查看: 16094|回复: 31
[求助] virtuoso新建库的时候加tf文件的时候出现如下的报错。很多层都不显示
发表于 2013-5-29 10:49:09 | 显示全部楼层 |阅读模式
我使用的是Ic514,工艺为smic.18.在新建库的时候加tf文件的时候出现如下的报错。很多层都不显示,说load tf失败
*WARNING* techCreateLayer: layer number 10 already exists (L10)
*WARNING* Layer 'AA' was not defined -- (AA 10 AA)
*WARNING* techCreateLayer: layer number 14 already exists (L14)
*WARNING* Layer 'NW' was not defined -- (NW 14 NW)
*WARNING* techCreateLayer: layer number 29 already exists (L29)
*WARNING* Layer 'DG' was not defined -- (DG 29 DG)
*WARNING* techCreateLayer: layer number 30 already exists (L30)
*WARNING* Layer 'GT' was not defined -- (GT 30 GT)
*WARNING* techCreateLayer: layer number 40 already exists (L40)
*WARNING* Layer 'SN' was not defined -- (SN 40 SN)
*WARNING* techCreateLayer: layer number 41 already exists (L41)
*WARNING* Layer 'ESD1' was not defined -- (ESD1 41 ESD1)
*WARNING* techCreateLayer: layer number 43 already exists (L43)
*WARNING* Layer 'SP' was not defined -- (SP 43 SP)
*WARNING* techCreateLayer: layer number 48 already exists (L48)
*WARNING* Layer 'SAB' was not defined -- (SAB 48 SAB)
*WARNING* techCreateLayer: layer number 50 already exists (L50)
*WARNING* Layer 'CT' was not defined -- (CT 50 CT)
*WARNING* techCreateLayer: layer number 61 already exists (L61)
*WARNING* Layer 'M1' was not defined -- (M1 61 M1)
.是不是版本不兼容?
 楼主| 发表于 2013-5-29 11:29:02 | 显示全部楼层
有人解答一下吗
发表于 2013-5-29 12:40:34 | 显示全部楼层
要看一下tf文件时怎么写的。贴出来诊断一下?
 楼主| 发表于 2013-5-29 23:17:13 | 显示全部楼层
回复 3# amodaman
   不知道明日是否还在?明天上班贴上去
 楼主| 发表于 2013-5-30 08:38:55 | 显示全部楼层
回复 3# amodaman
; LAYER DEFINITION
layerDefinitions(
techPurposes(
;( PurposeName               Purpose#   Abbreviation )
;User-Defined Purposes:
;System-Reserved Purposes:
  ( warning                   234        wng          )
  ( tool1                     235        tl1          )
  ( tool0                     236        tl0          )
  ( label                     237        lbl          )
  ( flight                    238        flt          )
  ( error                     239        err          )
  ( annotate                  240        ant          )
  ( drawing1                  241        dr1          )
  ( drawing2                  242        dr2          )
  ( drawing3                  243        dr3          )
  ( drawing4                  244        dr4          )
  ( drawing5                  245        dr5          )
  ( drawing6                  246        dr6          )
  ( drawing7                  247        dr7          )
  ( drawing8                  248        dr8          )
  ( drawing9                  249        dr9          )
  ( boundary                  250        bnd          )
  ( pin                       251        pin          )
  ( drawing                   252        drw          )
  ( net                       253        net          )
  ( cell                      254        cel          )
  ( all                       255        all          )
) ;techPurposes
techLayers(
;( LayerName                 Layer#     Abbreviation )
;User-Defined Layers:
  ( L0                        0          L0           )
  ( AA                        10         AA           )
  ( NPAA                      12         NPAA         )
  ( PPAA                      13         PPAA         )
  ( NW                        14         NW           )
  ( TP                        15         TP           )
  ( DNW                       19         DNW          )
  ( PW                        20         PW           )
  ( BNP                       23         BNP          )
  ( TN                        24         TN           )
  ( DG                        29         DG           )
  ( GT                        30         GT           )
  ( P2                        31         P2           )
  ( NLL                       35         NLL          )
  ( NLH                       36         NLH          )
  ( PLH                       37         PLH          )
  ( PLL                       38         PLL          )
  ( HRP                       39         HRP          )
  ( SN                        40         SN           )
  ( ESD1                      41         ESD1         )
  ( ESD2                      42         ESD2         )
  ( SP                        43         SP           )
  ( MVP                       44         MVP          )
  ( MVN                       45         MVN          )
  ( SAB                       48         SAB          )
  ( CT                        50         CT           )
  ( MIM                       58         MIM          )
  ( M1                        61         M1           )
  ( M2                        62         M2           )
  ( M3                        63         M3           )
  ( M4                        64         M4           )
  ( M5                        65         M5           )
  ( M6                        66         M6           )
  ( M7                        67         M7           )
  ( M8                        68         M8           )
  ( V1                        70         V1           )
  ( V2                        71         V2           )
  ( V3                        72         V3           )
  ( V4                        73         V4           )
  ( V5                        74         V5           )
  ( V6                        75         V6           )
  ( V7                        76         V7           )
  ( PA                        80         PA           )
  ( ALPA                      83         ALPA         )
  ( SUBTXT                    84         SUBTXT       )
  ( NAN                       85         NAN          )
  ( WELTXT                    86         WELTXT       )
  ( TTXT                      87         TTXT         )
  ( BTXT                      88         BTXT         )
  ( L89                       89         L89          )
  ( HRPDMY                    92         HRPDMY       )
  ( MIMDMY                    93         MIMDMY       )
  ( INDMY                     94         INDMY        )
  ( Res_NW                    95         Res_NW       )
  ( Res_P1                    96         Res_P1       )
  ( Res_AA                    97         Res_AA       )
  ( SUBD                      98         SUBD         )
  ( M6B                       99         M6B          )
  ( OPCBA                     100        OPCBA        )
  ( OPCBP                     101        OPCBP        )
  ( OPCBM                     102        OPCBM        )
  ( M5B                       103        M5B          )
  ( M4B                       104        M4B          )
  ( PWH                       105        PWH          )
  ( NWH                       106        NWH          )
  ( DIFTXT                    107        DIFTXT       )
  ( POLYTXT                   108        POLYTXT      )
  ( M3B                       109        M3B          )
  ( HTNWL                     110        htnwl        )
  ( EXCLU                     111        exclu        )
  ( ESDIO                     112        ESDIO        )
  ( DMPNP                     113        DMPNP        )
  ( PDC                       114        PDC          )
  ( PWL                       115        PWL          )
  ( CAPBP                     116        CAPBP        )
  ( DSTR                      117        DSTR         )
  ( DCTY                      118        DCTY         )
  ( M1TXT                     119        M1TXT        )
  ( M2TXT                     120        M2TXT        )
  ( M3TXT                     121        M3TXT        )
  ( M4TXT                     122        M4TXT        )
  ( M5TXT                     123        M5TXT        )
  ( M6TXT                     124        M6TXT        )
  ( M1B                       125        M1B          )
  ( M2B                       126        M2B          )
  ( BORDER                    127        BORDER       )
;System-Reserved Layers:
  ( Unrouted                  200        Unroute      )
  ( Row                       201        Row          )
  ( Group                     202        Group        )
  ( Cannotoccupy              203        noOcupy      )
  ( Canplace                  204        Canplac      )
  ( hardFence                 205        hardFnc      )
  ( softFence                 206        softFnc      )
  ( y0                        207        y0           )
  ( y1                        208        y1           )
  ( y2                        209        y2           )
  ( y3                        210        y3           )
  ( y4                        211        y4           )
  ( y5                        212        y5           )
  ( y6                        213        y6           )
  ( y7                        214        y7           )
