查看: 19706|回复: 30
[求助] 求教各位icc中create mw lib的问题[已解决]
发表于 2013-1-24 13:51:59 | 显示全部楼层 |阅读模式
小弟在create mw lib后,import design时第一个module就显示undefined,请问大神能帮助指导下么?
所用库http://bbs.eetop.cn/viewthread.php?tid=301894&highlight=milkyway%2Blef(感谢前辈分享)
1.create mw lib
tcl:create_mw_lib -technology /data/stu13/Simon/smic180/digital/sc/apollo/tf/smic18_6lm.tf -mw_reference_lib {/data/stu13/Simon/smic180/digital/sc/apollo/smic18} -open /data/stu13/Simon/0124/i_clkctrl
report:Start to load technology file /data/stu13/Simon/smic180/digital/sc/apollo/tf/smic18_6lm.tf.
Warning: ContactCode 'CONT1' is missing the attribute 'unitMinResistance'. (line 480) (TFCHK-014)
Warning: Layer 'METAL6' has a pitch 0.95 that does not match the doubled pitch 1.32 or tripled pitch 1.98. (TFCHK-050)
Technology file /data/stu13/Simon/smic180/digital/sc/apollo/tf/smic18_6lm.tf has been loaded successfully.
2.import design
tcl:set search_path /data/stu13/Simon/smic180/digital/sc/synopsys
set link_library "typical.db fast.db slow.db"
set target_library {typical.db fast.db slow.db}
import_designs -format verilog -top i_clkctrl -cel i_clkctrl -rp_constraint /data/stu13/Simon/0124/sdc.tcl {/data/stu13/Simon/0124/i_clkctrl.v}
report:*****    Start Pass 1 *****
Begin loading DB for bus info.
End of loading DB for bus info.Elapsed =    0:00:03, CPU =    0:00:03
*****  Pass 1 Complete *****
Elapsed =    0:00:00, CPU =    0:00:00
*****  Verilog HDL translation! *****
*****    Start Pass 2 *****
Error: Module 'DFFX1' is not defined.  (MWNL-297)
hdlCleanupDBLibrary:
Error: Verilog parser cannot parse the /data/stu13/Simon/0124/i_clkctrl.v source file. (MWNL-047)
论坛上之前发过类似问题的帖子,但是好像没有完成的跟进解决http://bbs.eetop.cn/viewthread.php?tid=340798&highlight=mw%2Blib
求助于各位大神,不胜感激
发表于 2013-1-24 14:26:55 | 显示全部楼层
回复 1# Simon0827
    确认以下内容:
1、lib/db中有无此cell的定义;
2、MilkyWay Data FRAM中有无此cell生成。
3、Netlist中关于此cell的定义是否正确
 楼主| 发表于 2013-1-24 14:57:41 | 显示全部楼层
回复 2# xjg@hmes
    感谢帮助,我刚才做了检查
    1.对应db的lib中存在DFFX1 cell
    2.Milky Way的Data FRAM是下载到的库内smic180/digital/sc/apollo/smic18/FRAM自有的,抱歉我刚接触这些还不懂自己生成
          其中FRAM内的对应cell文件名叫做DFFX1_1,在CEL中对应cell文件名叫做DFFX1_2
    3.nl中的定义是正确的
        另外请问,我在create nw lib后,得到的自己的project为/data/stu13/Simon/0124/i_clkctrl
        做完create后,内部只有3个文件lib,lib_1,lib_bck.请问这个是正常的吗?
