查看: 5114|回复: 5
[原创] How to choose Vds in analog design based on 2id/gm methodology
发表于 2013-7-11 18:22:10 | 显示全部楼层 |阅读模式
If the transitor appears in the small signal model of an amplifier and is required to contribute to the DC gain of the amplifier, the best Vds is about 2 or 3 times greater than Vov. In my study about 2id/gm methodology, I find the intrinsic gain of a transistor only relates to the L and the ratio K of Vds and Vov (or V* mentioned in EE240 from UCB), and only when the ratio reaches to 2 to 3, there is a certain intrinsic gain of a transistor.
Fig. 1 shows the relationship between the intrinsic gain and the ratio K as well as L, which could prove the above arguments. All data are mesured in TSMC 130nm technology.
Note that the expression of DC gain of a amplifier could convert into the expression of the correspondent intrinsic gain of Mosfets, which could be found in EE214 from stanford.
Copyright 2013 by Joy Shockley
发表于 2013-7-12 10:41:26 | 显示全部楼层
good! thanks share!!!
发表于 2013-7-12 15:10:39 | 显示全部楼层
能说中文吗?哥们。
发表于 2013-7-13 12:34:11 | 显示全部楼层
I agree with your signature
发表于 2013-8-8 13:11:51 | 显示全部楼层
kankan
发表于 2017-3-22 09:30:25 | 显示全部楼层
谢谢分享
GMT+8, 2025-12-17 15:50 , Processed in 0.026323 second(s), 7 queries , Gzip On, Redis On.
