查看: 3686|回复: 9
synopsys tcad 2005 license
发表于 2013-5-4 04:08:33 | 显示全部楼层 |阅读模式
悬赏1000资产已解决
Need to run raphael
It must contain FEATURE RA
最佳答案
查看完整内容
Make sure you also check if you can run with legacy daemon for which you can definitvely use my crypter.
发表于 2013-5-4 04:08:34 | 显示全部楼层
发表于 2013-5-4 18:35:46 | 显示全部楼层
Is this working with snpslmd or another one ? ANY will not be accepted you need to provide with and HOSTID or similar ...
 楼主| 发表于 2013-5-5 01:54:33 | 显示全部楼层
The license generated with snpslmd doesn't work.
Said "FEATURE RA is required".
I checked synopsys.src for license generating. No such feature exists.
I believe some "ranxt" should be included in order to get the license to run the raphael.
Any idea?
回复 2# nathan97
发表于 2013-5-5 14:08:41 | 显示全部楼层
I think you still have software that uses tmald daemon. I made a crypter in the past for that  generates licenses for that one. Here is attached (tmaCP -h for instructions) along with a template file. Enjoy it.BTW: I tried raphael v2009 which uses snpslmd daemon and indeed you need RANXT but they are different feature.
Let me know if this solves your issues.
Tma2003.rar
195.99 KB, 下载次数: 22 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2013-5-6 05:49:37 | 显示全部楼层
 楼主| 发表于 2013-5-6 21:25:06 | 显示全部楼层
Thank you. It doesn't work.
I think you are right that raphael v2009 uses snpslmd daemon.
I would try to modify synopsys.src to include RANXT.
回复 6# nathan97
 楼主| 发表于 2013-5-6 21:27:12 | 显示全部楼层
Thanks for reply. I checked and no RANXT is included.
I would include it manually.
回复 7# azaki3k
 楼主| 发表于 2013-5-8 22:27:07 | 显示全部楼层
Thanks for reply. I found a similar discussion at http://bbs.eetop.cn/thread-349406-1-1.html
I tried to generate license by adding RA feature. It finally worked.
回复 10# nathan97
发表于 2013-5-8 23:13:21 | 显示全部楼层
I'm glad you did it ... enjoy the tool. So do I get the reward ?
GMT+8, 2025-12-19 00:45 , Processed in 0.027340 second(s), 8 queries , Gzip On, Redis On.
