查看: 2611|回复: 0
astro 200703安装问题求解
发表于 2013-3-12 22:21:44 | 显示全部楼层 |阅读模式
安装过程很顺畅,环境变量的设置和license也是论坛里面教的那样做的,但是启动astro的时候报了下面错误:
Failed to get license key 'Milkyway'.  (License server system does not support this feature. (-18,147))
Failed to get license key 'MDataPrep'.  (License server system does not support this feature. (-18,147))
Failed to get license key 'Astro'.  (License server system does not support this feature. (-18,147))
Failed to get license key 'Apollo'.  (License server system does not support this feature. (-18,147))
License initialization failed
Connection to IPC server failed.
Starting IPC Server. (Port = 1924)
以为是环境变量设置错误,仔细检查过都和教程一样,没有问题。后来又用lmgrd -c **/license.dat 报了一下错误:
version GLIBC_2.0 not defined in file libc.so.6
求赐教。。
GMT+8, 2025-12-27 07:10 , Processed in 0.013615 second(s), 6 queries , Gzip On, Redis On.
