查看: 4034|回复: 2
[招聘] 嵌入式软件工程师C/C++ 上海
发表于 2013-8-2 15:54:46 | 显示全部楼层 |阅读模式
I.m Brian.Lin.a consultant base in guangzhou,now have a positon opening.If you or your friends are interested it,pls contact me.Keep in touch and you can add my qq-670855021 or linz11203114@163.com.
Job Title: Embedded SoftwareEngineer
ReportsTo:EE Manager
Group/Division: China Technology Center
CareerBand:III
Package:20-30W/Y
Category : Science Research andDevelopment,
Career Level : Experienced(Non-Manager)
Job Type : Full Time
Position Summary:
The Engineer in the Research andDevelopment
Engineering Department supports technology researchactivities and is responsible for product development and product supportthroughout the entire product life cycle.
The Engineer position requires a person skilled in
leading/ supportingthe development and sustaining support of embedded and PC software foranalytical instrumentation.
Extensiveroot cause analysis and problem solving skills are required to investigateinstrument issues and to drive to the resolution of problems.
Key Responsibilities:
Design firmware for analytical instrumentembedded system covering from applications development and/or OS porting;software architecture.
Must have strong design and projectmanagement skills and will be able to work with multidisciplinary teams (electrical, chemists, scientists, marketing, projectleaders) to help CTC delivery product on time, high quality withinbudget
Responsible for the design / implementation/ maintain product embedded software
FW architecture design and maintain; do contribution to module reusing and platformsharing
Follow on relevant design process / standard
Lead or support multiple concurrentprojects across diverse product lines. Towards this, develop design plans andproject schedules and ensure deliverable goals are achieved
Setup firmware design environment, need communicatewith regional marketing team and global R&D team to understand customerneeds and create solution
Work with technical services, manufacturing to provide support
Maintain a safe working environment,following established procedures.
Other tasks assigned by the Supervisor
Minimum Requirements/Qualifications:
BE/ B. or above Tech inCS/Electronics/Electrical
At least 3+ years of experience in the field of Embedded firmwaredevelopment with microprocessor based embedded Real time systems ORC/C++ software architecture
Embedded RTOS
(Linux/Nucleus/QNX/VxWorks/ThreadX) projectexperience is a must
Experience with communication programmingon RS232/RS485/Ethernet/SPI/I2C/USB
Extensive C/C++ Programming Knowledge
Experience in Unit/Integration/system testbased on complex hardware.
Excellent language skill on Englishreading, speaking and writing
Strong responsibility, self-motivated andinitiative
Proven skill inproblems addressing and resolving
Position will require initial travel to theU.S.for a period of 1-2 months for training.
发表于 2013-8-3 08:25:18 | 显示全部楼层
此帖仅作者可见
 楼主| 发表于 2013-8-9 11:42:59 | 显示全部楼层
此帖仅作者可见
GMT+8, 2025-12-15 12:07 , Processed in 0.194962 second(s), 9 queries , Gzip On, Redis On.
