查看: 5355|回复: 16
一篇sigma-delta ADC的论文
发表于 2007-1-12 22:57:21 | 显示全部楼层 |阅读模式
Abstract
This paper presents a 1st order sigma-delta-modulator with μ-law coding for
dynamic compression of audio signals. The nonlinearity is located in the
feedback loop of the modulator and does not require an internal multibit A/D
converter. The modulator requires just one opamp, one comparator, and a
minimum of digital logic to generate a four bit feedback and to ensure a
stable operation. The μ-law-function for μ=255 is approximated by a
standardised piecewise linear 16 segment function which is commonly used
in telecommunication. The chip has been designed and fabricated in a
standard 1.5μm n-well CMOS process, occupies a die area of 2 mm2, and has
been successfully tested.
sigma delta adc.pdf
62.61 KB, 下载次数: 38 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2007-1-16 23:13:55 | 显示全部楼层
怎么都是e文啊,呵呵,不是很方便啊
发表于 2007-1-19 17:30:27 | 显示全部楼层
就4页,paper
发表于 2007-1-21 21:55:20 | 显示全部楼层
好东西啊谢谢
发表于 2007-10-7 06:43:31 | 显示全部楼层
看到它的Abstract裡寫用1.5um process...
有點納悶...是哪一年的journal/conference??
anyway, 仍然謝謝樓主的分享!!
发表于 2007-10-8 07:58:22 | 显示全部楼层
Thank you so much ! These days I am looking for thesis about Delta Sigma A to D converter everywhere. Do you have more information about Delta Sigma A to D? Thank you so much!
发表于 2007-11-26 15:09:19 | 显示全部楼层
sdfafasdfsa
发表于 2008-3-3 22:05:20 | 显示全部楼层
一般般啦
发表于 2008-3-6 13:26:40 | 显示全部楼层
谢谢了!
发表于 2008-3-7 10:37:56 | 显示全部楼层
楼主有没有关于dac方面的资料??
GMT+8, 2025-12-26 13:19 , Processed in 0.023286 second(s), 6 queries , Gzip On, Redis On.
