17:08:10 (lmgrd) Please Note:
17:08:10 (lmgrd)
17:08:10 (lmgrd) This log is intended for debug purposes only.
17:08:10 (lmgrd) In order to capture accurate license
17:08:10 (lmgrd) usage data into an organized repository,
17:08:10 (lmgrd) please enable report logging. Use Macrovision's
17:08:10 (lmgrd) software license administration solution,
17:08:10 (lmgrd) FLEXnet Manager, to readily gain visibility
17:08:10 (lmgrd) into license usage data and to create
17:08:10 (lmgrd) insightful reports on critical information like
17:08:10 (lmgrd) license availability and usage. FLEXnet Manager
17:08:10 (lmgrd) can be fully automated to run these reports on
17:08:10 (lmgrd) schedule and can be used to track license
17:08:10 (lmgrd) servers and usage across a heterogeneous
17:08:10 (lmgrd) network of servers including Windows NT, Linux
17:08:10 (lmgrd) and UNIX. Contact Macrovision at
17:08:10 (lmgrd) www.macrovision.com for more details on how to
17:08:10 (lmgrd) obtain an evaluation copy of FLEXnet Manager
17:08:10 (lmgrd) for your enterprise.
17:08:10 (lmgrd)
17:08:10 (lmgrd) -----------------------------------------------
17:08:10 (lmgrd)
17:08:10 (lmgrd)
17:08:10 (lmgrd) Can't make directory /usr/tmp/.flexlm, errno: 2(No such file or directory)
17:08:10 (lmgrd) Can't open /usr/tmp/.flexlm/lmgrdl.3861, errno: 2
17:08:11 (lmgrd) Failed to open the TCP port number in the license.
17:08:11 (lmgrd) Can't remove statfile /usr/tmp/.flexlm/lmgrdl.3861: errno No such file or directory
他说不能Can't make directory /usr/tmp/.flexlm, 然后我新建了一个usr tmp flexlm 目录,并且把lmgrd那个文件也copy过来了,但还是不行
下面是我的目录
/home/lv/usr/tmp/.flexlm
lv@lv-virtual-machine:~/usr/tmp/.flexlm$ hostname
ubuntun
是不是把前面的/home/lv去掉就行了???
还有就是 17:08:11 (lmgrd) Failed to open the TCP port number in the license.
这个问题怎么解决啊
都弄了一下午了 还没装好
我用的是往虚拟机上装的 linux 是Ubuntun
希望以前装过的指教指教 不胜感激 |