        在import design报错后,内部多了一个CEL的folder,里面有两个文件DFFX1:1,DFFX1:1.lock
        请问是否是creat mw lib出了问题?Reference Lib阅读时有几个warning
Warning: ContactCode 'CONT1' is missing the attribute 'unitNomResistance'. (line 480) (TFCHK-014)
Warning: ContactCode 'CONT1' is missing the attribute 'unitMaxResistance'. (line 480) (TFCHK-014)
Warning: Cut layer 'VIA12' has a non-cross primary default ContactCode 'via1'. (line 498) (TFCHK-092)
Warning: Cut layer 'VIA23' has a non-cross primary default ContactCode 'via2'. (line 516) (TFCHK-092)
Warning: Cut layer 'VIA34' has a non-cross primary default ContactCode 'via3'. (line 534) (TFCHK-092)
Warning: Cut layer 'VIA45' has a non-cross primary default ContactCode 'via4'. (line 552) (TFCHK-092)
Warning: Layer 'METAL1' has a pitch 0.56 that does not match the recommended wire-to-via pitch 0.535 or 0.485. (TFCHK-049)
Warning: Layer 'METAL2' has a pitch 0.66 that does not match the recommended wire-to-via pitch 0.61 or 0.56. (TFCHK-049)
Warning: Layer 'METAL4' has a pitch 0.66 that does not match the recommended wire-to-via pitch 0.61 or 0.56. (TFCHK-049)
Warning: Layer 'METAL3' has a pitch 0.56 that does not match the doubled pitch 1.12 or tripled pitch 1.68. (TFCHK-050)
Warning: Layer 'METAL4' has a pitch 0.66 that does not match the doubled pitch 1.32 or tripled pitch 1.98. (TFCHK-050)
Warning: Layer 'METAL5' has a pitch 0.61 that does not match the doubled pitch 1.12 or tripled pitch 1.68. (TFCHK-050)
        但是最后也有生成成功的提示
        求教这些warning的出现是否影响了create lib的结果?
        谢谢高人
发表于 2013-1-24 16:25:17 | 显示全部楼层
回复 3# Simon0827
    这种wangning没问题,不影响后面的读入
再继续检查以下内容:
1、环境设置是否正确,如link_libary、target library等
2、实行check_library、check_design命令查看结果中的warning/error
这种错误我只能凭经验告诉你怎么去找解决方法,具体分析还得靠你自己细腻的check。
发表于 2013-1-25 07:30:10 | 显示全部楼层
这啥版本icc啊,还import_design ,
用read_verilog
ref lib要对,否则总是link error
 楼主| 发表于 2013-1-25 13:26:48 | 显示全部楼层
回复 4# xjg@hmes
    感谢您的帮助!抱歉我昨天临时有事出去,现在按您说的继续检查
 楼主| 发表于 2013-1-25 13:30:53 | 显示全部楼层
回复 5# icfbicfb
    2009.06 ICC SP1,请问您说的link error是我的lib没有去做link的工作还是说在link时会有error报出?
 楼主| 发表于 2013-1-27 17:22:55 | 显示全部楼层
回复 4# xjg@hmes
    能向您再请教下吗?我set了一个.synopsys_icc.tcl,也做了一些别的检查。
在指令import_designs -format verilog -top i_clkctrl -cel i_clkctrl -rp_constraint /data/stu13/Simon/0127/sdc.tcl {/data/stu13/Simon/0127/i_clkctrl.v}之后,得到了下面的log
Loading db file '/data/stu13/Simon/smic180/digital/sc/synopsys/typical.db'
Loading db file '/cad/synopsys/icc_2009.06-SP1/libraries/syn/gtech.db'
Loading db file '/cad/synopsys/icc_2009.06-SP1/libraries/syn/standard.sldb'
Warning: /data/stu13/Simon/0127/for_synPR/smic18: bus naming style _<%d> is not consistent with main lib. (MWNL-111)
请问这个Warning是否会影响lib的链接?(属于比较重的warning?)所以才会造成之前问题的undefined module?
Spec里面说
If you do not specifythe bus naming style, %d is used.
请问是否有别的常用bus naming style设置
 楼主| 发表于 2013-1-29 11:05:30 | 显示全部楼层
请恕小弟愚陋,花了不少功夫才解决这个简单问题。
最后将FRAM内的文件手动更名库即可以正常链接。
例如DFFX_1改为DFFX:1,不会贴图见谅
发表于 2013-5-29 11:18:27 | 显示全部楼层
回复 9# Simon0827
   这是因为版本问题吗  你有没有试一下2010的版本可能不用改名就可以了
GMT+8, 2025-9-17 11:37 , Processed in 0.021327 second(s), 5 queries , Gzip On, Redis On.