  ( y8                        215        y8           )
  ( y9                        216        y9           )
  ( designFlow                217        dsnFlow      )
  ( stretch                   218        stretch      )
  ( edgeLayer                 219        edgeLyr      )
  ( changedLayer              220        chngLyr      )
  ( unset                     221        unset        )
  ( unknown                   222        unknown      )
  ( spike                     223        spike        )
  ( hiz                       224        hiz          )
  ( resist                    225        resist       )
  ( drive                     226        drive        )
  ( supply                    227        supply       )
  ( wire                      228        wire         )
  ( pin                       229        pin          )
  ( text                      230        text         )
  ( device                    231        device       )
  ( border                    232        border       )
  ( snap                      233        snap         )
  ( align                     234        align        )
  ( prBoundary                235        prBndry      )
  ( instance                  236        instnce      )
  ( annotate                  237        anotate      )
  ( marker                    238        marker       )
  ( select                    239        select       )
  ( grid                      251        grid         )
  ( axis                      252        axis         )
  ( hilite                    253        hilite       )
  ( background                254        bkground     )
) ;techLayers
techLayerPurposePriorities(
;layers are ordered from lowest to highest priority
;( LayerName                 Purpose    )
  ( background                drawing    )
  ( grid                      drawing    )
  ( grid                      drawing1   )
  ( annotate                  drawing    )
  ( annotate                  drawing1   )
  ( annotate                  drawing2   )
  ( annotate                  drawing3   )
  ( annotate                  drawing4   )
  ( annotate                  drawing5   )
  ( annotate                  drawing6   )
  ( annotate                  drawing7   )
  ( annotate                  drawing8   )
  ( annotate                  drawing9   )
  ( instance                  drawing    )
  ( instance                  label      )
  ( prBoundary                drawing    )
  ( prBoundary                boundary   )
  ( prBoundary                label      )
  ( align                     drawing    )
  ( hardFence                 drawing    )
  ( softFence                 drawing    )
  ( text                      drawing    )
  ( text                      drawing1   )
  ( text                      drawing2   )
  ( border                    drawing    )
  ( device                    drawing    )
  ( device                    label      )
  ( device                    drawing1   )
  ( device                    drawing2   )
  ( device                    annotate   )
  ( wire                      drawing    )
  ( wire                      label      )
  ( wire                      flight     )
  ( pin                       label      )
  ( pin                       drawing    )
  ( pin                       annotate   )
  ( axis                      drawing    )
  ( edgeLayer                 drawing    )
  ( edgeLayer                 pin        )
  ( snap                      drawing    )
  ( stretch                   drawing    )
  ( y0                        drawing    )
  ( y1                        drawing    )
  ( y2                        drawing    )
  ( y3                        drawing    )
  ( y4                        drawing    )
  ( y5                        drawing    )
  ( y6                        drawing    )
  ( y7                        drawing    )
  ( y8                        drawing    )
  ( y9                        drawing    )
  ( hilite                    drawing    )
  ( hilite                    drawing1   )
  ( hilite                    drawing2   )
  ( hilite                    drawing3   )
  ( hilite                    drawing4   )
  ( hilite                    drawing5   )
  ( hilite                    drawing6   )
  ( hilite                    drawing7   )
  ( hilite                    drawing8   )
  ( hilite                    drawing9   )
  ( select                    drawing    )
  ( drive                     drawing    )
  ( hiz                       drawing    )
  ( resist                    drawing    )
  ( spike                     drawing    )
  ( supply                    drawing    )
  ( unknown                   drawing    )
  ( unset                     drawing    )
  ( designFlow                drawing    )
  ( designFlow                drawing1   )
  ( designFlow                drawing2   )
  ( designFlow                drawing3   )
  ( designFlow                drawing4   )
  ( designFlow                drawing5   )
  ( designFlow                drawing6   )
  ( designFlow                drawing7   )
  ( designFlow                drawing8   )
  ( designFlow                drawing9   )
  ( changedLayer              tool0      )
  ( changedLayer              tool1      )
  ( marker                    warning    )
  ( marker                    error      )
  ( Row                       drawing    )
  ( Row                       label      )
  ( Group                     drawing    )
  ( Group                     label      )
  ( Cannotoccupy              drawing    )
  ( Cannotoccupy              boundary   )
  ( Canplace                  drawing    )
  ( Unrouted                  drawing    )
  ( Unrouted                  drawing1   )
  ( Unrouted                  drawing2   )
  ( Unrouted                  drawing3   )
  ( Unrouted                  drawing4   )
  ( Unrouted                  drawing5   )
  ( Unrouted                  drawing6   )
  ( Unrouted                  drawing7   )
  ( Unrouted                  drawing8   )
  ( Unrouted                  drawing9   )
  ( L0                        drawing    )
  ( AA                        drawing    )
  ( NPAA                      drawing    )
  ( PPAA                      drawing    )
  ( NW                        drawing    )
  ( TP                        drawing    )
  ( DNW                       drawing    )
  ( PW                        drawing    )
  ( BNP                       drawing    )
  ( TN                        drawing    )
  ( GT                        drawing    )
  ( P2                        drawing    )
  ( NLH                       drawing    )
  ( NLL                       drawing    )
  ( PLH                       drawing    )
  ( PLL                       drawing    )
  ( HRP                       drawing    )
  ( SN                        drawing    )
  ( SP                        drawing    )
  ( ESD1                      drawing    )
  ( ESD2                      drawing    )
  ( MVP                       drawing    )
  ( MVN                       drawing    )
  ( SAB                       drawing    )
  ( MIM                       drawing    )
  ( M1                        drawing    )
  ( M2                        drawing    )
  ( M3                        drawing    )
  ( M4                        drawing    )
  ( M5                        drawing    )
  ( M6                        drawing    )
  ( M7                        drawing    )
  ( M8                        drawing    )
  ( NAN                       drawing    )
  ( TTXT                      drawing    )
  ( BTXT                      drawing    )
  ( Res_NW                    drawing    )
  ( Res_P1                    drawing    )
  ( Res_AA                    drawing    )
  ( V1                        drawing    )
  ( V2                        drawing    )
  ( V3                        drawing    )
  ( V4                        drawing    )
  ( V5                        drawing    )
  ( V6                        drawing    )
  ( V7                        drawing    )
  ( CT                        drawing    )
  ( DG                        drawing    )
  ( PA                        drawing    )
  ( ALPA                      drawing    )
  ( SUBD                      drawing    )
  ( HTNWL                     drawing    )
  ( EXCLU                     drawing    )
  ( L89                       drawing    )
  ( HRPDMY                    drawing    )
  ( MIMDMY                    drawing    )
  ( INDMY                     drawing    )
  ( ESDIO                     drawing    )
  ( DMPNP                     drawing    )
  ( PDC                       drawing    )
  ( PWL                       drawing    )
  ( CAPBP                     drawing    )
  ( DSTR                      drawing    )
