查看: 3606|回复: 3
[求助] virtuoso在新建库的时候加tf文件的时候出现如下的报错。很多层都不显示
发表于 2013-5-29 10:51:13 | 显示全部楼层 |阅读模式
我使用的是Ic514,工艺为smic.18.在新建库的时候加tf文件的时候出现如下的报错。很多层都不显示,说load tf失败
*WARNING* techCreateLayer: layer number 10 already exists (L10)
*WARNING* Layer 'AA' was not defined -- (AA 10 AA)
*WARNING* techCreateLayer: layer number 14 already exists (L14)
*WARNING* Layer 'NW' was not defined -- (NW 14 NW)
*WARNING* techCreateLayer: layer number 29 already exists (L29)
*WARNING* Layer 'DG' was not defined -- (DG 29 DG)
*WARNING* techCreateLayer: layer number 30 already exists (L30)
*WARNING* Layer 'GT' was not defined -- (GT 30 GT)
*WARNING* techCreateLayer: layer number 40 already exists (L40)
*WARNING* Layer 'SN' was not defined -- (SN 40 SN)
*WARNING* techCreateLayer: layer number 41 already exists (L41)
*WARNING* Layer 'ESD1' was not defined -- (ESD1 41 ESD1)
*WARNING* techCreateLayer: layer number 43 already exists (L43)
*WARNING* Layer 'SP' was not defined -- (SP 43 SP)
*WARNING* techCreateLayer: layer number 48 already exists (L48)
*WARNING* Layer 'SAB' was not defined -- (SAB 48 SAB)
*WARNING* techCreateLayer: layer number 50 already exists (L50)
*WARNING* Layer 'CT' was not defined -- (CT 50 CT)
*WARNING* techCreateLayer: layer number 61 already exists (L61)
*WARNING* Layer 'M1' was not defined -- (M1 61 M1)
.是不是版本不兼容?
没有别的技术库可以链接
发表于 2013-7-25 06:51:57 | 显示全部楼层
确定tf没弄错吧?
发表于 2013-10-3 09:41:26 | 显示全部楼层
检查下tf文件看相关定义是否有需要屏蔽的地方?
发表于 2013-10-9 20:20:29 | 显示全部楼层
有没有map文件哪
GMT+8, 2025-12-20 23:30 , Processed in 0.014153 second(s), 3 queries , Gzip On, Redis On.
