查看: 3546|回复: 9
14-bit 2.2-MS/s Sigma–Delta ADC’s
发表于 2007-1-12 22:59:51 | 显示全部楼层 |阅读模式
Abstract—This paper presents the design and test results
of a fourth-order and sixth-order 14-bit 2.2-MS/s sigma–delta
analog-to-digital converter (ADC). The analog modulator and
digital decimator sections were implemented in a 0.35-mm
CMOS double-poly triple-level metal 3.3-V process. The design
objective for these ADC’s was to achieve 85 dB signal-to-noise
distortion ratio (SNDR) with less than 200 mW power dissipation.
Both modulators employ a cascade sigma–delta topology. The
fourth-order modulator consists of two cascaded second-order
stages which include 1-bit and 5-bit quantizers, respectively. The
sixth-order modulator has a 2-2-2 cascade structure and 1-bit
quantizer at the end of each stage. An oversampling ratio of 24
was selected to give the best SNDR and power consumption with
realizable gain-matching requirements between the analog and
digital sections.
Index Terms—Analog circuits, cascaded ADC architectures, hybrid
A/D converters, mash ADC architectures, sigma–delta modulators,
switched-capacitor circuits.
14bit 2.2M sigma delta ADCs.pdf
663.15 KB, 下载次数: 71 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2007-9-29 21:45:40 | 显示全部楼层
ding
发表于 2008-11-5 21:26:00 | 显示全部楼层
xiexie
发表于 2008-11-13 08:53:55 | 显示全部楼层
thanks a lot
发表于 2008-11-13 09:19:05 | 显示全部楼层
AAAAAAAAAAAAA
发表于 2008-11-13 22:06:28 | 显示全部楼层
多谢!
发表于 2008-11-13 22:11:19 | 显示全部楼层
谢谢分享。。。。
发表于 2008-11-16 15:43:32 | 显示全部楼层
ok~~~~~~
发表于 2011-7-10 20:09:52 | 显示全部楼层
thanks for sharing.........
发表于 2015-3-9 19:09:39 | 显示全部楼层
14-bit 2.2-MSs Sigma–Delta ADC’s
GMT+8, 2025-12-26 01:08 , Processed in 0.026405 second(s), 7 queries , Gzip On, Redis On.
