查看: 2165|回复: 0
[招聘] NO.172-Software Senior Staff Engineer(Shenzhen)
发表于 2013-3-7 15:50:13 | 显示全部楼层 |阅读模式
Job Description and Responsibilities:
The job mainly includes the development of embedded ARM/DSP firmware on base station platforms for WCDMA and LTE modems. The SW engineer will have participated in embedded development of wireless modem implementations. The job involves interfacing with physical layer design and validation of physical layer, including WCDMA user plan and control plan protocol.
Typical responsibilities include the following:
? WCDMA/LTE L1 testing SW development.
? Embedded SW development on ARM and DSP such as BSP.
? Participate in testing and debugging in the LAB.
Job Requirements :
BS Degree in EE. With 3+ years of industrial experience or MS is preferred with 2+ years of industrial experience.
? Experience in L1//L2 development of UMTS/LTE standard and WCDMA knowledge is highly desirable and LTE knowledge is a plus.
? Ability to debug and test real-time ARM/DSP code. ? Programming experience in embedded system, ARM code and DSP.
? Knowledge of telecommunications and communications standards such as 3GPP, IEEE,
? Strong knowledge in digital communication, signal processing, error correcting codes.
? Ability to work in a team environment and strong communications skills are essential.
? Strong initiative and proactive working style required. Good written and verbal communication skills in English.
KT Human Resources Consulting Company (Shanghai) was established in 2001 in response to a need for a recruitment consultancy to be an active, contributing member of the semiconductor community, as opposed to simply a supplier to it.We provide professional search and talent acquisition in the Integrated Circuit、Electronic、Telecommunications industry of international corporations in Greater China. Our client list contains numerous international companies, many of them are long-term customers.
If you interested in the job, pls sent your cv to: hr@kthr.com, thanks!
“KT人才”微信也可查询职位啦!打开手机微信,搜号码“KTHR_COM”或查找微信公众帐号“KT人才”或扫描以上二维码即可添加,欢迎大家关注!(关注成功后输入”KT“即可查询职位!)
GMT+8, 2025-12-24 19:16 , Processed in 0.019016 second(s), 5 queries , Gzip On, Redis On.