  ( DCTY                      drawing    )
  ( M1TXT                     drawing    )
  ( M2TXT                     drawing    )
  ( M3TXT                     drawing    )
  ( M4TXT                     drawing    )
  ( M5TXT                     drawing    )
  ( M6TXT                     drawing    )
  ( SUBTXT                    drawing    )
  ( WELTXT                    drawing    )
  ( DIFTXT                    drawing    )
  ( POLYTXT                   drawing    )
  ( M1B                       drawing    )
  ( M2B                       drawing    )
  ( BORDER                    drawing    )
  ( M3B                       drawing    )
  ( M4B                       drawing    )
  ( M5B                       drawing    )
  ( M6B                       drawing    )
  ( PWH                       drawing    )
  ( NWH                       drawing    )
  ( OPCBA                     drawing    )
  ( OPCBP                     drawing    )
  ( OPCBM                     drawing    )
) ;techLayerPurposePriorities
techDisplays(
;( LayerName    Purpose      Packet          Vis Sel Con2ChgLy DrgEnbl Valid )
  ( background   drawing      background       t nil t nil nil )
  ( grid         drawing      grid             t nil t nil nil )
  ( grid         drawing1     grid1            t nil t nil nil )
  ( annotate     drawing      annotate         t t t t nil )
  ( annotate     drawing1     annotate1        t t t t nil )
  ( annotate     drawing2     annotate2        t t t t nil )
  ( annotate     drawing3     annotate3        t t t t nil )
  ( annotate     drawing4     annotate4        t t t t nil )
  ( annotate     drawing5     annotate5        t t t t nil )
  ( annotate     drawing6     annotate6        t t t t nil )
  ( annotate     drawing7     annotate7        t t t t nil )
  ( annotate     drawing8     annotate8        t t t t nil )
  ( annotate     drawing9     annotate9        t t t t nil )
  ( instance     drawing      instance         t t t t nil )
  ( instance     label        instanceLbl      t t t t nil )
  ( prBoundary   drawing      prBoundary       t t t t nil )
  ( prBoundary   boundary     prBoundaryBnd    t t t t nil )
  ( prBoundary   label        prBoundaryLbl    t t t t nil )
  ( align        drawing      defaultPacket    t t t t nil )
  ( hardFence    drawing      hardFence        t t t t nil )
  ( softFence    drawing      softFence        t t t t nil )
  ( text         drawing      text             t t t t nil )
  ( text         drawing1     text1            t t t t nil )
  ( text         drawing2     text2            t t t t nil )
  ( border       drawing      border           t t t t nil )
  ( device       drawing      device           t t t t nil )
  ( device       label        deviceLbl        t t t t nil )
  ( device       drawing1     device1          t t t t nil )
  ( device       drawing2     device2          t t t t nil )
  ( device       annotate     deviceAnt        t t t t nil )
  ( wire         drawing      wire             t t t t nil )
  ( wire         label        wireLbl          t t t t nil )
  ( wire         flight       wireFlt          t t t t nil )
  ( pin          label        pinLbl           t t t t nil )
  ( pin          drawing      pin              t t t t nil )
  ( pin          annotate     pinAnt           t t t t nil )
  ( axis         drawing      axis             t nil t t nil )
  ( edgeLayer    drawing      edgeLayer        t t t t nil )
  ( edgeLayer    pin          edgeLayerPin     t t t t nil )
  ( snap         drawing      snap             t t t t nil )
  ( stretch      drawing      stretch          t t t t nil )
  ( y0           drawing      y0               t t t t nil )
  ( y1           drawing      y1               t t t t nil )
  ( y2           drawing      y2               t t t t nil )
  ( y3           drawing      y3               t t t t nil )
  ( y4           drawing      y4               t t t t nil )
  ( y5           drawing      y5               t t t t nil )
  ( y6           drawing      y6               t t t t nil )
  ( y7           drawing      y7               t t t t nil )
  ( y8           drawing      y8               t t t t nil )
  ( y9           drawing      y9               t t t t nil )
  ( hilite       drawing      hilite           t t t t nil )
  ( hilite       drawing1     hilite1          t t t t nil )
  ( hilite       drawing2     hilite2          t t t t nil )
  ( hilite       drawing3     hilite3          t t t t nil )
  ( hilite       drawing4     hilite4          t t t t nil )
  ( hilite       drawing5     hilite5          t t t t nil )
  ( hilite       drawing6     hilite6          t t t t nil )
  ( hilite       drawing7     hilite7          t t t t nil )
  ( hilite       drawing8     hilite8          t t t t nil )
  ( hilite       drawing9     hilite9          t t t t nil )
  ( select       drawing      select           t t t t nil )
  ( drive        drawing      drive            t t t t nil )
  ( hiz          drawing      hiz              t t t t nil )
  ( resist       drawing      resist           t t t t nil )
  ( spike        drawing      spike            t t t t nil )
  ( supply       drawing      supply           t t t t nil )
  ( unknown      drawing      unknown          t t t t nil )
  ( unset        drawing      unset            t t t t nil )
  ( designFlow   drawing      designFlow       t nil nil nil nil )
  ( designFlow   drawing1     designFlow1      t nil nil nil nil )
  ( designFlow   drawing2     designFlow2      t nil nil nil nil )
  ( designFlow   drawing3     designFlow3      t nil nil nil nil )
  ( designFlow   drawing4     designFlow4      t nil nil nil nil )
  ( designFlow   drawing5     designFlow5      t nil nil nil nil )
  ( designFlow   drawing6     designFlow6      t nil nil nil nil )
  ( designFlow   drawing7     designFlow7      t nil nil nil nil )
  ( designFlow   drawing8     designFlow8      t nil nil nil nil )
  ( designFlow   drawing9     designFlow9      t nil nil nil nil )
  ( changedLayer tool0        changedLayerTl0  nil nil t nil nil )
  ( changedLayer tool1        changedLayerTl1  nil nil t nil nil )
  ( marker       warning      markerWarn       t t t t nil )
  ( marker       error        markerErr        t t t t nil )
  ( Row          drawing      Row              t t t t nil )
  ( Row          label        RowLbl           t t t t nil )
  ( Group        drawing      Group            t t t t nil )
  ( Group        label        GroupLbl         t t t t nil )
  ( Cannotoccupy drawing      Cannotoccupy     t t t t nil )
  ( Cannotoccupy boundary     CannotoccupyBnd  t t t t nil )
  ( Canplace     drawing      Canplace         t t t t nil )
  ( Unrouted     drawing      Unrouted         t t t t nil )
  ( Unrouted     drawing1     Unrouted1        t t t t nil )
  ( Unrouted     drawing2     Unrouted2        t t t t nil )
  ( Unrouted     drawing3     Unrouted3        t t t t nil )
  ( Unrouted     drawing4     Unrouted4        t t t t nil )
  ( Unrouted     drawing5     Unrouted5        t t t t nil )
  ( Unrouted     drawing6     Unrouted6        t t t t nil )
  ( Unrouted     drawing7     Unrouted7        t t t t nil )
  ( Unrouted     drawing8     Unrouted8        t t t t nil )
  ( Unrouted     drawing9     Unrouted9        t t t t nil )
  ( L0           drawing      l0               t t t t t )
  ( AA           drawing      aa               t t t t t )
  ( NPAA         drawing      npaa             t t t t t )
  ( PPAA         drawing      ppaa             t t t t t )
  ( NW           drawing      nw               t t t t t )
  ( TP           drawing      tp               t t t t t )
  ( DNW          drawing      dnw              t t t t t )
  ( PW           drawing      pw               t t t t t )
  ( BNP          drawing      bnp              t t t t t )
  ( TN           drawing      tn               t t t t t )
  ( GT           drawing      gt               t t t t t )
  ( P2           drawing      p2               t t t t t )
  ( NLH          drawing      nlh              t t t t t )
  ( NLL          drawing      nll              t t t t t )
  ( PLH          drawing      plh              t t t t t )
  ( PLL          drawing      pll              t t t t t )
  ( HRP          drawing      hrp              t t t t t )
  ( SN           drawing      sn               t t t t t )
  ( SP           drawing      sp               t t t t t )
  ( ESD1         drawing      esd1             t t t t t )
  ( ESD2         drawing      esd2             t t t t t )
  ( MVP          drawing      mvp              t t t t t )
  ( MVN          drawing      mvn              t t t t t )
  ( SAB          drawing      sab              t t t t t )
