查看: 3300|回复: 0
[招聘] 【社会招聘】LSI 2013中国热招职位(上海/北京/深圳)(最新全)
发表于 2013-3-11 16:39:02 | 显示全部楼层 |阅读模式
请将简历发至:Tracey.zheng@lsi.com
如有任何疑问,请发送邮件至Tracey.zheng@lsi.com或拨打电话021-24191709.
也可加我msn: zql975504@hotmail.com
或微博:http://www.weibo.com/u/1752448637
或QQ: 2306464914
LSI中国在2013和2014还会处于快速的成长阶段,如果您目前在下面没有找到合适的职位,也欢迎联系,我们随时都可能有适合你职业发展的机会呦!
上海热招职位:
1.        ASIC Customer Design Engineer-shanghai
Job Descriptions:
- LSI Corporation offers an excellent opportunity to contribute to a team environment and to grow personal career path. You will be working with internal and external customers to develop state of the art IC solutions utilizing LSI's leading edge CMOS cell-based ASIC technologies. You will have responsibility for ASIC designs through all of the key development and implementation phases including RTL analysis, synthesis, design optimization, timing verification, simulation, test insertion, physical design, vector generation, and post-prototype test support. Candidates will have opportunity to work on the latest 40nm/28nm designs.
Detail design tasks include
Presales support (die size support, memory generation, addressing customer questions and concerns.)
RTL analysis & synthesis
Top level and block level physical design Implementation (bonding, floor planning, power structure insertion, place and route, timing closure)
Test structure insertion/silicon testing debug
Formal verification
Static timing analysis
Cross talk analysis
Power verification
Physical verification
Overtime, candidates are expected to develop the most of above skills. Candidates who have the desire to seek the in-depth and broad technical challenge should apply.
Job Requirements:
BS/MS Electrical, Computer Engineering or Equivalent
- 2+ years experience in ASIC design and implementation. Familiar with all aspects of ASIC design implementation flow and specializing in physical design or DFT implementation.
RTL Analysis/Synthesis/STA OR Physical Design Implementation OR Physical Verification OR DFT
2.        Software Quality Assurance (SQA) Engineer-Shanghai
Job Description
- Quick learner with high level of self-motivation and dedication, with ability to deliver high quality products on time
- Meticulous, methodical, uncompromising, and creative in testing
- Experience in software debugging, problem creation and trapping
- Experience in devising testing / validation methodology is strong plus
- Communicate effectively in a team, able to multitask effectively in fast-paced environment
- Understanding of NAND Flash concepts, knowledge of Flash management techniques, including wear leveling, garbage collection (strong plus)
- Knowledge and hands-on experience with storage protocols is preferred (SAS / SATA)
Requirements/Qualifications (Education)
- BS in Electrical Engineering, Computer Science, or Computer Engineering is required with 3+ years of firmware development
- M.S. preferred with 2+ years in software / hardware validation
- Related storage experience will be plus
3.        Firmware Application Engineer-Shanghai
Job Descriptions:
Provide Tier 1 customer firmware support.
Act as firmware technical lead within the application engineering organization.
Manage and prioritize customer issues and customer expectations releasing firmware updates back to customers.
Train and teach internal application engineers on firmware implementation and architecture.
Minimal travel required.
Job Requirements:
BS EE or CS required, MS preferred
Must have experience with C/C++
Min 7+ years of firmware experience
Create and propose product concepts to executive level staff
Excellent verbal and written communication skills. High technical comprehension a must . Must be able to translate complex ideas into easily communicated messages
-Experienced with High Speed I/O interfaces from physical to protocol level (SAS, SATA, InfiniBand, FC, Ethernet, PCI Express), Memory technology (SRAM, DRAM, Flash, etc). Must have familiarity with Server and Storage system architecture
4.         Preamp Analog/Mixed Signal Design Engineer-
Shanghai
Job Description
- Design high speed analog and mixed-signal integrated circuits within custom chips for the hard disk drive industry
- Work directly with customers to determine system requirements, write specifications and guide customers in the use of pre-amplifier products
- Use high speed electronic characterization equipment to evaluate and debug the functionality of the design once the part is fabricated in silicon
- Provide technical leadership through all phases of product development including test, yield, characterization, reliability analysis, qualification and release to manufacturing
LSI's Storage Peripherals Group is looking for an experienced custom analog IC designer to join the pre-amplifier design team. At LSI we are committed to innovation and industry leadership. We develop advanced high-speed magneto electronic read/write IC architectures as the basis for our products.
Design team members define, create and modify high-speed custom integrated circuits for hard disk drive (HDD) products using leading edge CMOS and SiGe BiCMOS technologies.
