查看: 6901|回复: 24
[资料] Understanding and Enhancing Sensitivity in Receivers for Wireless Applications
发表于 2013-4-30 10:42:53 | 显示全部楼层 |阅读模式
Figure 1. Homodyne (Zero-IF) Receiver ............................................................................................... 5
Figure 2. Dual-Conversion Superheterodyne Receiver ......................................................................... 6
Figure 3. User Time Slots for TDMA Example ...................................................................................... 8
Figure 4. Frequency Channels for FDMA Example............................................................................... 8
Figure 5. Modulation Schemes .......................................................................................................... 11
Figure 6. Constellation Diagram (I/Q Plot) .......................................................................................... 12
Figure 7. OQPSK State Diagram ....................................................................................................... 13
Figure 8. p/4-DQPSK State Diagram.................................................................................................. 14
Figure 9. 16QAM State Diagram........................................................................................................ 15
Figure 10. Receiver Components ........................................................................................................ 16
Figure 11. Mixer Driven by LO Signal .................................................................................................. 21
Figure 12. I/Q Detector........................................................................................................................ 24
Figure 13. Complex Source Connected to Complex Conjugate Load Termination ................................. 25
Figure 14. Thermal Noise Visualized as Signal Generators .................................................................. 26
Figure 15. Filter Response Equated to Brick-Wall Filter Response........................................................ 27
Figure 16. Two-Port Network Connection for Available Gain Definition.................................................. 29
Figure 17. Available Thermal Noise (Noise Temperature)..................................................................... 30
Figure 18. Noise Output Power Versus Source Temperature (Noise Temperature) ............................... 31
Figure 19. Available Thermal Noise (Noise Figure)............................................................................... 32
Figure 20. Noise Output Power Versus Source Temperature (Noise Figure) ......................................... 33
Figure 21. Noise Figure Quantifies Signal-to-Noise Ratio Degradation.................................................. 34
Figure 22. Amplifier With 10 dB of Gain and a 5-dB Noise Figure ......................................................... 36
Figure 23. Two-Stage Network (Cascaded Noise Temperature)............................................................ 38
Figure 24. Cascaded Receiver System (Cascaded Noise Temperature) ............................................... 39
Figure 25. Two-Stage Network (Cascaded Noise Figure) ..................................................................... 40
Figure 26. Cascaded Receiver System (Cascaded Noise Figure) ......................................................... 41
Figure 27. Lossy Two-Port (Noise Figure) ............................................................................................ 42
Figure 28. Mixer Conversion Noise...................................................................................................... 44
Figure 29. Single-Sideband Mixer Noise Model .................................................................................... 45
Figure 30. Double-Sideband Mixer Noise Model................................................................................... 46
Figure 31. Dual-Conversion Receiver With Associated Noise and Signal Levels ................................... 47
Figure 32. Dual-Conversion Receiver and Carrier-to-Noise Ratio.......................................................... 48
Figure 33. Probability of Error Versus Carrier-to-Noise Ratio ................................................................ 49
Figure 34. Double-Sideband Phase Noise Plot of a Signal Source........................................................ 50
Figure 35. Conversion Limitations Due to Phase Noise ........................................................................ 51
Figure 36. Ideal Two-Port Pout Versus Pin Characteristic ....................................................................... 52
Figure 37. Two-Port Gain Versus Input Power Level ............................................................................ 53
Figure 38. Receiver Circuits and Intermodulation Distortion.................................................................. 54
Figure 39. Output Power Pout for One Fundamental Frequency Signal Versus Input Power Pin............... 56
Figure 40. Fundamental Po
and Third-Order Distortion P
d Output Powers Versus Input Power Pin.......... 57
Figure 41. Typical Output Spectrum of a Two-Port Receiver Network ................................................... 59
Figure 42. Cascaded Receiver Networks ............................................................................................. 59
Figure 43. Dynamic Range.................................................................................................................. 61
Figure 44. Receiver Blocking............................................................................................................... 62
Figure 45. Spur-Free Dynamic Range.................................................................................................. 63
Figure 46. High-Side Injection Example ............................................................................................... 65
Figure 47. Half-IF Spur........................................................................................................................ 66
Figure 48. Frequency Spectrum for RF and LO Frequencies .............................................................. 66
Figure 49. Receiver Block Diagram ..................................................................................................... 68
Figure 50. Six-Stage Network Combined Into Three-Stage Network ....................................................68
Figure 51. New Combined Receiver .................................................................................................... 69
资料对理解接收机还是比较有帮助的,属于基础类。
Sensitivity in Receivers for Wireless.pdf
544.6 KB, 下载次数: 852 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2013-4-30 11:15:49 | 显示全部楼层
清华微所PLL大牛李宇根教授2013讲义
发表于 2013-4-30 12:43:04 | 显示全部楼层
讲义?书?搞不清楚了
发表于 2013-4-30 16:36:23 | 显示全部楼层
这到底是什么东东啊
发表于 2013-5-1 04:03:04 | 显示全部楼层
貌似不大得文档,比较基础
发表于 2013-9-5 16:18:42 | 显示全部楼层
下载下来看看
发表于 2013-9-12 19:43:45 | 显示全部楼层
TI的文档
发表于 2013-12-16 18:18:12 | 显示全部楼层
感谢楼主分享!!!!
发表于 2016-5-5 17:52:18 | 显示全部楼层
thanks!
发表于 2016-9-11 06:20:15 | 显示全部楼层
感謝大大分享,謝謝你。
GMT+8, 2025-12-31 02:53 , Processed in 0.039350 second(s), 7 queries , Gzip On, Redis On.