  ( MIM          drawing      mim              t t t t t )
  ( M1           drawing      m1               t t t t t )
  ( M2           drawing      m2               t t t t t )
  ( M3           drawing      m3               t t t t t )
  ( M4           drawing      m4               t t t t t )
  ( M5           drawing      m5               t t t t t )
  ( M6           drawing      m6               t t t t t )
  ( M7           drawing      m7               t t t t t )
  ( M8           drawing      m8               t t t t t )
  ( NAN          drawing      nan              t t t t t )
  ( TTXT         drawing      ttxt             t t t t t )
  ( BTXT         drawing      btxt             t t t t t )
  ( Res_NW       drawing      res_nw           t t t t t )
  ( Res_P1       drawing      res_p1           t t t t t )
  ( Res_AA       drawing      res_aa           t t t t t )
  ( V1           drawing      v1               t t t t t )
  ( V2           drawing      v2               t t t t t )
  ( V3           drawing      v3               t t t t t )
  ( V4           drawing      v4               t t t t t )
  ( V5           drawing      v5               t t t t t )
  ( V6           drawing      v6               t t t t t )
  ( V7           drawing      v7               t t t t t )
  ( CT           drawing      ct               t t t t t )
  ( DG           drawing      dg               t t t t t )
  ( PA           drawing      pa               t t t t t )
  ( ALPA         drawing      alpa             t t t t t )
  ( SUBD         drawing      subd             t t t t t )
  ( HTNWL        drawing      htnwl            t t t t t )
  ( EXCLU        drawing      exclu            t t t t t )
  ( HRPDMY       drawing      hrpdmy           t t t t t )
  ( MIMDMY       drawing      mimdmy           t t t t t )
  ( INDMY        drawing      indmy            t t t t t )
  ( L89          drawing      grid1            t t t t t )
  ( ESDIO        drawing      esdio            t t t t t )
  ( DMPNP        drawing      dmpnp            t t t t t )
  ( PDC          drawing      pdc              t t t t t )
  ( PWL          drawing      pwl              t t t t t )
  ( CAPBP        drawing      capbp            t t t t t )
  ( DSTR         drawing      dstr             t t t t t )
  ( DCTY         drawing      dcty             t t t t t )
  ( M1TXT        drawing      m1txt            t t t t t )
  ( M2TXT        drawing      m2txt            t t t t t )
  ( M3TXT        drawing      m3txt            t t t t t )
  ( M4TXT        drawing      m4txt            t t t t t )
  ( M5TXT        drawing      m5txt            t t t t t )
  ( M6TXT        drawing      m6txt            t t t t t )
  ( SUBTXT       drawing      subtxt           t t t t t )
  ( WELTXT       drawing      weltxt           t t t t t )
  ( DIFTXT       drawing      diftxt           t t t t t )
  ( POLYTXT      drawing      polytxt          t t t t t )
  ( M1B          drawing      m1b              t t t t t )
  ( M2B          drawing      m2b              t t t t t )
  ( BORDER       drawing      border           t t t t t )
  ( M3B          drawing      m3b              t t t t t )
  ( M4B          drawing      m4b              t t t t t )
  ( M5B          drawing      m5b              t t t t t )
  ( M6B          drawing      m6b              t t t t t )
  ( PWH          drawing      pwh              t t t t t )
  ( NWH          drawing      nwh              t t t t t )
  ( OPCBA        drawing      opcba            t t t t t )
  ( OPCBP        drawing      opcbp            t t t t t )
  ( OPCBM        drawing      opcbm            t t t t t )
) ;techDisplays
techLayerProperties(
;( PropName               Layer1 [ Layer2 ]            PropValue )
) ;layerDefinitions
; LAYER RULES
layerRules(
streamLayers(
;( layer             streamNumber   dataType        translate   )
  ( ("L0" "drawing")
    0
0
t
  ( ("AA" "drawing")
    10
0
t
  ( ("NPAA" "drawing")      12          0               t        )
  ( ("PPAA" "drawing")      13          0               t        )
  ( ("NW" "drawing")
    14
0
t
  ( ("TP" "drawing")
    15
0
t
  ( ("DNW" "drawing")
    19
0
t
  ( ("PW" "drawing")
    20
0
t
  ( ("BNP" "drawing")
    23
0
t
  ( ("TN" "drawing")
    24
0
t
  ( ("DG" "drawing")
    29
0
t
  ( ("GT" "drawing")
    30
0
t
  ( ("P2" "drawing")
    31
0
t
  ( ("NLL" "drawing")       35          0               t        )
  ( ("NLH" "drawing")       36          0               t        )
  ( ("PLH" "drawing")       37          0               t        )
  ( ("PLL" "drawing")
    38
0
t
  ( ("HRP" "drawing")
    39
0
t
  ( ("SN" "drawing")
    40
0
t
  ( ("ESD1" "drawing")      41          0               t        )
  ( ("ESD2" "drawing")      42          0               t        )
  ( ("SP" "drawing")
    43
0
t
  ( ("MVP" "drawing")
    44
0
t
  ( ("MVN" "drawing")
    45
0
t
  ( ("SAB" "drawing")
    48
0
t
  ( ("CT" "drawing")
    50
0
t
  ( ("MIM" "drawing")       58          0               t        )
  ( ("M1" "drawing")
    61
0
t
  ( ("M2" "drawing")
    62
0
t
  ( ("M3" "drawing")        63          0               t        )
  ( ("M4" "drawing")        64          0               t        )
  ( ("M5" "drawing")        65          0               t        )
  ( ("M6" "drawing")        66          0               t        )
  ( ("M7" "drawing")        67          0               t        )
  ( ("M8" "drawing")        68          0               t        )
  ( ("V1" "drawing")
    70
0
t
  ( ("V2" "drawing")        71          0               t        )
  ( ("V3" "drawing")        72          0               t        )
  ( ("V4" "drawing")        73          0               t        )
  ( ("V5" "drawing")        74          0               t        )
  ( ("V6" "drawing")        75          0               t        )
  ( ("V7" "drawing")        76          0               t        )
  ( ("PA" "drawing")        80          0               t        )
  ( ("ALPA" "drawing")      83          0               t        )
  ( ("NAN" "drawing")
    85
0
t
  ( ("TTXT" "drawing")
    87
0
t
  ( ("BTXT" "drawing")
    88
0
t
  ( ("HRPDMY" "drawing")    92
0
t
  ( ("MIMDMY" "drawing")    93
0
t
  ( ("INDMY" "drawing")
    94
0
t
  ( ("L89" "drawing")
    89
0
t
  ( ("Res_NW" "drawing")    95
0
t
  ( ("Res_P1" "drawing")    96
0
t
  ( ("Res_AA" "drawing")    97
0
t
  ( ("OPCBA" "drawing")    100          0               t        )
  ( ("OPCBP" "drawing")    101          0               t        )
  ( ("OPCBM" "drawing")    102          0               t        )
  ( ("PWH" "drawing")      105          0               t        )
  ( ("NWH" "drawing")      106          0               t        )
  ( ("BORDER" "drawing")   127          0               t        )
  ( ("HTNWL" "drawing")    131          0               t        )
  ( ("SUBD"  "drawing")    131          1               t        )
  ( ("EXCLU" "drawing")    132          0               t        )
  ( ("ESDIO" "drawing")    133          0               t        )
  ( ("DMPNP" "drawing")
   134
0
t
  ( ("PDC"   "drawing")
   135
0
t
  ( ("PWL" "drawing")
   136
0
t
  ( ("CAPBP" "drawing")
   137
0
t
  ( ("DSTR" "drawing")
   138
0
t
  ( ("DCTY" "drawing")
   139
0
t
  ( ("M1TXT" "drawing")
   141
0
t
  ( ("M2TXT" "drawing")
   142
0
t
  ( ("M3TXT" "drawing")
   143
0
t
  ( ("M4TXT" "drawing")
   144
0
t
  ( ("M5TXT" "drawing")
   145
0
t
  ( ("M6TXT" "drawing")
   146
0
t
  ( ("SUBTXT"  "drawing")  161          0               t        )
  ( ("WELTXT"  "drawing")  162          0               t        )
  ( ("DIFTXT"  "drawing")  163          0               t        )
  ( ("POLYTXT" "drawing")  164          0               t        )
  ( ("M1B" "drawing")
   151          0
        t
  ( ("M2B" "drawing")
   152          0
        t
  ( ("M3B" "drawing")
   153          0
        t
  ( ("M4B" "drawing")
   154          0
        t
  ( ("M5B" "drawing")
   155          0
        t
  ( ("M6B" "drawing")
   156          0
        t
) ;streamLayers
) ;layerRules
; PHYSICAL RULES
physicalRules(
mfgGridResolution(
      ( 0.005000 )
) ;mfgGridResolution
) ;physicalRules
 楼主| 发表于 2013-5-30 08:43:19 | 显示全部楼层
回复 3# amodaman
   再来display文件;#########################################################################
;#               Virtuoso Display File                                   #
;# @Process    SMIC All Logic Process
;#$RCSfile: display.drf,v $
;#$Author: Wendy_Sui
;#$Modifier: Micky_Yu
;#$Revision: 1.2 $
;#$Date: 2003/04/07 03:52:08 $
;#$Revision History:
;#$   2003/04/03, Change some color and copy to different folder of vir techfile
;#$               Revision : 1.1
;#$   2003/01/16, Modify: PDC, by Micky