Team members support the entire product life cycle beginning with design and moving through test, qualification, release to production and ramp to volume.
- Degree in Electrical Engineering (or related field), MS required, Ph.D. preferred
- 5 years and above Experience with analog and mixed signal IC product design, integration and verification is required.
- Strong physical layout knowledge and parasitic component understanding essential
- Process and device physics knowledge critical
- Proven skills using electronic measurement equipment in a lab environment
- Expertise in applied magnetism and recording a strong plus
5.        Verification Engineer-Shanghai
Job Descriptions:
As a member of the Read Channel team, candidate must be willing to work as an extended member of the design team. Duties will include functional verification of Storage read channel mixed-signal IP. Candidate will be expected to contribute to design and development of System Verilog based verification environment and will be responsible for verification closure of block/chip/system level functions for mixed signal based IP. Experience with System Verilog and functional coverage methodologies is required. Must be willing to follow a disciplined verification methodology and to work closely with a multi-location, international design team. Excellent teamwork and communication skills are required.
Job Requirements:
BSEE with 3-5+ years of design and/or verification experience required, MSEE preferred.
Required knowledge and skills:
1)Expertise in System Verilog required
2)Good understanding of Digital Signal Processing
3)Good understanding of Analog and Digital Circuits
4)Very good analytical/debugging skill
5)Good verbal and written communication skills
6.         Program Manager -Shanghai
Job Description
Scope of programs: International Programs with contributors from several organizations and/or Business Units Programs with high business impact, above $20Mio total over product lifetime Programs with high development cost and effort, above 5 man years Programs with concurrent engineering of customer product and IP customization Responsibilities: - Project Definition: Ensure that Goals, Objectives & Scope for the Program is defined, understood and agreed to Work with engineering and management to form the project team. Develop a Project Plan with clear ownership and deliverables milestones together with LSI and Customer teams Work with engineering to calculate and forecast the effort and investment for successful project execution Drive concurrent Risk Management as integral part of the project planning and execution - Project Execution: Call regular project review meetings, internal and with the customer Coordinate and align the customer execution with internal LSI organizations and deliverables. Ensure effective communication between all parties involved
Provide regular project reports (to the customer and internal) Continuously track/maintain and measure project schedule progress against plan Perform continuous Risk Management and elevate critical issues and risks. Manage the Change Management Process (with the customer and internal to LSI) Manage the Action Management Process Facilitate Project Lessons Learned (internal and with the customer)
- Minimum 5 years experience in the fields of management, sales/marketing and engineering
- Good understanding of the ASIC design process & methodology
- Detailed knowledge of project management methodology, processes and tools
- PMI certification is a plus
- Expert knowledge in Microsoft Project, Excel, and Outlook
- Basic knowledge in Microsoft Word and PowerPoint
- Engineering degree or equivalent
- Ability to adopt and execute a structured working methodology
- Fluent verbal and writing language skills in native language and English
- Strong communication skills
- Excellent interpersonal and leadership skills
- Self motivated and self driving
7.        Sr. System Admin-Shanghai
Job Descriptions:
To provide Storage administration and engineering support in China and further our global support model. This is required due to the vast growth in China and regions outside the U.S. This requisition is part of the Workforce Plan alignment efforts.
Job Requirements:
3-5 years of experience with Unix and/or Linux (Solaris and RedHat Linux OS) administration. 1-3 years of experience with Storage and Backup infrastructure administration with experience in Network Appliance Filers, SAN, OnStor gateways, EMC, Veritas Cluster Software, Veritas File System, Volume Manager, enterprise RAID Array and Netbackup. Vendor relation management experience required. Ability to work with a flexible schedule. Experience with Perl, Tcsh and other administrative languages is a plus. Ability to work in a fast-paced engineering environment with a positive customer service and teamwork attitude. Familiarity with Semiconductor and Design Center business operation. Demonstrates initiative & contributes to problem solving.
8.        Package Development Engineer-Shanghai
Job Descriptions:
Based in Shanghai, will work with LSI experts and world leading OSAT partners in rapidly expanding team to develop and introduce new IC Package Technology into manufacture.
Development of IC Wirebond and Package technology
Ownership of new IC Package Technology development programs
Organize and oversee programs
Manage development through subons and suppliers
Communicate program status to stakeholders
Coordinate technology characterization and qualification
Interact with Business Unit eng. and program management to align activities and deliverables
Interact with Quality and Failure Analysis engineering to identify technical issues and resolve problems
Provide technical oversight for wirebond technology
Job Requirements:
MS or above in Mechanical Eng., Physics, Chemical Eng., Material Eng.
