楼主: 胡兵
[资料] SoC Encounter经典实例教程+代码
发表于 2018-1-28 10:07:46 | 显示全部楼层
好东西谢了。
发表于 2018-1-29 00:15:00 | 显示全部楼层
多謝樓主
发表于 2018-1-30 13:31:59 | 显示全部楼层
回复 1# 胡兵
发表于 2018-2-1 15:43:17 | 显示全部楼层
多谢分享
发表于 2018-4-12 16:11:28 | 显示全部楼层
感谢楼主分享,希望可以用到!
发表于 2018-4-13 11:08:48 | 显示全部楼层
非常感谢你
发表于 2018-4-15 20:04:53 | 显示全部楼层
学习一下
发表于 2018-6-1 14:32:02 | 显示全部楼层
9.1之前的版本
ion
XOR2X1, XNOR2X1 2-input XOR and XNOR
TIELO, TIEHI Cells used to tie inputs to logic 1 or 0
OAI22X1, OAI21X1 OR-AND-Invert gates with 4 (22) and 3 (21) inputs
NOR3X1, NOR2X2, NOR2X1 2- and 3-input NOR
NAND3X1, NAND2X2, NAND2X1 2- and 3-input NAND
MUX2X2, MUX2NX1 2-input MUX, and 2-input inverting mux (N)
LCX1, LCNX1 Gated latches
INVX1, INVX2, INVX4, INVX8, INVX16 Inverters
FILL8, FILL4, FILL2, FILL Filler cells of various widths
These are used to fill empty spots in standard cell rows
ENINVX1, ENINVX2 Enabled inverters (tri-state inverters)
DCX1, DCNX1, DCBX1, DCBNX1 Edge triggered flip-flops
BUFX8, BUFX4, BUFX2 non-inverting buffers
AOI22X1, AOI21X1 AND-OR-Invert gates with 4 (22) and 3 (21) inputs
AND3X1 3-input AND
Figure 13.1: Cells contained in the UofU Digital v1 2 cell library. The cell names are coded
with output drive strengths: X1 is unit drive strength, and Xn is n-times that unit drive
strength. Sequential cells are coded with a C if they have a clear signal, B if they have
both Q and Qbar outputs, and N if they are clocked on a negative edge or level
发表于 2018-8-6 10:46:38 | 显示全部楼层
感謝樓主分享
发表于 2018-8-7 09:58:15 | 显示全部楼层
学习了  谢谢
GMT+8, 2025-12-24 23:01 , Processed in 0.021769 second(s), 3 queries , Gzip On, Redis On.