;#$               Add:    SUBTXT,WELTXT,DIFTXT,POLYTXT $
;#$   2003/01/24, Add subd according to new SMIC mapping file $
;#$   2003/03/17, Add m7,m8,v6,v7, l127--> border
drDefineDisplay(
;( DisplayName )
( display       )
drDefineColor(
;( DisplayName   ColorsName   Red      Green    Blue     )
( display       white        255      255      255      )
( display       yellow       255      255      0        )
( display       silver       217      230      255      )
( display       cream        255      255      204      )
( display       pink         255      191      242      )
( display       magenta      255      0        255      )
( display       lime         0        255      0        )
( display       tan          255      230      191      )
( display       cyan         0        255      255      )
( display       cadetBlue    57       191      255      )
( display       orange       255      128      0        )
( display       red          255      0        0        )
( display       purple       153      0        230      )
( display       green        0        204      102      )
( display       brown        191      64       38       )
( display       blue         0        0        255      )
( display       slate        140      140      166      )
( display       gold         217      204      0        )
( display       maroon       230      31       13       )
( display       violet       94       0        230      )
( display       forest       38       140      107      )
( display       chocolate    128      38       38       )
( display       navy         51       51       153      )
( display       black        0        0        0        )
( display       gray         204      204      217      )
( display       winColor1    166      166      166      )
( display       winColor2    115      115      115      )
( display       winColor3    189      204      204      )
( display       winColor4    204      204      204      )
( display       winColor5    199      199      199      )
( display       blinkRed     255      0        0        t )
( display       blinkYellow  255      255      0        t )
( display       blinkWhite   255      255      255      t )
drDefineStipple(
;( DisplayName   StippleName  Bitmap     )
( display       dots         ( ( 0 1 0 0 0 1 0 0 0 1 0 0 0 1 0 0  )
                                ( 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0  )
                                ( 0 0 0 1 0 0 0 1 0 0 0 1 0 0 0 1  )
                                ( 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0  ) ) )
( display       dots1        ( ( 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0  )
                                ( 0 0 1 0 0 0 1 0 0 0 1 0 0 0 1 0  )
                                ( 1 0 0 0 1 0 0 0 1 0 0 0 1 0 0 0  )
                                ( 1 0 0 0 1 0 0 0 1 0 0 0 1 0 0 0  ) ) )
( display       hLine        ( ( 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0  )
                                ( 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1  )
                                ( 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1  ) ) )
( display       vLine        ( ( 0 0 1 0 0 0 1 0 0 0 1 0 0 0 1 0  )
                                ( 0 0 1 0 0 0 1 0 0 0 1 0 0 0 1 0  ) ) )
( display       cross        ( ( 1 0 0 0 1 0 0 0 1 0 0 0 1 0 0 0  )
                                ( 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1  )
                                ( 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1  ) ) )
( display       grid         ( ( 0 0 0 1 0 0 0 1 0 0 0 1 0 0 0 1  )
( display       slash        ( ( 0 0 0 1 0 0 0 1 0 0 0 1 0 0 0 1  )
( display       backSlash    ( ( 1 0 0 0 1 0 0 0 1 0 0 0 1 0 0 0  )
                                ( 0 0 0 1 0 0 0 1 0 0 0 1 0 0 0 1  ) ) )
( display       hZigZag      ( ( 1 1 0 0 0 0 0 0 1 1 0 0 0 0 0 0  )
                                ( 0 0 1 0 0 0 0 0 0 0 1 0 0 0 0 0  )
                                ( 0 0 0 1 1 0 0 0 0 0 0 1 1 0 0 0  )
                                ( 0 0 0 0 0 1 0 0 0 0 0 0 0 1 0 0  )
                                ( 0 0 0 0 0 0 1 1 0 0 0 0 0 0 1 1  )
                                ( 1 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0  )
                                ( 0 1 1 0 0 0 0 0 0 1 1 0 0 0 0 0  )
                                ( 0 0 0 1 0 0 0 0 0 0 0 1 0 0 0 0  )
                                ( 0 0 0 0 1 1 0 0 0 0 0 0 1 1 0 0  )
                                ( 0 0 0 0 0 0 1 0 0 0 0 0 0 0 1 0  )
                                ( 1 0 0 0 0 0 0 1 1 0 0 0 0 0 0 1  )
                                ( 0 1 0 0 0 0 0 0 0 1 0 0 0 0 0 0  )
                                ( 0 0 1 1 0 0 0 0 0 0 1 1 0 0 0 0  )
                                ( 0 0 0 0 1 0 0 0 0 0 0 0 1 0 0 0  )
                                ( 0 0 0 0 0 1 1 0 0 0 0 0 0 1 1 0  )
                                ( 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 1  ) ) )
( display       vZigZag      ( ( 1 0 0 0 0 1 0 0 0 0 1 0 0 0 0 0  )
                                ( 1 0 0 0 0 0 1 0 0 0 0 1 0 0 0 0  )
                                ( 0 1 0 0 0 0 1 0 0 0 0 0 1 0 0 0  )
                                ( 0 0 1 0 0 0 0 1 0 0 0 0 1 0 0 0  )
                                ( 0 0 1 0 0 0 0 0 1 0 0 0 0 1 0 0  )
                                ( 0 0 0 1 0 0 0 0 1 0 0 0 0 0 1 0  )
                                ( 0 0 0 0 1 0 0 0 0 1 0 0 0 0 1 0  )
                                ( 0 0 0 0 1 0 0 0 0 0 1 0 0 0 0 1  )
                                ( 0 0 0 0 1 0 0 0 0 0 1 0 0 0 0 1  ) ) )
( display       hCurb        ( ( 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0  )
                                ( 0 0 0 1 1 1 1 1 0 0 0 1 1 1 1 1  )
                                ( 1 1 1 1 0 0 0 1 1 1 1 1 0 0 0 1  )
( display       vCurb        ( ( 0 0 0 0 0 1 0 0 0 0 0 0 0 1 0 0  )
                                ( 0 0 1 1 1 1 0 0 0 0 1 1 1 1 0 0  )
                                ( 0 0 1 1 1 1 0 0 0 0 1 1 1 1 0 0  ) ) )
( display       brick        ( ( 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1  )
                                ( 0 0 0 0 0 0 1 0 0 0 0 0 0 0 1 0  ) ) )
( display       dagger       ( ( 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0  )
                                ( 1 1 1 1 1 0 0 0 1 1 1 1 1 0 0 0  )
                                ( 0 0 0 0 0 1 0 0 0 0 0 0 0 1 0 0  ) ) )
( display       triangle     ( ( 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0  )
                                ( 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0  )
                                ( 0 0 0 1 0 1 0 0 0 0 0 0 0 0 0 0  )
                                ( 0 0 1 0 0 0 1 0 0 0 0 0 0 0 0 0  )
                                ( 0 1 0 0 0 0 0 1 0 0 0 0 0 0 0 0  )
                                ( 1 1 1 1 1 1 1 1 1 0 0 0 0 0 0 0  )
                                ( 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0  )
                                ( 0 0 0 0 0 0 0 0 0 0 1 0 1 0 0 0  )
                                ( 0 0 0 0 0 0 0 0 0 1 0 0 0 1 0 0  )
                                ( 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1 0  )
                                ( 0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 1  )
( display       x            ( ( 1 0 0 0 1 0 0 0 1 0 0 0 1 0 0 0  )
( display       dot1         ( ( 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0  )
( display       dot2         ( ( 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0  )
                                ( 0 0 0 1 1 1 0 0 0 0 0 0 0 0 0 0  )
( display       dot3         ( ( 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0  )
( display       dot4         ( ( 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0  )
( display       dot5         ( ( 0 1 0 0 0 0 0 0 0 1 0 0 0 0 0 0  )
( display       stipple_k0   ( ( 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1  )
                                ( 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0  )
                                ( 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0  )
                                ( 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0  )
                                ( 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0  )
                                ( 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0  )
                                ( 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0  )
( display       stipple_k1   ( ( 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0  )
                                ( 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0  )