5 plus years experience in IC Package wirebonding process development or operations
Overseas subcon management experience
Self motivated, self confident, with strong work ethic
Excellent negotiation skills
Excellent communication skills in Chinese and English
Excellent program management skills
Experience with Design of Experiments, SPC, 6 sigma
9.        Test Engineer-Shanghai
Job Descriptions:
Will develop processes, fixturing, and software to facilitate manufacturing test for storage products. Design for Manufacturability and Design for Testability to ensure product quality through methodical and detail oriented test practices. Design, develop, and document the test plan. Contribute significantly to multiple projects developing solutions, methods, and efficiencies that lead to quality products and customer success. Drive corrective
e action through test enhancements or process modification in response to root cause failure data. Analyze test results and take action to increase yields. Transition products to contract manufacturers.
Job Requirements:
Indepth knowledge on Windows and Unix Platform. Understanding of System Hardware and Storage related products. Experience in Black-box testing. Writing scripts for mixed-signal Automated testing - Teradyne Catalyst experience preferred. Experience in the development of manufacturing test processes - storage technology preferred. Demonstrated knowledge of C/C++, etc. Hardware knowledge to the component level. Ability to communicate relevant information and ideas persuasively in a concise, organized, and professional manner. Versatile in dealing successfully with changing conditions managing multiple projects with minimal supervision. Knowledge of DFx engineering practices; New Product Introduction; and transitioning products to contract manufacturers. Established reputation for competence and reliability.
Education
BS EE with 2-4 years experience.
10.         WebCloud Account Sales-Shanghai /Beijing
Job Descriptions:
- This Account manager role is responsible for LSI’s storage business (ASD/RSD) for tier-1 WebCloud customers in North or East China region. It required knowledge and expertise in SSD/Flash, SAS/SATA, RAID, x86 Server, storage, database, distributed application areas for selling LSI’s Flash and SAS storage solution to those tier-1 WebCloud customers like Tencent, Alibaba and Baidu. This role also required strong background and understanding in MDC (Mega Data center) server storage architecture, the key needs and trends in storage area for MDC, and also how to apply flash technologies into MDC to accelerate the storage performance. For all assigned customers and projects, this role is responsible for identifying new business opportunity, arrange the pre-sale supports, close the design win, drive the customer satisfactory, manage the customer relationship and eventually drive and grow the overall LSI sales revenue from the account. This role also needs to define sales plan, provide regular business updates/design win updates and revenue forecast, work with LSI product team and all functional team, to take the lead and be accountable in archiving design win target and sale revenue quota. This role required strong English communication capability, in both written and speak, to support the daily work with support team and product team. Other than to drive the direct sale with tier-1 WebCloud customers, this account manager role also need to build up the relationship and engagement model, to influence customer’s preference in storage technologies, partner with LSI’s OEMs to grow the business size, identify new business opportunity for LSI’s Flash/SAS storage solution
Job Requirements:
- Strong background and understanding in WebCloud customers
- 7+ years working experience in IT server storage industry
- 3+ years working experience in global company
- Strong understanding in Flash storage solution and the industry trends
- Strong English communication both in written and in verbal
- Self motivated person with passion for success
- Strong leadership skill to drive both internal and external to make things happen
- Bachelor in Computer Science or EE
11.         Marketing Manager -Shanghai
Job Descriptions:
We are looking for a smart, talented and experienced marketing profession to join the Corporate Marketing Team at LSI Asia Pacific and Japan region. In this role, you will lead a small team to be responsible for Channel marketing, brand, online marketing and integrated marketing campaigns that shape audience perceptions and generate demand. Additionally, he/she will interface with LSI ’s advertising/event agencies and key internal stakeholders such as sales team and business units to lead the efforts on channel development and sales enablement. - 50% of his/her time on developing and executing the engagement strategy and plan on channel marketing including channel development plan by leveraging Marketing Development Fund, co-marketing activities, leads generation program, etc. - The other 50% of his/her time as the team manager, driving and facilitating the development and execution of the integrated marketing efforts to increase brand awareness, enable sales force and generate demand.
Job Requirements:
- Strong ability to influence and impact
- Strong project management skills
- Great communication and collaboration skills
- Strong analytical capabilities
- Detail oriented work style
- At least 2-3 years of solid channel marketing experience in Distribution and Reseller Channel, preferably in technology marketing
- University degree, MBA is a plus
- Marketing agency experience considered a plus, but not required for this position
- Experience working at a large global multinational is also a positive
12.        PR Manager -Shanghai
Job Descriptions:
- Pro-actively develop & implement complete media relations program in China, closely collaborating with field team & worldwide to grow brand awareness among target audience and demonstrate key values to existing and potential customers in China.
