查看: 1854|回复: 1
[招聘] Cadence SH 招聘 Principal Product Engineer
发表于 2013-4-16 18:02:12 | 显示全部楼层 |阅读模式
Cadence SH 招聘Principal Product Engineer
If youhave interest, PLS send your update CV to zhangyl@cadence.com
1. Principal/Lead/Senior PVS Product Engineer
Position Description:
The Product Engineering teamworks with Customers and foundries, R&D, Marketing, and the FieldApplications Engineers to create products that address the unique and complexneeds of our customers. A Physical Verification Product Engineer providesin-depth technical expertise in writing Physical Verification rule decks (i.e.DRC, ERC, FILL and LVS) and the usage of Physical Verification tools throughoutphysical implementation and signoff verification cycles.
Responsibilities:
Develop Physical Verificationrule decks (i.e. DRC, ERC, FILL and LVS)
Setup efficient flows toimprove rule deck development quality and product performance.
Run expert-level benchmarksand solve complex customer problems.
Work with the RD, field,customers and foundries to identify and define product requirement and enhancement
Position Requirements:
Knowledge of developing ruledecks for commercial physical verification tools (e.g. PVS, Calibre, Hercules,Dracula, Assura, etc.) is required.
Experience in the followingareas:
- DRC, includes density,antenna, etc.
- LVS, includes deviceextraction, parameter measurement, connect/stamp sequences, short isolation,etc.
- Knowledge of netlist formatsSPICE, CDL, Verilog, etc.
- DFM, includes yieldanalysis, via insertion, OPC, FILL, etc.
Experience with layoutimplementation tools (e.g. Virtuoso, DesignREV, ICStation, etc.) for thecreation of qualification cells is required.
Knowledge of automating testsuites for the qualification of rule decks is a plus.
Programming of Tcl, Perl, andSkill are a plus
EDUCATION: BS or MS in ElectricalEngineering.
2. PrincipalProduct Engineer-----DDR IP
Cadence is lookingfor an individual to work in design IP team. The group provides configurableDDR memory controller and PHY IP for ASICs. The job will be mainly focused onproviding post technical support to customers; however there will be a varietyof other engineering tasks that will allow the candidate to expand skills andresponsibilities.
Providetechnical support to customers for integration of IP into ASICs including:
- Debugging ofcustomers’ simulation or silicon issues.
- Reviewing ofcustomers’ design integration of our IPs.
- Reviewing statictiming reports to assist with customers’ timing closure.
- Answeringtechnical questions about IP operation.
- Train fieldengineers in IP operation.
- Interface with theR&D Team to bridge product improvements and resolve customer issues.
PositionRequirements:
- Excellent oral andwritten communication
- Good English communication skill
- BS  8+ yearsof prior work-experience or MS 6+ years of prior work-experience
- All front-endskills – RTL design & verification in Verilog, synthesis, static-timinganalysis, DFT
- Back-end skills –place & route, physical verification, timing closure
- Time managementskills sufficient to balance multiple high-priority projects.
- Willingness tolearn new skills and perform tasks that often go outside area of currentexpertise.
Additional Desirable Qualifications:
- Experience withStatic Timing scripts and report analysis
- Familiarity withDDR memory operation, system applications, AXI, OCP, AHB
- Familiarity withFrame maker
- Scripting – inPerl, TCL, etc..
发表于 2013-4-17 10:33:10 | 显示全部楼层
有没有数字前端做design的职位啊?
GMT+8, 2025-12-23 05:11 , Processed in 0.019202 second(s), 6 queries , Gzip On, Redis On.
