that the bitstream was successfully created.
ERROR:iMPACT:123 - Mask file top_level.msk is invalid. Solution 1:iMPACT is looking for a mask (*.msk) file in order to perform a "verify" operation. The ".msk" file will need to be present in the directory where the ".bit" file is located for iMPACT to pick this up.
Creating a mask file can be done one of two ways.
First, from command line use the "-m" option in BitGen. //什么意思啊?如何操作?
Second, from the ISE Design Environment Tools:
1. Click right the "Generate Programming file" process: The BitGen options window opens.
2. Click on the tab "Readback" option.
3. Check "Create ReadBack Data files" and "Create Mask File".
4. Click "OK".
5. Re-run the "Generate Programming file" process.
另:如果大家有和我相似经历的话,请把不吝赐教
发表于 2008-1-20 22:45:22 | 显示全部楼层
我也遇到与你同样的问题,具体解决方法是:
    1、右键单击“Generate Programming file”项打开“properties",进入”Process Properties"的窗口,也就是我们经常改JTAG CLOCK和CCLK的那个窗口;
    2、打开“Readback  options"项,选中”Create ReadBack Data files" 复选框,这个时候 "Create Mask File".项也变成可选的复选框,选中它单击OK完成!
    3、重新RUN,CONFIG IS OK!!!
发表于 2008-3-17 14:42:27 | 显示全部楼层
感谢!
恰好我也遇到了这个问题
发表于 2008-5-16 08:08:46 | 显示全部楼层
昨天找了一天啦!!!THANKS
发表于 2008-5-16 09:23:28 | 显示全部楼层
dddddddddddddddddddddddddddddddddddddddd
头像被屏蔽
发表于 2008-5-16 23:57:00 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
GMT+8, 2025-12-24 05:00 , Processed in 0.022532 second(s), 9 queries , Gzip On, Redis On.
