我实现了一个 16*8bit的寄存器组 有一个输入端, 两个输出端,但是占用了 192个 逻辑单元.使用的是 EP1C6, QuartusII 4.2. 请帮我改一下,使他少占用资源,我是用在 微处理器 上的,要求速度快,且能同时读写,所以不能用 FPGA 内的 M4K 模块.
源代码如下:
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
entity REGS is
generic (
WIDTH : in natural := 8
port (
CLK : in std_logic;
DIN : in std_logic_vector(WIDTH-1 downto 0);
DIN_ADDR : in std_logic_vector(3 downto 0);
WEN : in std_logic;
DOUT0 : out std_logic_vector(WIDTH-1 downto 0);
DOUT1 : out std_logic_vector(WIDTH-1 downto 0);
DOUT0_ADDR : in std_logic_vector(3 downto 0);
DOUT1_ADDR : in std_logic_vector(3 downto 0)
end;
architecture RTL of REGS is
signal reg0 : std_logic_vector(WIDTH-1 downto 0);
signal reg1 : std_logic_vector(WIDTH-1 downto 0);
signal reg2 : std_logic_vector(WIDTH-1 downto 0);
signal reg3 : std_logic_vector(WIDTH-1 downto 0);
signal reg4 : std_logic_vector(WIDTH-1 downto 0);
signal reg5 : std_logic_vector(WIDTH-1 downto 0);
signal reg6 : std_logic_vector(WIDTH-1 downto 0);
signal reg7 : std_logic_vector(WIDTH-1 downto 0);
signal reg8 : std_logic_vector(WIDTH-1 downto 0);
signal reg9 : std_logic_vector(WIDTH-1 downto 0);
signal reg10 : std_logic_vector(WIDTH-1 downto 0);
signal reg11 : std_logic_vector(WIDTH-1 downto 0);
signal reg12 : std_logic_vector(WIDTH-1 downto 0);
signal reg13 : std_logic_vector(WIDTH-1 downto 0);
signal reg14 : std_logic_vector(WIDTH-1 downto 0);
signal reg15 : std_logic_vector(WIDTH-1 downto 0);
begin
data_in : process(CLK, DIN, DIN_ADDR, WEN)
begin
if (CLK'EVENT and CLK = '0' and WEN = '1') then
case DIN_ADDR is
when "0000" => reg0 <= DIN;
when "0001" => reg1 <= DIN;
when "0010" => reg2 <= DIN;
when "0011" => reg3 <= DIN;
when "0100" => reg4 <= DIN;
when "0101" => reg5 <= DIN;
when "0110" => reg6 <= DIN;
when "0111" => reg7 <= DIN;
when "1000" => reg8 <= DIN;
when "1001" => reg9 <= DIN;
when "1010" => reg10 <= DIN;
when "1011" => reg11 <= DIN;
when "1100" => reg12 <= DIN;
when "1101" => reg13 <= DIN;
when "1110" => reg14 <= DIN;
when "1111" => reg15 <= DIN;
when others => null;
end case;
end if;
end process;
DOUT0 <= reg0 when DOUT0_ADDR = "0000" else
reg1 when DOUT0_ADDR = "0001" else
reg2 when DOUT0_ADDR = "0010" else
reg3 when DOUT0_ADDR = "0011" else
reg4 when DOUT0_ADDR = "0100" else
reg5 when DOUT0_ADDR = "0101" else
reg6 when DOUT0_ADDR = "0110" else
reg7 when DOUT0_ADDR = "0111" else
reg8 when DOUT0_ADDR = "1000" else
reg9 when DOUT0_ADDR = "1001" else
reg10 when DOUT0_ADDR = "1010" else
reg11 when DOUT0_ADDR = "1011" else
reg12 when DOUT0_ADDR = "1100" else
reg13 when DOUT0_ADDR = "1101" else
reg14 when DOUT0_ADDR = "1110" else
reg15 ;
DOUT1 <= reg0 when DOUT1_ADDR = "0000" else
reg1 when DOUT1_ADDR = "0001" else
reg2 when DOUT1_ADDR = "0010" else
reg3 when DOUT1_ADDR = "0011" else
reg4 when DOUT1_ADDR = "0100" else
reg5 when DOUT1_ADDR = "0101" else
reg6 when DOUT1_ADDR = "0110" else
reg7 when DOUT1_ADDR = "0111" else
reg8 when DOUT1_ADDR = "1000" else
reg9 when DOUT1_ADDR = "1001" else
reg10 when DOUT1_ADDR = "1010" else
reg11 when DOUT1_ADDR = "1011" else
reg12 when DOUT1_ADDR = "1100" else
reg13 when DOUT1_ADDR = "1101" else
reg14 when DOUT1_ADDR = "1110" else
reg15;
end RTL; |
