查看: 2407|回复: 1
[招聘] 【社招】EMC上海招ME Supplier/Hardware Engineer
发表于 2013-1-19 09:46:19 | 显示全部楼层 |阅读模式
EMC上海招ME Supplier Engineer, Senior Hardware Engineer这两个职位都要求5年以上对口工作经验感兴趣的朋友请发送简历至 henry.chang@emc.com来信不能一一回复,请见谅;对于合适的简历我会推荐给招聘的Manager邮件标题格式:YourName_JobTitle------------------------------------------------------Job Title: ME Supplier EngineerExperience and Education  •        BEng or other technical degree required.•        Understands general manufacturing operations and practices, fabrication experience, including quality management and process controls. Six Sigma tools, continuous improvement and lean techniques.•        Experience with DFM, tolerance analysis and process capability.•        Strong English skills (verbal and written).•        Strong mechanical CAD experience – Solid Works preferable.•        Knowledge of Mechanical Design (i.e. tolerances, materials, platings, etc.)•        Failure Analysis skills; methods and procedures is a plus.•        Experience with Supplier Management activities, including process qualifications, NPI development and qualifications, PPAPs and surveillance audits.•        Ability to work in a matrix management environment. Needs to work cross functionally with regional and remote teams.•        Experience with a large multinational would be a plus.•        5 years experience as a mechanical engineer supporting sheet metal and plastic tooling designs.Roles and ResponsibilitiesThis position is a Fabrication Engineer to support the management of technical elements across Sheet Metal & Plastic commodities within China supply base. The Engineer will primarily work with  Development Engineering on New Product efforts to evaluate hard tooling designs and associated costings, as well as ensuring the supplier's facilities within China comply to 's product and process specifications, performing product and process audits, monitoring the supplier's factory data, facilitating qualification activities and driving quality improvement initiatives within the supplier's factory. RESPONSIBILITIES: •        Evaluate hard tooling designs and associated costings.•        Assist in developing new technology direction and strategy for technical support.•        Perform advanced technology qualifications by selecting candidate suppliers and determining the qualification plan.•        Provide recommendations to Design team on NPI and existing projects.•        Develop technical relationships with suppliers; initiate forums to understand what future advanced technologies can be provided by suppliers.•        Supplier quality management: day to day monitoring to targets & goals, continuous improvement of quality metrics, execution of purges/containment actions, verification of corrective actions and progress reporting.•        Liaison between the supplier,  plants (Cork, Apex and Franklin), and Design in the event of a major quality issue.•        Driving the implementation and effective use of Six Sigma and Lean Manufacturing methodology at the suppliers.•        Qualification of processes & technologies: Running the qualifications and reporting progress.•        Audits & Assessments: Conducting audits per the standard requirements and methodologies, driving improvements to close gaps and providing timely reports on audit results.•        Processes & Standards: Execute responsibilities per the world-wide processes and standards and provide inputs for continuous improvement. Ensure conformance of supplier processes to  requirements.•        Product Data Management: Ensure the supplier ships product at the correct revision and that Engineering Change Orders are correctly implemented.It is critical that the selected candidate can work independently and is self motivated. Independent planning of daily work activity aligned with organizational goals is a must. In addition, the candidate should be able to communicate in Mandarin (in writing and verbally) and have an excellent level of English, particularly with respect to Engineering and Technical terms. The candidate should have good report writing skills and be willing to attend conference calls outside normal working hours. Excellent interpersonal and communication skills and the ability to interact with people at all levels is important.In addition, the selected candidate must be willing/able to work extensively in China and be willing to travel to other countries within the Asia-Pacific region at short notice. Infrequent travel to the US and Europe may be required. Knowledge of China based supply chains supporting computer products manufacturers would be beneficial.  is an Equal Employment Opportunity employer that values the strength diversity brings to the workplace-----------------------------------------------------------Job Title: Senior Hardware EngineerKey Skill Requirements:              Strong thermal skills, Flotherm, rich problem solving skills, 5+ working experienceSPECIFIC SKILLS The candidate must have strong thermal skills, Detailed knowledge system and component level thermal analysis, good acoustic technology, proficiency with laboratory equipment, air chambers, data recorders, and other system-level measurement systems. A strong background in storage sub-systems components such as disk drives and experience with high availability designs. Flotherm Skill Project management skills. Cross-Functional skill. Ability to set up the system for thermal test and measurement General knowledge in hardware, software and/or operating systems environments. General knowledge and application of engineering concepts. Communication skills. Understanding of business environment. EXPERIENCE 5 years minimum, with broad experience in high availability, high reliability mechanical enclosures and system design. Understanding of the various topologies and thermal design solutions common to the technology, and a proven ability to apply them correctly during a development cycle. Requires a strong understanding and familiarity of computer system hardware and architecture as it pertains to thermal and mechanical design. Firm working knowledge in areas such as mechanical design, power design, and component characteristics, as they relate to thermal design. Must have a good understanding of the Contract Manufacturing (CM) and OEM/JDM industry as a whole, in order to make accurate and optimum make-vs.-buy decisions in commoditized product areas. EDUCATION BSME with a concentration in Thermofluids minimum, MSME degree desirable but not required
发表于 2013-1-22 19:21:35 | 显示全部楼层
有没有成都的职位?
GMT+8, 2025-12-22 23:13 , Processed in 0.028384 second(s), 8 queries , Gzip On, Redis On.
