楼主: raychore
更新文档
发表于 2014-1-6 00:57:10 | 显示全部楼层
试试看!!!!!!!!!!!!
发表于 2014-2-26 21:45:51 | 显示全部楼层
感谢楼主分享。
发表于 2014-3-24 22:19:38 | 显示全部楼层
果断支持一个
发表于 2014-3-27 17:10:30 | 显示全部楼层
MAny thanks
发表于 2014-4-1 02:10:45 | 显示全部楼层
谢谢.........
发表于 2014-4-1 02:27:05 | 显示全部楼层
謝謝..........
发表于 2014-4-9 15:37:39 | 显示全部楼层
破解工作也是任重道远啊 -- 小白吐槽
发表于 2014-4-15 01:38:35 | 显示全部楼层
回复 79# 伯伯尼
谁给个ic616的license链接?
发表于 2014-4-15 08:34:04 | 显示全部楼层
回复 80# dandeng
下面的两个帖子里都有,可以试试:
   1、http://bbs.eetop.cn/viewthread.php?tid=321723&from=favorites    2、http://bbs.eetop.cn/viewthread.php?tid=317711&from=favorites
发表于 2014-4-16 01:36:26 | 显示全部楼层
回复 81# 伯伯尼
Its ok now with IC616! thanks Friend
But the license seems not work for MMSIM12.10.347,
so my Spectre can not run, I got the following problem:
spectre input.scs -64 =aps
    Fatal error in MPI_Init: Other MPI error, error stack:
MPIR_Init_thread(420)..............:
MPID_Init(180).....................: channel initialization failed
MPIDI_CH3_Init(38).................:
MPID_nem_init(244).................:
MPID_nem_tcp_init(108).............:
MPID_nem_tcp_get_business_card(354):
MPID_nem_tcp_init(313).............: gethostbyname failed, danwork (errno 2)
so can you help me with Patch and license that can both work for IC616 and MMSIM12 at the same time
Thanks!
GMT+8, 2025-12-27 02:24 , Processed in 0.020754 second(s), 3 queries , Gzip On, Redis On.
