楼主: raychore
更新文档
发表于 2013-8-9 16:10:19 | 显示全部楼层
请问楼主,安装好616后,按照您的方法,将文件放入tools下,破解后,得出如下结果,如何解决呢?谢谢!
[tladmin@localhost ~]$ virtuoso
WARNING: HOST <localhost.localdomain> DOES NOT APPEAR TO BE A CADENCE SUPPORTED LINUX CONFIGURATION.
         For More Info,  Please Run '<cdsroot>/tools.lnx86/bin/checkSysConf' <productId>.
virtuoso:   ERROR: The OA2.2 library directory (/home1/tools/cadence/IC616_06.16.005/oa_v22.43.018/lib/linux_rhel40_gcc44x_32/opt) does not seem to exist.
virtuoso:    INFO: Note that OpenAccess (OA) requires running the Configure phase.
virtuoso:          See the "OpenAccess Installation and Configuration Guide" before
virtuoso:          you complete the configuration step. This manual is included with
virtuoso:          the Cadence product documentation.
发表于 2013-8-9 16:12:17 | 显示全部楼层
环境为redhat 4.8 x86_64
 楼主| 发表于 2013-8-10 20:40:00 | 显示全部楼层
回复 43# dc_2010
你OA没设置好啊,和我这个patch不搭嘎啊
发表于 2013-8-15 15:53:39 | 显示全部楼层
redhat cowboy
发表于 2013-8-26 22:04:07 | 显示全部楼层
太贵了,下载不起啊
发表于 2013-8-26 23:15:41 | 显示全部楼层
回复 1# raychore
   PlzPlzPlzPlzneedpvslicense...........
发表于 2013-8-29 01:03:00 | 显示全部楼层
hguyyyyyyyyyyyyyyyyyyyyyyyy
发表于 2013-9-6 12:18:28 | 显示全部楼层
to dc_2010, There are check on linux kernel version in sysname script. Matched versions are 2.4 and 2.6, but some linux distributions has kernel 3.*.*, so it does not match.
You can try to modify line 199 from
2.6*)
to
2.6* | 3.0*)
发表于 2013-9-10 13:07:08 | 显示全部楼层
thx for sharing
发表于 2013-9-10 17:12:49 | 显示全部楼层
不好意思啊LZ,我在弄的时候遇到了这样的提示……提示特别长但都差不多:
./sfk: error while loading shared libraries: libstdc++.so.5: cannot open shared object file: No such file or directory
./pearl/bin/pearlCell
./sev/bin/32bit/vsa2
./sev/bin/64bit/vpsbatch
./sev/bin/64bit/vsa2
./tlfUtil/bin/32bit/tlfConvert
./tlfUtil/bin/32bit/tlfEncrypt
./tlfUtil/bin/32bit/tlfMerge
我把压缩包内除了readme的其他所有文件都拷进了IC616安装位置下的tools文件夹,然后执行sh,出现如上提示……
请问LZ我该怎么办……?
GMT+8, 2025-12-27 00:35 , Processed in 0.018620 second(s), 3 queries , Gzip On, Redis On.