                                ( 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0  )
                                ( 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0  )
                                ( 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0  )
                                ( 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0  )
                                ( 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0  )
( display       stipple_k2   ( ( 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1  )
                                ( 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0  ) ) )
( display       stipple_k3   ( ( 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0  )
                                ( 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1  ) ) )
( display       stipple_k4   ( ( 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0  )
                                ( 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0  ) ) )
( display       stipple_k5   ( ( 1 1 0 0 1 1 0 0 1 1 0 0 1 1 0 0  )
                                ( 0 0 1 1 0 0 1 1 0 0 1 1 0 0 1 1  )
                                ( 0 0 1 1 0 0 1 1 0 0 1 1 0 0 1 1  ) ) )
( display       stipple_k6   ( ( 0 0 1 1 0 0 1 1 0 0 1 1 0 0 1 1  )
                                ( 1 1 0 0 1 1 0 0 1 1 0 0 1 1 0 0  ) ) )
( display       stipple_k7   ( ( 1 1 1 1 0 0 0 0 1 1 1 1 0 0 0 0  )
                                ( 0 0 0 0 1 1 1 1 0 0 0 0 1 1 1 1  )
                                ( 0 0 0 0 1 1 1 1 0 0 0 0 1 1 1 1  ) ) )
( display       stipple_k8   ( ( 0 1 0 0 0 1 0 0 0 1 0 0 0 1 0 0  )
( display       stipple_k9   ( ( 0 0 0 1 0 0 0 1 0 0 0 1 0 0 0 1  )
( display       stipple_k10  ( ( 1 0 0 1 1 0 0 0 1 0 0 1 1 0 0 0  )
                                ( 0 1 0 0 1 1 0 0 0 1 0 0 1 1 0 0  )
                                ( 0 0 1 0 0 1 1 0 0 0 1 0 0 1 1 0  )
                                ( 0 0 0 1 0 0 1 1 0 0 0 1 0 0 1 1  )
                                ( 0 0 0 1 0 0 1 1 0 0 0 1 0 0 1 1  ) ) )
( display       stipple_k11  ( ( 1 0 0 0 0 0 1 1 1 0 0 0 0 0 1 1  )
                                ( 1 0 0 0 0 1 0 0 1 0 0 0 0 1 0 0  )
                                ( 1 1 1 0 0 0 0 0 1 1 1 0 0 0 0 0  )
                                ( 0 0 1 0 0 0 0 1 0 0 1 0 0 0 0 1  )
                                ( 0 0 1 1 1 0 0 0 0 0 1 1 1 0 0 0  )
                                ( 0 1 0 0 1 0 0 0 0 1 0 0 1 0 0 0  )
                                ( 0 0 0 0 1 1 1 0 0 0 0 0 1 1 1 0  )
                                ( 0 0 0 1 0 0 1 0 0 0 0 1 0 0 1 0  )
                                ( 0 0 0 1 0 0 1 0 0 0 0 1 0 0 1 0  ) ) )
( display       stipple_k12  ( ( 1 0 0 1 1 0 0 0 1 0 0 1 1 0 0 0  )
                                ( 1 0 0 0 1 0 0 1 1 0 0 0 1 0 0 1  )
                                ( 0 1 1 0 0 0 1 0 0 1 1 0 0 0 1 0  )
                                ( 0 0 1 0 0 0 0 1 0 0 1 0 0 0 0 1  ) ) )
( display       stipple_k13  ( ( 0 0 1 0 0 0 1 0 0 0 1 0 0 0 1 0  )
                                ( 0 1 0 0 0 1 0 0 0 1 0 0 0 1 0 0  ) ) )
( display       stipple_k14  ( ( 0 1 0 0 0 1 0 0 0 1 0 0 0 1 0 0  )
( display       stipple_k15  ( ( 0 0 0 0 0 0 1 0 0 0 0 0 0 0 1 0  )
( display       stipple_k16  ( ( 1 0 0 0 0 0 1 1 1 0 0 0 0 0 1 1  )
                                ( 1 1 1 1 0 0 0 0 0 1 1 1 0 0 0 0  )
                                ( 0 0 1 1 1 1 0 0 0 0 0 1 1 1 0 0  )
                                ( 0 0 0 0 1 1 1 1 0 0 0 0 0 1 1 1  )
( display       stipple_k17  ( ( 0 0 0 1 1 0 0 0 0 0 0 1 1 0 0 0  )
                                ( 0 0 1 0 0 0 0 0 0 0 1 0 0 0 0 0  ) ) )
( display       stipple_k18  ( ( 0 0 0 0 0 0 1 1 1 1 0 0 0 0 0 0  )
                                ( 0 0 0 0 0 1 1 0 0 1 1 0 0 0 0 0  )
                                ( 0 0 0 0 1 1 0 0 0 0 1 1 0 0 0 0  )
                                ( 0 0 1 1 0 0 0 0 0 0 0 0 1 1 0 0  )
                                ( 0 1 1 0 0 0 0 0 0 0 0 0 0 1 1 0  )
                                ( 1 1 0 0 0 0 0 0 0 0 0 0 0 0 1 1  )
                                ( 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1  )
                                ( 0 0 0 0 0 0 1 1 1 1 0 0 0 0 0 0  ) ) )
( display       stipple_k19  ( ( 1 1 1 1 0 0 0 0 1 1 1 1  )
                                ( 0 0 0 0 0 0 0 0 0 0 0 0  )
                                ( 1 1 1 1 0 0 0 0 1 1 1 1  ) ) )
( display       stipple_k20  ( ( 0 0 0 0 0 1 1 0 0 0 0 0  )
                                ( 1 1 1 1 1 1 1 1 1 1 1 1  )
                                ( 0 0 0 0 0 1 1 0 0 0 0 0  ) ) )
( display       stipple_k21  ( ( 0 0 1 1 0 0 0 1 0 0 1 1 0 0 0 1  )
                                ( 1 1 0 0 0 1 0 0 1 1 0 0 0 1 0 0  )
                                ( 1 0 0 1 1 0 0 0 1 0 0 1 1 0 0 0  ) ) )
( display       stipple_k22  ( ( 0 0 0 1 0 0 1 0 0 0 0 1 0 0 1 0  )
                                ( 0 0 0 1 1 1 0 0 0 0 0 1 1 1 0 0  )
                                ( 0 1 1 1 0 0 0 0 0 1 1 1 0 0 0 0  )
                                ( 1 1 0 0 0 0 0 1 1 1 0 0 0 0 0 1  )
                                ( 0 0 0 0 0 1 1 1 0 0 0 0 0 1 1 1  )
                                ( 0 0 0 0 0 1 1 1 0 0 0 0 0 1 1 1  ) ) )
( display       stipple_k23  ( ( 0 0 1 0 0 0 0 1 0 0 1 0 0 0 0 1  )
( display       stipple_k24  ( ( 0 0 0 0 0 1 0 0 0 0 0 0 0 1 0 0  )
( display       stipple_k25  ( ( 0 0 0 0 0 0 1 0 0 0 0 0 0 0 1 0  )
                                ( 1 0 0 0 0 0 1 1 1 0 0 0 0 0 1 1  ) ) )
( display       stipple_k26  ( ( 0 0 1 0 0 0 0 0 0 0 1 0 0 0 0 0  )
                                ( 0 0 0 1 1 0 0 0 0 0 0 1 1 0 0 0  ) ) )
drDefineLineStyle(
;( DisplayName   LineStyle    Size       Pattern   )
( display       solid        1          (1 1 1 ) )
( display       dashed       1          (1 1 1 1 0 0 ) )
( display       dots         1          (1 0 0 ) )
( display       dashDot      1          (1 1 1 0 0 1 0 0 ) )
( display       shortDash    1          (1 1 0 0 ) )
( display       doubleDash   1          (1 1 1 1 0 0 1 1 0 0 ) )
( display       hidden       1          (1 0 0 0 ) )
( display       thickLine    3          (1 1 1 ) )
( display       thickLine2   2          (1 1 1 ) )
drDefinePacket(
;( DisplayName  PacketName           Stipple    LineStyle  Fill       Outline    [FillStyle])
( display      border               blank      solid      tan        tan        outline   )
( display      res_nw               X          dashDot    pink       pink       X         )
( display      esd2                 blank      thickLine2 gold       gold       X         )
( display      y8                   blank      solid      blue       blue       outline   )
( display      background           solid      solid      black      black      solid     )
( display      diftxt               brick      solid      yellow     yellow     outlineStipple)
( display      nll                  hCurb      solid      winColor1  winColor1  outlineStipple)
( display      esd1                 blank      thickLine2 cadetBlue  cadetBlue  X         )
( display      y9                   blank      solid      silver     silver     outline   )
( display      m1b                  blank      solid      yellow     yellow     outline   )
( display      nan                  blank      thickLine  orange     orange     X         )
( display      mim                  blank      thickLine2 magenta    magenta    X         )
( display      pin                  solid      solid      red        red        solid     )
( display      hardFence            blank      solid      red        red        outline   )
( display      m1txt                blank      solid      cyan       cyan       X         )
( display      designFlow3          dots       solid      cyan       cyan       outlineStipple)
( display      Unrouted1            blank      dashed     brown      brown      outline   )
( display      RowLbl               blank      solid      cyan       cyan       outline   )
( display      edgeLayerPin         blank      solid      yellow     yellow     outline   )
( display      instance             blank      solid      red        red        outline   )
( display      snap                 blank      solid      yellow     yellow     outline   )
( display      pinAnt               blank      solid      red        red        outline   )
( display      designFlow2          dots       solid      magenta    magenta    outlineStipple)
( display      m2txt                blank      solid      orange     orange     X         )
( display      Unrouted2            blank      dashed     red        red        outline   )
( display      hilite               blank      solid      white      white      outline   )