- Develop, prepare and implement a variety of public relations campaigns and events both ATL and BTL; Maintain and enhance media relations in China; create media and PR specific materials.
- Maximize the brand awareness and new product exposure by leveraging the opportunities of the executive interview and public speakership while maximizing integration with other elements of the marketing mix to close the loop and maximize the market impact.
- Identify and leverage the traditional and online media and advertorial chances to maximize the brand awareness and generate positive advocacy
Job Requirements:
- 5 years and/or above work experiences with at least 3 years in PR roles in multinational companies; PR agency experience is a plus
- Fluent spoken and written English, excellent presentation skill
- Excellent organizational and project management skills
- Good team player with strong cross-functional collaborative ability
- independent and highly self-motivated with result driven
13.        Marketing Executive -Shanghai
Job Descriptions:
- Support the implementation and management of the channel marketing activities and marketing programs, accountable for delivering and executing within agreed timeframes
- Manage local vendors to help align resources and execute on the program. Regular reviews with vendors to ensure the cost efficiency and effectiveness
- Responsible for budget management for marketing team, tracking the budget usage and balance and provide visibility on regular base
- Coordinate with translation house to handle the translation work for the marketing materials such as press release, new product launch, presentation materials for marketing events, etc.
Job Requirements:
- Bachelor degree; 1-2 years working experience in marketing and/or sales
- Good command of English in both writing and speaking
- Strong interpersonal, communication skills; Self-motivated, passionate and results- oriented
- Coordination and planning of budgets, time management; Detail Oriented; Good analytical skills
北京热招职位:
1. Field Application Engineer-Beijing
Job Descriptions:
Work closely with Sales and customers to provide excellent support of new and existing business, including pre-design win and post design win.
Achieve design wins at customers
Support customers on-site when needed.
Work closely with global technical colleagues (USA, China) to provide backup support.
Track issues and defects and drive to resolution.
Provide quick response to key customer’s request on technical support.
Provide technical training to Sales team and customers.
Job Requirements:
• 6 years+ of experience with Storage controller, Storage system and/or flash solution.
• Knowledge and experience in Firmware/Software, SAS server system, flash solution and datacenter. Oracle Database knowledge or PCIe based flash card/flash solution is a plus.
• Experience supporting storage products eg. SAS processor/Controller/Expander or storage system or webcloud customers
• Broad Network or Storage knowledge
• Demonstrated ability to learn technology quickly
• Very good English communication skills
• Team player, self-motivation
• Communication/Information Systems or EE degree, Masters preferred
2. Senior Technical Marketing Engineer -Beijing
Job Descriptions:
- Run and own proof of concept activities introducing Nytro PCIe flash solutions
- Analyze customer requirements and recommend creative architectures and solutions that implement Nytro solutions
- Answer technical questions regarding hardware and software on sales calls
- Provide constructive feedback to engineering regarding product requirements, support tools, and support methodologies
- Provide an effective bridge between end users and LSI’s engineering team
- Assist in architecture definition with customers and provide technical support for evaluation and proof of concept projects to reach successful completion
- Maintain close contact with engineers and management at customers’ sites, and provide status and new project information to sales and product marketing managers
- Debug hardware and/or software problems related to proof of concept evaluations
LSI Corporation is a leading provider of innovative silicon, systems and software technologies that enable products which seamlessly bring people, information and digital content together. We offer a broad portfolio of capabilities and services including custom and standard product ICs, adapters, systems and software that are trusted by the world's best known brands to power leading solutions in the storage and networking markets.
Job Requirements:
- Over 7 years experience with 3+ years enterprise solution development experience. BSEE/BSCS or higher.
- Willingness to travel over 50% of the time
- Understanding of Window/Linux/VMware OS and provide support
- Strong analytical and troubleshooting skills
- Know how to use performance tools (IOmeter, VDBench, Flex IO, Sysbench, IOZone, IOStat, etc)
- Ability to handle and resolve critical customer issues/problems resulting in a high level of customer satisfaction
- Strong leadership skills. Drive to succeed, achievement orientation, self-motivation.
- Strategic thinking, with the ability to identify and unravel issues before they hit the schedule.
- Positive, energetic, persistent and can-do attitude. Not requiring a lot of hand-holding.
- Excellent written and oral communications skills as well as proven presentation skills
3.        Segment Technical Expert –Shanghai/Beijing/Shenzhen
Job Descriptions:
Working with tier-1 datacenter customers you will assist LSI in developing strong technical credibility through your knowledge of server, storage and networking knowledge.  You will work with our account teams, CTO office and business units to drive proof-of-concepts, new initiatives and drive requirements into the engineering and business teams.   You will be the technical champion, representing LSI at end-user customers, to assist in activities ranging from pre-sales to new architecture discussions.   Strong knowledge of hardware/software/systems deployed in datacenters is essential for success in this role.
