楼主: xiatan
CST2012
发表于 2013-5-27 12:48:21 | 显示全部楼层
回复 6# sabiks
报错“the license server manager has not been started yet. the wrong port @host or license file is being used,or the port or hostname in the license file has been changed”这是SP8端口用27777的时候报的错误;“see the system adminstrator about starting the license server system ,or make sure you're reffering to the right host”,这是用端口27000时报的错误,求楼主指导!!!!先行谢过!
发表于 2013-7-8 21:31:55 | 显示全部楼层
楼主。我想请问你,我安装的是CST2012最原始的版本,  然后下载了SP7,想安装这个补丁,但是提示“update is not valid”。
是不是我需要安装补丁SP1才行?   求解答 谢谢
发表于 2013-7-9 13:11:05 | 显示全部楼层
   SP is accumulated in each version, so you don't need the earlier SPs in order to install the SP7.
发表于 2013-9-21 23:07:04 | 显示全部楼层
回复 4# xiatan
   楼主如何解决的
发表于 2014-1-9 11:16:10 | 显示全部楼层
什么时候出2013啊?
发表于 2015-1-13 21:53:35 | 显示全部楼层
没搞懂
发表于 2015-12-22 17:17:28 | 显示全部楼层
LZ   求CST2012下载地址,THANX!
GMT+8, 2025-12-27 12:51 , Processed in 0.016560 second(s), 4 queries , Gzip On, Redis On.
