楼主: bigcathua
HFSS15 win32
发表于 2013-6-11 18:35:25 | 显示全部楼层
正在找破解呢,感谢。
发表于 2013-6-11 18:43:08 | 显示全部楼层
破解怎么用?
 楼主| 发表于 2013-6-26 18:43:15 | 显示全部楼层
覆盖安装目录下的同名文件。
发表于 2013-6-28 00:15:04 | 显示全部楼层
下载太费劲了,不过是好东西啊
发表于 2013-7-5 15:17:37 | 显示全部楼层
Ansys HFSS 15 Build 0.2 (x64)(2013)
Ansys HFSS 15 Build 0.2 (x64)(2013) | 910 MB
ANSYS HFSS software is the industry-standard simulation tool for three-D full-wave electromagnetic field simulation and is essential for the design of high-frequency and high-speed component design. HFSS offers multiple state-of the-art solver technologies based on either the proven finite element method or the well established integral equation method. You can Select the Appropriate solver for the type of Simulation Performing you are.
Electric field distribution with A Far field Radiation Pattern simulated by the New Finite antenna array capability in HFSS Engineers Rely on the accuracy, capacity, and performance of HFSS to Design High- speed components including on-chip embedded passives, IC packages, PCB interconnects and high-frequency components such as antennas, RF / microwave components and biomedical devices.
With HFSS, engineers can extract scattering matrix parameters (S, Y, Z parameters), visualize 3-D electromagnetic fields (near-and far-field) and generate ANSYS Full-Wave SPICE models that link to circuit simulations. Signal integrity engineers use HFSS within ESTABLISHED EDA Design Flows to evaluate Signal quality, Including Transmission Losses path, reflection loss Due to impedance mismatches, parasitic Coupling and Radiation.
Electric field in A cavity filter simulated by HFSS Each HFSS solver is based on A powerful, automated solution process where you are only required to specify geometry, material properties and the desired output.
From there HFSS will automatically generate an appropriate, efficient and accurate mesh for solving the problem using the selected solution technology. With HFSS the physics defines the mesh; the mesh does not define the physics.
Year: 2013
Version: 15 Build 0.2
Home: _http://www.ansys.com/
Download From Rapidgator
http://rapidgator.net/file/eba38 ... S.15.part1.rar.html
http://rapidgator.net/file/b3ef3 ... S.15.part2.rar.html
http://rapidgator.net/file/396a2 ... S.15.part3.rar.html
http://rapidgator.net/file/4d49e ... S.15.part4.rar.html
Download From Lumfile
http://lumfile.com/ndiylyf5ym3t/Ansoft.HFSS.15.part1.rar.html
http://lumfile.com/1goejkbavuvv/Ansoft.HFSS.15.part2.rar.html
http://lumfile.com/4wlztr9rgzkt/Ansoft.HFSS.15.part3.rar.html
http://lumfile.com/3irlh43creuk/Ansoft.HFSS.15.part4.rar.html
Download From Uploaded
http://uploaded.net/file/ihgpr46k/Ansoft.HFSS.15.part1.rar
http://uploaded.net/file/ia2gh2gk/Ansoft.HFSS.15.part2.rar
http://uploaded.net/file/byskbzjo/Ansoft.HFSS.15.part3.rar
http://uploaded.net/file/3q6h3a5l/Ansoft.HFSS.15.part4.rar
发表于 2013-7-18 05:52:35 | 显示全部楼层
樓主
少了一個 HFSS150Win32.part50
发表于 2013-7-18 11:12:03 | 显示全部楼层
破解不成功,还是看来还是得回头用HFSS13.0了
发表于 2013-7-22 11:27:32 | 显示全部楼层
回复 23# duandaodream
   你下载完了吗?破解成功没?
发表于 2013-8-22 09:02:37 | 显示全部楼层
感谢楼主分享 能激活吧?
发表于 2013-9-24 11:04:57 | 显示全部楼层
感谢楼主,急需破解。
GMT+8, 2025-12-14 23:11 , Processed in 0.453378 second(s), 5 queries , Gzip On, Redis On.
