楼主: sailor0321
再发一个HFSS V15 X64的crack,已稳定测试多天,正常运算
发表于 2014-3-27 19:28:22 | 显示全部楼层
有没有linux的和谐啊?
发表于 2014-4-4 00:04:24 | 显示全部楼层
WO XIAN 试试另外一个。。。mark
发表于 2014-4-5 00:19:46 | 显示全部楼层
HFSS 15.0.3 Service Pack Updates
Enhancement: HFSS 15.0.3 introduces a new 3D electrical layout interface. To utilize it,
             download and install ANSYS Designer 8.0.3.  Then, launch ANSYS Designer, and
             insert an EM design type into the Designer desktop (Project > Insert EM Design...)
DE54625: HFSS will now reanalyze the last pass using the copied mesh for geometrically-
         equivalent design variations when the user selects the "Copy geometrically equivalent
         meshes" Optimetrics' option.
DE56281: Radiated field computation will no longer be affected by enabling/disabling differential
         pairs.
DE53254: The calculation of near fields in the post processor are now accurate for designs with
         metallic IE regions.
DE57316: The HPC for multiprocessing option will no longer adversely affect matrix assembly
         performance during a simulation relative to standard MP.
DE51696: An appropriate warning message now appears if a project is opened that contains designs
         for which licenses are not available.  Closing the project without saving now does
         not cause any loss of data.
DE57722: Optimizations that utilize the MATLAB optimizer now gracefully abort when a variation
         fails to solve.
DE51920: The curved object visualization setting works correctly for all models irrespective of
         the "face by face" faceting option (see Tools/Options/Modeler Options/Display).
US66895: Licensing changes
            - HFSS will now check out the hfss_gui license when users insert an HFSS-IE design
              or open an existing HFSS-IE design.
            - HFSS will now attempt to check out the "designer_desktop" license if the
              "hfss_desktop" license is unavailable.
            - Designer will now attempt to check out the "hfss_desktop" license if the
              "designer_desktop" license is unavailable.
发表于 2014-4-5 00:38:37 | 显示全部楼层
谢谢、、、真的搞定了。。。我开始就不行,原来是要安装patch
发表于 2014-4-8 20:17:51 | 显示全部楼层
非常感谢。
发表于 2014-4-12 15:03:21 | 显示全部楼层
安装了打不开,说一直连接什么server,怎么破呀?
发表于 2014-4-16 09:01:44 | 显示全部楼层
为何这个的破解总是有毒呢
发表于 2014-4-27 06:58:11 | 显示全部楼层
非常感谢楼主分享
发表于 2014-4-30 12:29:11 | 显示全部楼层
感谢楼主
发表于 2014-5-3 21:11:47 | 显示全部楼层
非常感谢~~~找了好久~
GMT+8, 2025-12-15 02:54 , Processed in 0.026301 second(s), 5 queries , Gzip On, Redis On.