Job Requirements:
Server technology and scale-out architectures
Datacenter architectures
Networking and storage
Ability to work effectively with customers
English
深圳热招职位:
1.         Systems Application Engineer –Shenzhen
Job Descriptions:
Provide product support for customers that use LSI’s I/O standard products. Product support involves helping the customer with the initial integration of the I/O standard product and debug of any software or hardware issues that arise. Work with the technical publications group on data manuals, systems engineering notes, and other documentation support. Provide training for customers and the Field Application Engineering organization. Work with the development engineering departments, hardware and software in debugging and supporting new products. Also involves working with silicon and software in a system environment
Job Requirements:
- Considering candidates with BSEE/BSCE. 5+ years of experience required.
- The ideal candidate will have a technical understanding of SAS, SCSI and PCI Express. Candidate will have embedded firmware debug experience and posses systems level knowledge. Good communication/interpersonal skills and the ability to listen and incorporate feedback is essential. The ability to handle multiple tasks at the same time is also required.
- C coding experience or equivalent coursework required.
- Logic analyzer, oscilloscope and protocol analyzer experience a plus.
2.        Segment Technical Expert –Shanghai/Beijing/Shenzhen
Job Descriptions:
Job Requirements:
English
3.        China OEM Sales Director-Shenzhen/Shanghai/Beijing
Job Descriptions:
- Lead the LSI China OEM Sales Team to develop, drive and execute the strategic and tactical OEM Sales plans/strategies working with business units to achieve planned revenue and design win goals with the result of consistent business growth in LSI OEM like Huawei, ZTE…etc.
- Build internal metrics to bring detailed visibility to the business. Analyze and evaluate the effectiveness of Sales methods and results, and recommend and administer policies and procedures to enhance operational effectiveness.
- Evaluate and formulate the necessary infrastructure support and organizational structure to sustain the growth of the organization that is consistent and economically adequate for attainment of business objectives. This includes the recruiting, organizing, training, and directing of an aggressive OEM Sales Team.
- Leverage relationships with China OEM’s executives to enlarge account penetration and expand the opportunity base. Direct the development of the relationships between LSI’s executives and China OEM’s executives.
- Provide visionary leadership on market positioning including the expansion of the product offering. Provide input to Marketing and Engineering of the business units to ensure that current core technologies and products are adapted for the international marketplace consistent with OEM’s needs. This also includes understanding and successfully navigating OEM’s business strategy to provide the feedback to LSI business unites to get alignment on roadmap solutions.
- Provide leadership in maintaining and developing the company image, generating a positive business climate and motivating employees. Customize negotiations and engagements with OEM to maintain healthy business climate.
- Maintain thorough familiarity with policies and procedures relating to Standards of Business Conduct/Conflict of Interest. Train and motivate subordinates in the importance of full compliance with the letter and spirit of such policies and procedures.
Job Requirements:
As leader of LSI OEM Sales Team, s/he will be responsible for China OEM revenue generation and design win closure. This person must have proven success selling semiconductor technology in the Networking and Storage industry. S/he must have prior management experience at early stage companies and with established technology brands and prior experience of direct engagement with China OEM. Key qualifications and experience required include:
- A minimum of 10 years of experience selling semiconductor solutions and a minimum of 5 years of experience directly engaging with China OEM.
- Previously held senior Sales management positions for fabless or ASIC design companies supporting China OEM.
- Extensive experience in solution selling of Networking and Storage solutions.
- Advanced understanding of IC design and manufacturing, the economics of the markets served, relationships/networking in China OEM, successful track-record of organizational interactions and experience engineering unique solutions.
- Ability to leverage previously established relationships and new relationships with key
decision makers in China OEM.
- Proven ability to work with customers throughout the evaluation and benchmarking
process.
- The ability to align personal and Sales team’s compensation with the company’s goals and objectives.
- Proven experience taking an emerging technology value proposition through customer
validation as well as volume production.
- Understand customer needs and drive Sales that map capabilities with customers while ensuring profitability.
- Demonstrated ability to personally initiate meetings with targeted companies and drive
Sales.
- Strong creative and strategic approach to growing revenue and design wins
complemented by flawless execution.
- Possess BSEE degree, MBA highly preferred
- Fluent Chinese and English required.
GMT+8, 2025-10-6 22:20 , Processed in 0.020701 second(s), 6 queries , Gzip On, Redis On.
