楼主: 短笛
外国经典数字电路
发表于 2007-9-22 21:28:15 | 显示全部楼层
没钱呀!好贵
发表于 2007-9-23 00:05:11 | 显示全部楼层
学习学习一下
发表于 2007-9-29 15:43:08 | 显示全部楼层
en ..xiexieha ..
发表于 2007-10-2 12:02:20 | 显示全部楼层
是不是那本Complete Digital Design啊,我一直在找,下了的人回个话呀
发表于 2007-10-2 12:43:00 | 显示全部楼层
书名:Complete Digital Design: A Comprehensive Guide to Digital Electronics and Computer System Architecture
ISBN:007140927
作者:Mark Balch
出版社:McGraw-Hill Professional
简介:The explosion in communications and embedded computing technologies has brought with it a host of new skill requirements for electrical and electronics engineers, students, and hobbyists. With engineers expected to have such diverse expertise, they need comprehensive, easy-to-understand guidance on the fundamentals of digital design.
Enter McGraw-Hill’s Complete Digital Design. Written by an experienced electrical engineer and networking hardware designer, this book helps you understand and navigate the interlocking components, architectures, and practices necessary to design and implement digital systems. It includes:
* Real world implementation of microprocessor-based digital systems
* Broad presentation of supporting analog circuit principles
* Building complete systems with basic design elements and the latest technologies
Complete Digital Design will teach you how to develop a customized set of requirements for any design problem — and then research and evaluate available components and technologies to solve it. Perfect for the professional, the student, and the hobbyist alike, this is one volume you need handy at all times
Preface xiii
Acknowledgments xix
PART 1 Digital Fundamentals
Chapter I Digital Logic
1.1 Boolean Logic / 3
1.2 Boolean Manipulation / 7
1.3 The Karnaugh map ! 8
1.4 Binary and Hexadecimal Numbering / I0
1.5 Binary Addition ! 14
1.6 Subtraction and Negative Numbers / 15
1.7 Multiplication and Division / 17
1.8 Flip-Flops and Latches / 18
1.9 Synchronous Logic / 21
1.10 Synchronous Timing Analysis / 23
1.11 ClockSkew / 25
1.12 Clock Jitter / 27
1.13 Derived Logical Building Blocks / 28
Chapter 2 Integrated Circuits and the 7400 Logic Families
2.1 The Integrated Circuit / 33
2.2 IC Packaging ! 38
2.3 The 7400-Series Discrete Logic Family / 41
2.4 Applying the 7400 Family to Logic Design / 43
2.5 Synchronous Logic Design with the 7400 Family / 45
2.6 Common Variants of the 7400 Family / 50
2.7 Interpreting a Digital IC Data Sheet / 51
Chapter 3 Basic Computer Architecture
3.1 The Digital Computer / 56
3.2 Microprocessor Internals / 58
3.3 Subroutines and the Stack ! 60
3.4 Reset and Interrupts / 62
3.5 Implementation of an Eight-Bit Computer / 63
3.6 Address Banking / 67
3.7 Direct Memory Access / 68
3.8 Extending the Microprocessor Bus / 70
3.9 Assembly Language and Addressing Modes / 72
Chapter 4 Memory
4.1 Memory Classifications / 77
4.2 EPROM / 79
4.3 Flash Memory i 81
4.4 EEPROM / 85
4.5 Asynchronous SRAM / 86
4.6 Asynchronous DRAM / 88
4.7 Multiport Memory / 92
4.8 The FIFO / 94
Chapter 5 Serial Communications
5.1 Serial vs. Parallel Communication / 98
5.2 The UART / 99
5.3 ASCII Data Representation / 102
5.4 RS-232 / 102
5.5 RS-422 / 107
5.6 Modems and Baud Rate / 108
5.7 Network Topologies / 109
5.8 Network Data Formats / 110
5.9 RS-485 / 112
5.10 A Simple RS-485 Network / 114
5.11 Interchip Serial Communications / 117
Chapter 6 Instructive Microprocessors and Microcomputer Elements
6.1 Evolution / 121
6.2 Motorola 6800 Eight-bit Microprocessor Family / 122
6.3 Intel 8051 Microcontroller Family / 125
6.4 Microchip PIC Microcontroller Family / 131
6.5 Intel 8086 16-Bit Microprocessor Family / 134
6.6 Motorola 68000 16/32-Bit Microprocessor Family / 139
PART 2 Advanced Digital Systems
Chapter 7 Advanced Microprocessor Concepts
7.1 RISC and CISC / 145
7.2 Cache Structures / 149
7.3 Caches in Practice / 154
7.4 Virtual Memory and the MMU / 158
7.5 Superpipelined and Superscalar Architectures / 161
