查看: 2124|回复: 0
[招聘] NO.86-Analog Design Engineer(Beijing)
发表于 2013-5-17 16:10:01 | 显示全部楼层 |阅读模式
Position Duties and Responsibilities:
The analog design engineer is responsible for the whole analog circuit design flow, including following:
l         Involved in define functional and performance requirements of analog blocks by working with system/application engineers
l         Responsible for circuit topologies, schematic design and simulation
l         Perform layout supervision including layout floor plan and key points checklist, backend checks such as DRC and LVS, and post-simulation
l         Assist in developing test specifications and test plan and also responsible for analog block evaluation
l         Debugging and problem solving according to evaluation results
Candidate Qualifications:
Candidate must:
l         MS degree in Micro-Electronics or Electronic Engineering with over 2+ years analog design and verification experience or BS degree with over 4+ years
l         Solid knowledge of CMOS device, fabrication and classic analog circuit structure
l         Be familiar with the tools and environment for analog circuit design, such as Cadence VSE, ADE, spectra, VLE, mix-simulation tools and so on
l         Have one or more analog circuit design experience, such as ADCs, DACs, PLL, Amp, CMP, BGR and Regulator, POR, switched-capacitor circuit, IOBUFF, oscillator, charge pump circuit, display driver and so on.
l         Independent and self-motivated
l         Open mind and excellent communication skill
KT Human Resources Consulting Company (Shanghai) was established in 2001 in response to a need for a recruitment consultancy to be an active, contributing member of the semiconductor community, as opposed to simply a supplier to it.We provide professional search and talent acquisition in the Integrated Circuit、Electronic、Telecommunications industry of international corporations in Greater China. Our client list contains numerous international companies, many of them are long-term customers.
If you interested in the job, pls sent your cv to: hr@kthr.com, thanks!
“KT人才”微信也可查询职位啦!打开手机微信,搜号码“KTHR_COM”或查找微信公众帐号“KT人才”或扫描以上二维码即可添加,欢迎大家关注!(关注成功后输入”KT“即可查询职位!)
GMT+8, 2025-12-23 10:54 , Processed in 0.019246 second(s), 6 queries , Gzip On, Redis On.
