查看: 1877|回复: 0
[招聘] Cadence SH 招聘 Lead Product Validation Engineer
发表于 2013-2-4 15:37:40 | 显示全部楼层 |阅读模式
If you haveinterest,PLS send your CV to zhangyl@cadence.com
欢迎应届博士或者有工作经验者投递
JobTitle:    Lead PV Engineer
Position Description:
This job is an importantaddition to our R&D team to develop Cadence Encounter DigitalImplementation System (EDI)
Responsible for developing,applying, and improving quality standard for Cadence EDI products
Required to acquire expertiseand ownership over existing product components as well as develop brand newproduct features.
Help identifying newtechnology challenges in advanced process nodes and proactively provide theproduct improvement suggestion to R&D
Build up EDI expertise anddeliver support to field team and customers whenever needed
PositionRequirements:
CS/EE BS degree with 5+ yearsor MS degree with 3+ years of EDA or IC design related experience.
Good experience with Placeand Route design flow using EDA tools. Good knowledge of LEF/DEF.
Be familiar with IC back-enddesign flow, from netlist to gdsout.
Strong analysis/bedbugcapability for technical issues, be detailed oriented with a focus on quality.
Good team player with strongwritten and verbal communication skills.
Be able to work underpressure, be able to work on multiple projects at the same time.
Good English read, write andcommunication Skill.
JobTitle:    Lead PV Engineer-SoftwareSystem
Cadence ICD Product ValidationRegression system is the core system infrastructure of the whole ProductValidation organization, which can greatly improve the whole organization'sefficiency and boost the team productivity.
This position is responsiblefor the regression system and application development and maintanance.
The candidate need use allkinds of knowledge and skills to design and improve the system based on thebusiness requirement for the organization operation and the existing system andrelated software/hardware environment.
Detailed Responsibility:
1. Analyze System and Businessrequirement, based on which design the system flow chart
2. Do the needfulsystem/scripts maintenance/improvement
3. Communicate with related ITand PV team and drive to improve organization operation efficiency
4. Innovate on the nextgeneration system to boost organization's efficiency
Position Requirements:
Bachelor with 4 years relatedexperience or Master with 2 years related experience
1. Result driven and detailsfocused working attitude
2. Excellent analytical skillsand complex system problem solving skills
3. Strong technical experiencein Unix/Linux usage
4. Strong Perl/Tcl/Cshellscripting
5. Good knowledge andexperience in CGI programming
6. Good knowledge in SQLdatabase
7. Knowledge in Web programing(javascript, php, Python, XML) is a strong plus
8. Knowledge in NFS/DistributedProcessing/Server Farm/Network is a strong plus
9. Good written English andoral English is a strong plus
Job Title:
Lead PV DesignEngineer
1.Work through synthesis flow and APR flow by solvingdifferent kind of issues and bottleneck, througn many designs.
2.Identify any timing/power/area issues within SYN/APR flow,and among flow interfaces.
Develop system for automation.
1.MS with 3 years work experience in design house or EDAcompany.
2.Good at STA, good at APR flow, including place, route, cts,optimization, and SI analysis
Know about RTL synthesis.
3.Good at unix scripts, cshell. Perl is a plus.
4.Strong ability in analysis and solving issues,  strong ability in facing difficulty andchallenges.  Proactive in work.
5.Good English skill, communication skill and good team work.
GMT+8, 2025-12-22 23:12 , Processed in 0.025590 second(s), 6 queries , Gzip On, Redis On.
