楼主: Amare.liu
Iscape04.21启动报libXext.so.6找不到
发表于 2015-9-17 16:06:34 | 显示全部楼层
Set your DISPLAY environment variable to a proper
value and manually start InstallScape by typing:
/home/leq263/cadence/installscape/iscape/bin/iscape.sh /home/leq263/Desktop/ic616/ic616/Hotfix_IC06.16.080_lnx86_1of6/IC06.16.080_lnx86.Hotfix/CDROM1:::/home/leq263/cadence/ic616
Initializing InstallScape using JVM at /home/leq263/cadence/installscape/iscape.04.23-s008/runtime/LNX86/bin/java. This might take some time...
Exception in thread "main" java.lang.UnsatisfiedLinkError: /home/leq263/cadence/installscape/iscape.04.23-s008/runtime/LNX86/lib/i386/xawt/libmawt.so: libXtst.so.6: cannot open shared object file: No such file or directory
        at java.lang.ClassLoader$NativeLibrary.load(Native Method)
        at java.lang.ClassLoader.loadLibrary0(Unknown Source)
        at java.lang.ClassLoader.loadLibrary(Unknown Source)
        at java.lang.Runtime.load0(Unknown Source)
        at java.lang.System.load(Unknown Source)
        at java.lang.Runtime.loadLibrary0(Unknown Source)
        at java.lang.System.loadLibrary(Unknown Source)
        at sun.security.action.LoadLibraryAction.run(Unknown Source)
        at java.security.AccessController.doPrivileged(Native Method)
        at java.awt.Toolkit.loadLibraries(Unknown Source)
        at java.awt.Toolkit.<clinit>(Unknown Source)
        at com.khanpur.installer.gui.InstallerUI.main(InstallerUI.java:107)
楼上的几种方法都试过了 还是不行 ,不知道哪里出来问题。请教下高手。。。
发表于 2015-11-6 22:02:07 | 显示全部楼层
感谢!搞定
发表于 2015-11-23 11:36:42 | 显示全部楼层
回复 3# mabas.masood
您好,我运行了
yum install libXext.i686指令
但是出现了
There are no enabled repos.
Run "yum repolist all" to see the repos you have.
You can enable repos with yum-config-manager --enable <repo>
我对这个repo不是很了解,而且repolist里面repo数量为0。不知您对这一问题是否有经验呢?谢谢
发表于 2015-12-8 17:39:45 | 显示全部楼层
回复 14# lvfeng308
层主在不,新手求问下是需要下载libXext.so.6这个下载安装就行了吗?
发表于 2015-12-9 18:20:41 | 显示全部楼层
回复 24# 墨小尘
   先设置好yum环境,然后用yum install glibc.i686 (差什么,就运行什么,进行安装操作)
发表于 2016-6-1 15:51:55 | 显示全部楼层
学习了!
发表于 2016-6-9 18:39:35 | 显示全部楼层
回复 6# wch0327
成功了,谢谢这位兄弟
发表于 2017-1-6 17:25:30 | 显示全部楼层
16l ok
发表于 2019-3-16 23:23:20 | 显示全部楼层
Thanks Homeboy, need below to work.
java_vm=Path_to_your_java_bin_folder
发表于 5 天前 | 显示全部楼层
ubuntu用
sudo dpkg --add-architecture i386
sudo apt update
sudo apt install libc6:i386 libxtst6:i386
sudo apt install libxi6:i386
GMT+8, 2025-9-12 03:14 , Processed in 0.017568 second(s), 4 queries , Gzip On, Redis On.