( display      rp94                 blank      solid      yellow     yellow     solid     )
( display      designFlow1          dots       solid      purple     purple     outlineStipple)
( display      grid1                blank      solid      white      white      outline   )
( display      m5txt                blank      solid      cream      cream      X         )
( display      Unrouted3            blank      dashed     pink       pink       outline   )
( display      m3b                  blank      solid      yellow     yellow     outline   )
( display      select               blank      solid      tan        tan        outline   )
( display      v1                   X          solid      orange     orange     X         )
( display      Unrouted4            blank      dashed     orange     orange     outline   )
( display      wireLbl              solid      solid      cadetBlue  cadetBlue  solid     )
( display      m6txt                blank      solid      silver     silver     X         )
( display      subd                 blank      dashed     white      blue       outline   )
( display      htnwl                stipple_k4 solid      brown      brown      outlineStipple)
( display      v2                   blank      solid      magenta    magenta    X         )
( display      designFlow7          dots       solid      yellow     yellow     outlineStipple)
( display      align                blank      solid      tan        tan        outline   )
( display      tim                  blank      solid      magenta    magenta    outline   )
( display      pa                   blank      dashed     blinkYellow blinkYellow outlineStipple)
( display      alpa                 blank      dashed     brown      brown     outlineStipple)
( display      Unrouted5            blank      dashed     green      green      outline   )
( display      unset                blank      solid      forest     forest     outline   )
( display      sn                   stipple_k0 solid      green      green      outlineStipple)
( display      vtnh                 blank      thickLine2 orange     orange     outline   )
( display      rp91                 blank      solid      yellow     yellow     solid     )
( display      designFlow6          dots       solid      orange     orange     outlineStipple)
( display      m1                   dots       solid      cyan       cyan       outlineStipple)
( display      v3                   blank      solid      cream      cream      X         )
( display      cg                   stipple_k4 solid      lime       lime       outlineStipple)
( display      Unrouted6            blank      dashed     blue       blue       outline   )
( display      m5b                  blank      solid      yellow     yellow     solid     )
( display      rp90                 blank      solid      yellow     yellow     solid     )
( display      resist               blank      solid      cyan       cyan       outline   )
( display      hrpdmy               stipple_k11 thickLine2 pink       magenta    outlineStipple)
( display      exclu                blank      dashDot    cyan       cyan       X         )
( display      m2                   stipple_k15 solid      orange     orange     outlineStipple)
( display      v4                   blank      solid      cyan       cyan       X         )
( display      sab                  dot5       thickLine2 tan        tan        outlineStipple)
( display      designFlow5          dots       solid      green      green      outlineStipple)
( display      capbp                blank      thickLine  magenta    magenta    X         )
( display      Unrouted7            blank      dashed     purple     purple     outline   )
( display      CannotoccupyBnd      blank      solid      red        red        outline   )
( display      sp                   stipple_k1 solid      magenta    magenta    outlineStipple)
( display      rp93                 blank      solid      yellow     yellow     solid     )
( display      designFlow4          dots       solid      forest     forest     outlineStipple)
( display      softFence            blank      solid      yellow     yellow     outline   )
( display      mvn                  blank      thickLine2 gold       gold       X         )
( display      m3                   stipple_k24 solid      purple     purple     outlineStipple)
( display      v5                   blank      solid      gold       gold       X         )
( display      p2bk                 blank      solid      yellow     yellow     solid     )
( display      rp92                 blank      solid      yellow     yellow     solid     )
( display      m4                   stipple_k0 solid      pink       pink       outlineStipple)
( display      changedLayerTl1      blank      solid      yellow     yellow     outline   )
( display      vtph                 blank      thickLine2 cadetBlue  cadetBlue  outline   )
( display      prBoundaryLbl        blank      solid      purple     purple     outline   )
( display      dnw                  stipple_k4 solid      brown      brown      outlineStipple)
( display      hvpf                 blank      solid      yellow     yellow     solid     )
( display      mvp                  blank      thickLine2 magenta    magenta    X         )
( display      m5                   stipple_k1 solid      cream      cream      outlineStipple)
( display      ht                   blank      solid      yellow     yellow     solid     )
( display      changedLayerTl0      blank      solid      red        red        outline   )
( display      spike                blank      solid      purple     purple     outline   )
( display      weltxt               brick      solid      orange     orange     outlineStipple)
( display      text                 blank      solid      white      white      outline   )
( display      ddd                  stipple_k15 solid      tan        tan        outlineStipple)
( display      Row                  blank      solid      cyan       cyan       outline   )
( display      m6                   dot5       solid      silver     silver     outlineStipple)
( display      m3txt                blank      solid      purple     purple     X         )
( display      wire                 solid      solid      cadetBlue  cadetBlue  solid     )
( display      polytxt              brick      solid      cyan       cyan       outlineStipple)
( display      Cannotoccupy         X          solid      red        red        X         )
( display      GroupLbl             blank      solid      green      green      outline   )
( display      psub                 blank      doubleDash violet     violet     outline   )
( display      axis                 blank      solid      white      white      outline   )
( display      dmpnp                blank      solid      yellow     yellow     solid     )
( display      ppaa                 backSlash  solid      yellow     yellow     outlineStipple)
( display      opcba                blank      solid      yellow     yellow     solid     )
( display      edgeLayer            blank      solid      winColor5  winColor5  outline   )
( display      annotate2            blank      solid      lime       lime       outline   )
( display      ono                  blank      thickLine2 yellow     yellow     outline   )
( display      indmy                blank      thickLine  green      green      X         )
( display      res_aa               X          dashed     pink       pink       X         )
( display      rgm                  blank      solid      yellow     yellow     solid     )
( display      annotate3            blank      solid      cyan       cyan       outline   )
( display      deviceAnt            blank      solid      yellow     yellow     outline   )
( display      Unrouted             blank      dashed     winColor5  winColor5  outline   )
( display      stretch              blank      solid      yellow     yellow     outline   )
( display      border               blank      thickLine2 green      green      outline   )
( display      plh                  vLine      solid      winColor3  winColor3  outlineStipple)
( display      annotate1            blank      solid      pink       pink       outline   )
( display      esdio                blank      thickLine2 white      white      X         )
( display      Group                dots       solid      green      green      outlineStipple)
( display      deviceLbl            blank      solid      green      green      outline   )
( display      bnp                  stipple_k18 solid      lime       lime       outlineStipple)
( display      annotate6            blank      solid      silver     silver     outline   )
