查看: 2308|回复: 3
[求助] 求大神指教程序那里有问题?????
发表于 2013-3-24 09:44:31 | 显示全部楼层 |阅读模式
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity button is
port(
bin : in std_logic_vector(1 downto 0);
bout : out std_logic_vector(7 downto 0));
end entity button;
architecture counter of button is
signal num : integer := 0;
procedure change (a : in integer) is
begin
case a is
when 0 => bout <="11111100";
when 1 => bout <="01100000";
when 2 => bout <="11011010";
when 3 => bout <="11110010";
when 4 => bout <="01100110";
when 5 => bout <="10110110";
when 6 => bout <="11111010";
when 7 => bout <="11100000";
when 8 => bout <="11111110";
when 9 => bout <="11110110";
when others=>bout<="00000000";
end case;
end procedure;
begin
if (bin(0) = '0') then
num <= num+1;
change(num);
end if;
if (bin(1) = '0') then
num <= num-1;
change(num);
end if;
end counter;
发表于 2013-3-24 10:10:25 | 显示全部楼层
没时钟?
发表于 2013-3-24 15:49:46 | 显示全部楼层
if 要放在一个process里面啊。如果放在process外面,是和generate一起用,不是干这个事情的。
 楼主| 发表于 2013-3-25 16:54:41 | 显示全部楼层
回复 3# tigerjade
谢谢你!嘻嘻!
GMT+8, 2025-12-16 08:13 , Processed in 0.027779 second(s), 5 queries , Gzip On, Redis On.
