查看: 2453|回复: 4
[求助] vhdl 求大神指点
发表于 2013-6-13 18:30:57 | 显示全部楼层 |阅读模式
代码如下
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD_LOGIC_ARITH.ALL;
LIBRARY WORK;
ENTITY TEST IS
   PORT (
   CLK : IN  std_logic;
   d : out std_logic_vector(3 downto 0));
END TEST;
ARCHITECTURE SIM OF TEST IS
   FUNCTION TMR (A,B,C:STd_LOGIC_VECTOR( 3 DOWNTO 0))     -- 三路表决器函数
  RETURN STD_LOGIC_VECTOR IS
   variable RESULT : STD_LOGIC_VECTOR(3 DOWNTO 0);
   begin
     for i in 3 to 0  loop
      RESULT(i) := ((A(i) AND B(i)) OR (C(i) AND B(i)) OR (A(i) AND C(i)))   ;
   END LOOP;
    RETURN  RESULT;
  END FUNCTION TMR;
  SIGNAL A :STD_LOGIC_VECTOR(3 DOWNTO 0);
  SIGNAL B :STD_LOGIC_VECTOR(3 DOWNTO 0);
  SIGNAL C :STD_LOGIC_VECTOR(3 DOWNTO 0);
     BEGIN
     P_RUN ROCESS(CLK)
     BEGIN
       IF CLK='1' THEN
         A<="1101";
         B<="1111";
         C<="1111";
         D<= TMR(A,B,C);---A,B,C调用函数表决
       ELSE
          A<="0000";
         B<="1000";
         C<="0000";
         D<= TMR(A,B,C);
       END IF;
     END PROCESS  P_RUN;
     END SIM;
tb文件给一个时钟信号
仿真结果如下:三路表决结果出错,未初始化态。
仿真结果,函数调用错误
仿真结果,函数调用错误
发表于 2013-6-13 19:08:47 | 显示全部楼层
回复 1# hecwty888
   初始态
 楼主| 发表于 2013-6-13 20:29:51 | 显示全部楼层
回复 2# shiyinjita
    函数赋值无效怎么搞
 楼主| 发表于 2013-6-14 09:09:09 | 显示全部楼层
莫沉,顶起
发表于 2013-6-14 20:25:38 | 显示全部楼层
你或者改成用复位来实现初始化,或者
SIGNAL A :STD_LOGIC_VECTOR(3 DOWNTO 0) := 0
好像是这样的,你多尝试几遍
GMT+8, 2025-11-25 04:16 , Processed in 0.028497 second(s), 6 queries , Gzip On, Redis On.