7.6 Floating-Point Arithmetic / 165
7.7 Digital Signal Processors / 167
7.8 Performance Metrics / 169
Chapter 8 High-Performance Memory Technologies
8.1 Synchronous DRAM / 173
8.2 Double Data Rate SDRAM / 179
8.3 Synchronous SRAM / 182
8.4 DDR and QDR SRAM / 185
8.5 Content Addressable Memory / 188
Chapter 9 Networking
9.1 Protocol Layers One and Two / 193
9.2 Protocol Layers Three and Four / 194
9.3 Physical Media / 197
9.4 Channel Coding / 198
9.5 8B10B Coding ! 203
9.6 Error Detection / 207
9.7 Checksum / 208
9.8 Cyclic Redundancy Check / 209
9.9 Ethernet / 215
Chapter 10 Logic Design and Finite State Machines
10.1 Hardware Description Languages / 221
10.2 CPU Support Logic / 227
10.3 Clock Domain Crossing / 233
10.4 Finite State Machines / 237
10.5 FSM Bus Control / 239
10.6 FSM Optimization / 243
10.7 Pipelining / 245
Chapter 11 Programmable Logic Devices
11.1 Custom and Programmable Logic / 249
11.2 GALs and PALs / 252
11.3 CPLDs / 255
11.4 FPGAs / 257
PART 3 Analog Basics for Digital Systems
Chapter 12 Electrical Fundamentals
12.1 Basic Circuits / 267
12.2 Loop and Node Analysis / 268
12.3 Resistance Combination / 271
12.4 Capacitors / 272
12.5 Capacitors as AC Elements / 274
12.6 Inductors / 276
12.7 Nonideal RLC Models / 276
12.8 Frequency Domain Analysis / 279
12.9 Lowpass and Highpass Filters / 283
12.10 Transformers / 288
Chapter 13 Diodes and Transistors
13.1 Diodes / 293
13.2 Power Circuits with Diodes / 296
13.3 Diodes in Digital Applications / 298
13.4 Bipolar Junction Transistors / 300
13.5 Digital Amplification with the BJT / 301
13.6 Logic Functions with the BJT / 304
13.7 Field-Effect Transistors / 306
13.8 Power FETs and JFETs / 309
Chapter 14 Operational Amplifiers
14.1 The Ideal Op-amp / 311
14.2 Characteristics of Real Op-amps / 316
14.3 Bandwidth Limitations / 324
14.4 Input Resistance / 325
14.5 Summation Amplifier Circuits / 328
14.6 Active Filters / 331
14.7 Comparators and Hysteresis / 333
Chapter 15 Analog Interfaces for Digital Systems
15.1 Conversion between Analog and Digital Domains / 339
15.2 Sampling Rate and Atiasing / 341
15.3 ADC Circuits / 345
15.4 DAC Circuits / 348
15.5 Filters in Data Conversion Systems / 350
PART 4 Digital System Design in Practice
Chapter 16 Clock Distribution
16.1 Crystal Oscillators and Ceramic Resonators / 355
16.2 Low-Skew Clock Buffers / 357
16.3 Zero-Delay Buffers: The PLL / 360
16.4 Frequency Synthesis / 364
16.5 Delay-Locked Loops / 366
16.6 Source-Synchronous Clocking / 367
Chapter 17 Voltage Regulation and Power Distribution
17.1 Voltage Regulation Basics / 372
17.2 Thermal Analysis / 374
17.3 Zener Diodes and Shunt Regulators / 376
17.4 Transistors and Discrete Series Regulators / 379
17.5 Linear Regulators / 382
17.6 Switching Regulators / 386
17.7 Power Distribution / 389
17.8 Electrical Integrity / 392
Chapter 18 Signal Integrity
18.1 Transmission Lines / 398
18.2 Termination / 403
18.3 Crosstalk / 408
18.4 Electromagnetic Interference / 410
18.5 Grounding and Electromagnetic Compatibility / 413
18.6 Electrostatic Discharge / 415
Chapter 19 Designing for Success
19.1 Practical Technologies / 420
19.2 Printed Circuit Boards / 422
19.3 Manually Wired Circuits / 425
19.4 Microprocessor Reset / 428
19.5 Design for Debug / 429
19.6 Boundary Scan / 431
19.7 Diagnostic Software / 433
19.8 Schematic Capture and Spice / 436
19.9 Test Equipment / 440
Appendix A Further Education
这本书好像有中译本的,学数字电路的话我推荐一本书,叫<数字集成电路透视>,现在论坛的附件能上传5M了,楼主:我看应该找时间重新上传一下
发表于 2007-10-2 12:46:35 | 显示全部楼层
我传一下吧,我看这么早的帖,楼主也忘了
发表于 2007-10-2 13:10:19 | 显示全部楼层
Complete Digital Design.rar
3.53 MB, 下载次数: 18 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2007-12-7 08:53:00 | 显示全部楼层
顶一下
发表于 2007-12-7 12:01:16 | 显示全部楼层
HAO HAO HAO
发表于 2007-12-12 16:33:49 | 显示全部楼层
ding
ding a ding
GMT+8, 2025-12-26 11:38 , Processed in 0.025148 second(s), 6 queries , Gzip On, Redis On.