( display      pwh                  blank      solid      yellow     yellow     solid     )
( display      Canplace             blank      solid      cyan       cyan       outline   )
( display      m2b                  blank      solid      yellow     yellow     outline   )
( display      ct                   X          solid      lime       lime       X         )
( display      annotate7            blank      solid      red        red        outline   )
( display      hrp                  blank      dashDot    magenta    magenta    X         )
( display      annotate4            blank      solid      yellow     yellow     outline   )
( display      device1              solid      solid      green      green      solid     )
( display      markerWarn           X          solid      blinkYellow blinkYellow X         )
( display      text2                solid      solid      white      white      solid     )
( display      l0                   dot4       solid      yellow     yellow     outlineStipple)
( display      pll                  vCurb      solid      winColor1  winColor1  outlineStipple)
( display      designFlow           dots       solid      blue       blue       outlineStipple)
( display      hilite1              blank      solid      magenta    magenta    outline   )
( display      device               blank      solid      green      green      outline   )
( display      prBoundary           blank      solid      purple     purple     outline   )
( display      dcty                 blank      solid      yellow     yellow     solid     )
( display      annotate5            blank      solid      white      white      outline   )
( display      btxt                 blank      solid      silver     silver     outline   )
( display      text1                blank      dashed     white      white      outline   )
( display      npaa                 backSlash  solid      red        red        outlineStipple)
( display      gp                   cross      solid      navy       navy       outlineStipple)
( display      markerErr            X          solid      blinkWhite blinkWhite X         )
( display      unknown              blank      solid      yellow     yellow     outline   )
( display      m4b                  blank      solid      yellow     yellow     outline   )
( display      pwl                  blank      solid      yellow     yellow     solid     )
( display      annotate             blank      solid      orange     orange     outline   )
( display      hilite3              blank      solid      cyan       cyan       outline   )
( display      pinLbl               blank      solid      red        red        outline   )
( display      device2              blank      dashed     green      green      outline   )
( display      grid                 blank      solid      slate      slate      outline   )
( display      nw                   stipple_k4 solid      forest     forest     outlineStipple)
( display      hilite2              blank      solid      tan        tan        outline   )
( display      annotate8            blank      solid      tan        tan        outline   )
( display      tn                   blank      doubleDash green      green      X         )
( display      hilite5              blank      solid      lime       lime       outline   )
( display      annotate9            blank      solid      green      green      outline   )
( display      tow                  blank      thickLine2 purple     purple     outline   )
( display      opcbm                blank      solid      yellow     yellow     solid     )
( display      dg                   X          thickLine2 tan        tan        X         )
( display      gt                   cross      solid      blue       blue       outlineStipple)
( display      hilite4              blank      solid      orange     orange     outline   )
( display      y0                   blank      solid      yellow     yellow     outline   )
( display      mimdmy               stipple_k22 thickLine2 tan        cream      outlineStipple)
( display      m6b                  blank      solid      yellow     yellow     solid     )
( display      supply               blank      solid      lime       lime       outline   )
( display      pw                   stipple_k8 solid      navy       navy       outlineStipple)
( display      hilite7              blank      solid      cream      cream      outline   )
( display      y1                   blank      solid      red        red        outline   )
( display      tp                   blank      doubleDash cadetBlue  cadetBlue  X         )
( display      defaultPacket        X          dashed     tan        tan        X         )
( display      Unrouted8            blank      dashed     gold       gold       outline   )
( display      hilite6              blank      solid      orange     orange     outline   )
( display      y2                   blank      solid      green      green      outline   )
( display      dstr                 blank      solid      yellow     yellow     solid     )
( display      Unrouted9            blank      dashed     silver     silver     outline   )
( display      hilite9              blank      solid      pink       pink       outline   )
( display      m4txt                blank      solid      pink       pink       X         )
( display      y3                   blank      solid      magenta    magenta    outline   )
( display      prBoundaryBnd        blank      solid      cyan       cyan       outline   )
( display      subtxt               brick      solid      forest     forest     outlineStipple)
( display      p2                   grid       solid      cadetBlue  cadetBlue  outlineStipple)
( display      hilite8              blank      solid      magenta    magenta    outline   )
( display      y4                   blank      solid      cyan       cyan       outline   )
( display      opcbp                blank      solid      yellow     yellow     solid     )
( display      designFlow9          dots       solid      red        red        outlineStipple)
( display      nlh                  hLine      solid      winColor3  winColor3  outlineStipple)
( display      y5                   blank      solid      purple     purple     outline   )
( display      res_p1               X          dashed     cadetBlue  cadetBlue  X         )
( display      ctxt                 blank      solid      yellow     yellow     solid     )
( display      hiz                  blank      solid      orange     orange     outline   )
( display      drive                blank      solid      blue       blue       outline   )
( display      wireFlt              blank      dashed     red        red        outline   )
( display      instanceLbl          blank      solid      gold       gold       outline   )
( display      ttxt                 blank      solid      yellow     yellow     outline   )
( display      designFlow8          dots       solid      brown      brown      outlineStipple)
( display      pdc                  blank      solid      yellow     yellow     solid     )
( display      y6                   blank      solid      orange     orange     outline   )
( display      aa                   backSlash  solid      maroon     maroon     outlineStipple)
( display      nwh                  blank      solid      yellow     yellow     solid     )
( display      om                   solid      solid      orange     orange     X         )
( display      y7                   blank      solid      gold       gold       outline   )
( display      m7                   dots       solid      blue       blue       outline   )
( display      m8                   stipple_k0 solid      brown      brown      outline   )
( display      v6                   blank      solid      gray       gray       outline   )
( display      v7                   blank      solid      green      green      outline   )
发表于 2013-5-30 09:02:37 | 显示全部楼层
display文件与这个没有关系,只是显示。
能不能不要用TF,就用默认的TF好了
我们工作通常都用默认的,这样做是最安全的。
发表于 2013-5-30 09:10:14 | 显示全部楼层
在创建新库的时候,SMIC在工艺库子目录下的tf文件是不需要被手动load进来的。正确的做法是把新建的用户库attach到SMIC提供的工艺库上。那个工艺库带有所有的层定义和显示信息。当用户自己需要特定的显示设置时,才需要定制一个display.drf文件,加载进来以达到自己需要的效果。
这里出的警告信息基本上是因为重复定义了层,所以手动装载tf文件的时候不成功。我猜是你新建的库自动attach到了一个缺省设置的工艺库上。在IC5141的CIW窗口里面用Tools->Technology File Manager ...->Attach ...菜单就可以把用户的库改动设置到自己想要的工艺库。
只有大概20年以前的IC4.3版本才需要手动把tf文件加载进来,现在已经完全不需要这样做了。虽然这样做在不冲突的情况下也是可以的,但是何必呢。
 楼主| 发表于 2013-5-30 09:19:57 | 显示全部楼层
回复 7# xjg@hmes
   没有默认的tf,如果不加tf的话,全部都是L+数字层
 楼主| 发表于 2013-5-30 09:22:32 | 显示全部楼层
回复 8# amodaman
   关键是smic和arm都没有提供工艺库,只有gds文件
GMT+8, 2025-9-17 03:22 , Processed in 0.032987 second(s), 5 queries , Gzip On, Redis On.
