查看: 12705|回复: 24
[资料] Primetime Reference Methodology script vG-2012.06
发表于 2013-6-21 13:43:48 | 显示全部楼层 |阅读模式
G-2012.06
This section describes new features, changes, and enhancements in the PrimeTime
Reference Methodology version G-2012.06.
*  Support has been added for a link-path-per-instance file containing commands
   that set link_path_per_instance variable to ensure appropriate linking for
   the design in PrimeTime.
   You create this tool command language (Tcl) script file by using the
   write_link_library command in Design Compiler or IC Compiler.
Lynx Compatibility
This release provides enhancements in the Lynx-compatible reference methodology
flow. For information about these enhancements, see the file named
Release_Notes.LynxCompatible-RM.txt.
PT-RM_G-2012.06.tar (50 KB , 下载次数: 162 )
PT-RM_G-2012.06-SP2.tar (50 KB , 下载次数: 163 )
发表于 2013-7-17 20:27:44 | 显示全部楼层
还两个文件
发表于 2013-11-28 13:29:47 | 显示全部楼层
什么东东下来看看
发表于 2014-5-6 21:47:09 | 显示全部楼层
先下载,看看是不是我预期的,谢谢楼主
发表于 2014-6-17 15:02:26 | 显示全部楼层
什么东东下来看看
发表于 2014-8-31 20:31:56 | 显示全部楼层
看一看!
发表于 2014-9-16 21:28:45 | 显示全部楼层
这个是干嘛用的啊
发表于 2014-9-17 19:35:53 | 显示全部楼层
谢谢分享,好好学习下。
发表于 2014-12-22 13:24:04 | 显示全部楼层
good reference
发表于 2015-1-27 09:22:51 | 显示全部楼层
GMT+8, 2025-12-16 03:22 , Processed in 0.023780 second(s), 6 queries , Gzip On, Redis On.
