查看: 2747|回复: 7
Cadence仿真求助!
发表于 2013-5-17 23:24:44 | 显示全部楼层 |阅读模式
用cadence仿真时出现如下提示
2013-05-17 13:08:23的屏幕截图.png
请问这是什么原因?
发表于 2013-5-18 00:02:55 | 显示全部楼层
do you add spectre in path?
write spectre in terminal and press enter
 楼主| 发表于 2013-5-18 06:31:17 | 显示全部楼层
回复 2# mabas.masood
    please tell me the detail.
发表于 2013-5-18 11:01:41 | 显示全部楼层
1- install mmsim (for example mmsim121)
2- add this line in bashrc
   export PATH=<path of mmsim>/tools.lnx86/binPATH
   export PATH=<path of mmsim>/MMSIM121PATH
3- save and open another terminal
4 -finish
 楼主| 发表于 2013-5-18 13:03:15 | 显示全部楼层
i have install the Cadence Base,  i have the install package for Hotfix.  What should i do? Is mmsim and Hotfix the same?
发表于 2013-5-18 22:34:38 | 显示全部楼层
回复 5# 英特耐雄纳尔
   Cadence Base,  and its Hotfix do not include MMSIM.MMSIM is a indepentent package
发表于 2013-5-19 17:22:46 | 显示全部楼层
yes mmsim is simulator for cadence
发表于 2013-5-30 05:26:13 | 显示全部楼层
好在很多license已经包含了MMSIM的FEATURE,所以一般不需要单独和谐MMSIM了。
GMT+8, 2025-12-27 07:45 , Processed in 0.032822 second(s), 6 queries , Gzip On, Redis On.
