查看: 9058|回复: 15
vcs 启动报错
发表于 2013-7-13 21:52:11 | 显示全部楼层 |阅读模式
请问各位大牛,在安装了vcs之后,执行
vcs a.v
出现如下情况,不知道从何下手解决。
小女子不才,还望各位大牛不吝赐教,万分感谢!
                   Chronologic VCS (TM)
   Version G-2012.09_Full64 -- Sat Jul 13 21:45:00 2013
         Copyright (c) 1991-2012 by Synopsys Inc.
                ALL RIGHTS RESERVED
This program is proprietary and confidential information of Synopsys Inc.
and may be used and disclosed only as authorized in a license agreement
controlling such use
and disclosure.
Got SIGSEGV
An unexpected termination has occurred in /home/eda/synopsys/version2012/vcs_vG201209/amd64/bin/vcs1
During setup for compilation
Command line: /home/eda/synopsys/version2012/vcs_vG201209/amd64/bin/vcs1 -Mcc=gcc -Mcplusplus=g++ -Masflags= "-Mcfl= -pipe -O -
I/home/eda/synopsys/version2012/vcs_vG201209/amd64/lib " "-Mldflags= -melf_i386 " -Mout=simv -Mamsrun= -Mvcsaceobjs= "-Mobjects=
/home/eda/synopsys/version2012/vcs_vG201209/amd64/lib/libvirsim.so /home/eda/synopsys/version2012/vcs_vG201209/amd64/lib/liberrorinf.so
/home/eda/synopsys/version2012/vcs_vG201209/amd64/lib/libsnpsmalloc.so " -Msaverestoreobj=/home/eda/synopsys/version2012/vcs_vG201209/amd64/lib/vcs_save_restore_new.o
-Mcrt0= -Mcrtn= -Mcsrc= "-Msyslibs=/home/eda/synopsys/version2012/vcs_vG201209/amd64/lib/ctype-stubs_32.a -ldl " -gen_obj a.v
--- Stack trace follows:
[Thread debugging using libthread_db enabled]
0x0000003a404ab64e in waitpid () from /lib64/libc.so.6
#0  0x0000003a404ab64e in waitpid () from /lib64/libc.so.6
#1  0x0000003a4043e769 in do_system () from /lib64/libc.so.6
#2  0x000000000367ac44 in tracker::StackAnnotator::getGdbOutput(char const*, char const*, char const*) ()
#3  0x000000000367b1db in tracker::StackAnnotator::dumpStackByGdb(char const*, char const*) ()
#4  0x000000000367c168 in tracker::StackAnnotator::dumpProcessStack(unsigned int, char const*, char const*) ()
#5  0x0000000003672f86 in dumpStackTrace ()
#6  0x000000000336e98d in stackTraceHandler ()
#7  0x000000000336d622 in SigHandler ()
#8  <signal handler called>
#9  0x0000000003113aab in ?? ()
#10 0x000000000310f7d6 in KSmjJrtmFGE89nx ()
#11 0x000000000310f85b in Vi9wVDbIr1poz5K ()
#12 0x0000000003102a53 in ?? ()
#13 0x00000000031034ba in _scl_lc_checkout ()
#14 0x0000000003104169 in ?? ()
#15 0x000000000310178f in _scl_lc_checkout_wrapper ()
#16 0x000000000310449c in ?? ()
#17 0x00000000030f84a4 in vcs_checkout ()
#18 0x00000000030f64f5 in lDeleteFromSchedulerQ ()
#19 0x00000000030f2091 in GetAFlexLicense ()
#20 0x00000000030f2417 in tfdvsf_chk ()
#21 0x0000000000c46611 in ?? ()
#22 0x0000000000c48f3e in c_main ()
#23 0x00000000016914b6 in main ()
Completed context dump phase
CPU time: 1.191 seconds to compile
发表于 2013-12-19 12:40:53 | 显示全部楼层
请问解决了这个问题了吗?遇见同样的错误
发表于 2014-3-1 11:53:56 | 显示全部楼层
楼主解决了吗,弄好好久都没弄好……
发表于 2014-3-1 11:56:53 | 显示全部楼层
是g++的问题么?我装的是系统盘里自带的。。。
 楼主| 发表于 2014-3-1 12:48:08 | 显示全部楼层
回复 3# wbaif
不好意思啊,还没有弄好,我也不知道是怎么回事呢。
 楼主| 发表于 2014-3-1 12:53:51 | 显示全部楼层
回复 2# ustc_mth
   没有解决呢,不好意思啊。
发表于 2014-3-1 13:43:35 | 显示全部楼层
缺少了SCL下的arm64,补装上就ok^^^^^^
发表于 2014-3-2 20:43:25 | 显示全部楼层
主机重启后又出现这问题了。。。
发表于 2014-7-15 19:28:22 | 显示全部楼层
我也遇到同样的问题,请问这个问题解决了吗?
发表于 2014-9-22 15:23:58 | 显示全部楼层
回复 6# E2TML
请问这个问题,您是如何解决的啊?现在碰到这个问题,不知道是vcs软件的安装问题还是怎么回事?求解!
GMT+8, 2025-12-17 09:28 , Processed in 0.033886 second(s), 8 queries , Gzip On, Redis On.
