查看: 2663|回复: 1
[求助] ADS2012中如何进行verilog-AMS运行配置
发表于 2013-8-5 20:02:38 | 显示全部楼层 |阅读模式
直接打开verilog-AMS例子运行不了,hpeesofsim.cfg配置文件中编译器选择的是modelsim,其中有一个叫做VERILOG_PATH的变量,help中说编译器中也要设置该路径,不知怎么弄啊。还有就是MODELSIM_ROOT变量如何设置呢?直接在配置文件中加了这么一行不知可行:MODELSIM_ROOT=D:/modeltech_6.5仿真运行报错如下:Error detected by hpeesofsim in Verilog-A Device during circuit set up.
Failed to create shared memory TDA_SMC2032(-5950) after 10 tries.
The requested file was not found.
发表于 2013-8-10 23:44:39 | 显示全部楼层
没弄过,给你顶一下
GMT+8, 2025-12-26 06:33 , Processed in 0.015387 second(s), 7 queries , Gzip On, Redis On.
