查看: 7067|回复: 15
[IEEE]Driver Deadtime Control and its Impact on System Stability
发表于 2007-1-27 21:47:18 | 显示全部楼层 |阅读模式
Driver Deadtime Control and its Impact on System Stability of
Synchronous Buck Voltage Regulator
Weihong Qiu , Steven Mercer , (George) Zhixiang Liang , Greg Miller
Intersil Corporation
Abstract: Driver dead-time control is a popular scheme in a synchronous Buck voltage regulator to prevent the shoot-through issue. In addition to its impact on efficiency, dead-time control also impacts loop gain and system stability, especially under the critical load condition. In this paper, the influence of driver dead time on the synchronous buck converter is investigated, and some practical issues are analyzed and verified by experimental results.
0-7803-9547-6/06/$20.00 (C)2006 IEEE
(7 Pages)
abbr_rol and its impact on system stability of synchronous buck voltage regulator.pdf
388.26 KB, 下载次数: 121 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2007-1-29 09:03:20 | 显示全部楼层
建议楼主对电源的论文归归类!
 楼主| 发表于 2007-1-29 10:44:03 | 显示全部楼层
本人正在整理中,因为资料实在太多了,足有一张DVD光盘的容量,所以比较费时。请版主和网友理解和耐心等待!
发表于 2007-1-29 11:17:50 | 显示全部楼层
看看,从来没听说过还有这么一说
发表于 2007-1-29 11:54:06 | 显示全部楼层
CONCLUSIONS
V. CONCLUSIONS
During synchronous Buck converter design, the impact
of the driver deadtime on the system stability should be taken
into consideration. For most applications, the driver deadtime
has little impact on the system stability. But it may increase
the output current or voltage ripple under the critical load
condition for some applications. It is necessary to verify the
operation and system stability considerations of the system
loop under different load conditions, especially the critical
load condition.
发表于 2007-1-29 11:55:18 | 显示全部楼层
Reference:
Reference:
[1] Y.Panov and M. M.Jovanovic, “Design considerations for
12V/1.5V, 50A voltage regulator modules,” IEEE APEC
2000, Page(s): 39-46.
[2] Djekic, O.; Brkovic, M.; Roy, A.; “High frequency
synchronous buck converter for low voltage applications”
IEEE PESC 1998, Page(s): 1248–1254
[3] Alou, P.; Perez-Bedmar, P.; Cobos, J.A.; Uceda, J.;
Rascon, M. “A high efficiency voltage regulator module
with single winding self-driven synchronous rectification “,
IEEE PESC 2000, Page(s): 1510-1515
发表于 2007-2-9 23:31:38 | 显示全部楼层
521521
发表于 2007-2-9 23:33:44 | 显示全部楼层
521521
发表于 2008-3-24 13:06:37 | 显示全部楼层
 不错,找了好久呢,就是下载速度不快。
发表于 2008-3-24 13:18:02 | 显示全部楼层
下载很慢,是否限制了速度呢
GMT+8, 2025-12-14 09:35 , Processed in 0.023415 second(s), 7 queries , Gzip On, Redis On.
