查看: 5597|回复: 1
[求助] ise place route报错
发表于 2013-6-11 14:35:29 | 显示全部楼层 |阅读模式
ise在布局布线时出现以下错误:Phase  2  : 59979 unrouted; WARNING:Route:436 - The router has detected an unroutable situation for one or more connections. The router will finish the rest of the
   design and leave them as unrouted. The cause of this behavior is either an issue with the placement or unroutable placement constraints.
   To allow you to use FPGA editor to isolate the problems, the following is a list of (up to 10) such unroutable connections:
Unroutable
signal: CLK_9516_FPGA_245M76_2_P_IBUF
pin:  U_ila_pro_0/U0/I_NO_D.U_ILA/U_TRIG/U_TM/G_NMU[3].U_M/U_MU/DOUT_tmp/CLK
Unroutable
pin:  U_ila_pro_0/U0/I_NO_D.U_ILA/U_TRIG/U_TM/G_NMU[1].U_M/U_MU/DOUT_tmp/CLK
Unroutable
pin:  U_ila_pro_0/U0/I_NO_D.U_ILA/U_TRIG/U_TM/G_NMU[0].U_M/U_MU/DOUT_tmp/CLK
Unroutable
pin:  U_ila_pro_0/U0/I_NO_D.U_ILA/U_TRIG/U_TM/G_NMU[2].U_M/U_MU/DOUT_tmp/CLK
Unroutable
pin:
U_ila_pro_0/U0/I_NO_D.U_ILA/U_CAPSTOR/I_CASE1.I_YES_TB.U_TRACE_BUFFER/U_RAM/I_K7.U_CS_BRAM_CASCADE_K7/I_DEPTH_EQ_48K_OR_64K.U_SBRAM_0/I_B36K
GT0.G_RAMB36[41].u_ramb36/U_RAMB36/CLKBWRCLKL
求大神指导以下啊
发表于 2013-6-11 17:16:43 | 显示全部楼层
Chipscope未布通,先去掉后试试。资源使用太多?
GMT+8, 2025-12-25 18:29 , Processed in 0.021108 second(s), 9 queries , Gzip On, Redis On.
