查看: 2230|回复: 5
HDL.Works.IO.Checker.v2.2.R4 w/ CRACK [Windows + Linux]
发表于 2013-3-27 13:25:01 | 显示全部楼层 |阅读模式
HDL Works IO Checker 2.2.R4 w/ CRACK
IO Checker 2.2
Verifying hundreds of FPGA IO pins between PCB and FPGA in minutes
When using large FPGA's on a PCB making sure that the FPGA pins are connected to the right signals on the PCB is a cumbersome task. On the FPGA side the pins are assigned to the HDL signals that form the toplevel of the logic implemented on the FPGA. On the PCB side the pins have to be connected to the proper net that will connect it to other components on the PCB. Because implementation of FPGA and PCB is often done in parallel and by different engineers, the signal names used are not always identical. To make things even worse, it is often necessary to perform pin swaps to prevent PCB routing problems. These pin swaps have to be made both on the FPGA and the PCB. As this is almost always manual work, and current devices have over 1500 pins, a mistake is easily made.
Intelligent Verification
IO Checker uses rules (based on regular expressions) to match the signal names in both the FPGA and PCB design environment. It allows the tool to validate groups of matches although individual signals can still differ. The rules can be generated automatically and be fine-tuned by the designer. The automated approach will often match 80% to 90% of all device pins.
The flexibility of IO Checker allows it to be used in any design flow and does not require any design methodology. The rules generator in combination with the sorted problem view allows engineers to validate a 1000+ pins device in half an hour.
Once the project and its rules are defined it is a simple task to keep the FPGA and PCB data consistent. All out-of-date files are processed in one action and all changes are reported.
Features & Benefits
  • Compare FPGA and PCB pin names using regular expressions
  • Create & update FPGA constraint file
  • Automatic rule generation
  • Voltage checks for power pins
  • User directed acceptance of verified differences
  • One click verification and consistency
  • Reports incremental changes in pin- and net list
  • Concentrate on a dozen differences instead of a thousand lines
  • Fits in any design flow
  • HTML report
Homepage:
  1. http://www.hdlworks.com/products/iochecker/index.html
    复制代码
UnRAR Password/Passcode: eetop.cn
Please verify downloads against the MD5 checksums listed below to see if files are all OK!
  1. Linux:
  2. ac4c5c9fc844aa7749871a7845b59f97  HDL.Works.IO.Checker.v2.2.R4.for.Linux-BEAN.part1.rar
  3. e4d14ae57c864f663e4e347b900454c5  HDL.Works.IO.Checker.v2.2.R4.for.Linux-BEAN.part2.rar
  4. b14870b36a36582f6a91bd2671bb5dd8  HDL.Works.IO.Checker.v2.2.R4.for.Linux-BEAN.part3.rar
  5. 61c4dd119a9a236918c3261ff6385656  HDL.Works.IO.Checker.v2.2.R4.for.Linux-BEAN.part4.rar
  6. Windows:
  7. 9131960e36e3b2a963d77d1db7a5d375  HDL.Works.IO.Checker.v2.2.R4.for.Windows-BEAN.part1.rar
  8. decd4a042e6a239b1ff3f7236f5c75c4  HDL.Works.IO.Checker.v2.2.R4.for.Windows-BEAN.part2.rar
  9. 97fb54fdb4eab3a42d53f17a458d8a0e  HDL.Works.IO.Checker.v2.2.R4.for.Windows-BEAN.part3.rar
  10. 3104527166512fc92124b8abf80e1b52  HDL.Works.IO.Checker.v2.2.R4.for.Windows-BEAN.part4.rar
    复制代码
15 MB, 下载次数: 8 , 下载积分: 资产 -5 信元, 下载支出 5 信元
15 MB, 下载次数: 9 , 下载积分: 资产 -5 信元, 下载支出 5 信元
11.3 MB, 下载次数: 9 , 下载积分: 资产 -4 信元, 下载支出 4 信元
15 MB, 下载次数: 24 , 下载积分: 资产 -5 信元, 下载支出 5 信元
15 MB, 下载次数: 21 , 下载积分: 资产 -5 信元, 下载支出 5 信元
15 MB, 下载次数: 19 , 下载积分: 资产 -5 信元, 下载支出 5 信元
4.62 MB, 下载次数: 18 , 下载积分: 资产 -3 信元, 下载支出 3 信元
发表于 2013-7-19 12:49:44 | 显示全部楼层
试试看好用否
发表于 2013-7-19 12:53:18 | 显示全部楼层
试试看能不能正常破解
发表于 2013-7-19 13:05:39 | 显示全部楼层
试试看能不能正常破解
发表于 2013-7-19 16:36:58 | 显示全部楼层
感謝大大的分享
我正需要呢
謝謝喔
发表于 2013-8-1 11:51:19 | 显示全部楼层
看看能不能破解
GMT+8, 2025-12-19 22:39 , Processed in 0.028450 second(s), 10 queries , Gzip On, Redis On.
