查看: 4391|回复: 4
ic5141突然不能启动了哪位大侠帮帮忙
发表于 2013-4-17 11:14:01 | 显示全部楼层 |阅读模式
我装好ic5141后本来能启动的,原理图和spectre都能用的,但是突然就不能用了,哪位大侠帮帮忙看看呀
\o Program:        @(#)$CDS: icfb.exe version 5.1.0 09/22/2009 01:17 (cicln04) $
\o Hierarchy:        /opt/edatools/cadence/cdba/IC05.10/tools.lnx86/dfII/
\o Sub version:        sub-version 5.10.41.500.6.139 (32-bit addresses)
\o Host name (type):    XXXX (i686)
\o Operating system:    Linux 2.6.18-164.el5PAE #1 SMP Thu Sep 3 04:10:44 EDT 2009
\o X display name:    :0.0
\o X server:        The X.Org Foundation
\o Depth of Visual (Root):    24 (24)
\o Number of Planes Used:    24
\o X version:        11.0 (vendor release 70101000)
\o Window Manager:    other
\o User Name:       XXX
\o Working Directory:    XXXXX
\o Process Id:        5392
\o
\w *WARNING* Too few cells in color pool.. setting to 12
\o COPYRIGHT © 1992-2009  CADENCE DESIGN SYSTEMS INC.  ALL RIGHTS RESERVED.
\o           © 1992-2009  UNIX SYSTEMS Laboratories INC.,
\o                          Reproduced with permission.
\o
\o This Cadence Design Systems program and online documentation are
\o proprietary/confidential information and may be disclosed/used only
\o as authorized in a license agreement controlling such use and disclosure.
\o
\o           RESTRICTED RIGHTS NOTICE (SHORT FORM)
\o Use/reproduction/disclosure is subject to restriction
\o set forth at FAR 1252.227-19 or its equivalent.
\p >
\o 8-bit PseudoColor Visual is not available (default Visual option).
\o Using 24-bit TrueColor Visual.
\o The program xdpyinfo can be used to verify the Visuals available
\o for your display.
 楼主| 发表于 2013-4-17 11:57:13 | 显示全部楼层
高手帮帮忙呀
发表于 2013-4-17 20:33:38 | 显示全部楼层
貌似是显示的问题,不知道你用什么方式登录的?ssh -X ? vnc ? or vmware ?
发表于 2013-4-17 21:17:08 | 显示全部楼层
试试
setenv DISPLAY unix:0.0
发表于 2013-6-26 09:23:49 | 显示全部楼层
楼主问题解决了吗  小弟也遇到同样的问题了
GMT+8, 2025-12-19 23:11 , Processed in 0.028331 second(s), 6 queries , Gzip On, Redis On.
