查看: 19902|回复: 38
[转贴] IC名人及著作
发表于 2013-1-14 12:49:46 | 显示全部楼层 |阅读模式
A.Razavi
1.Principles of Data Conversion System Design
2.High Speed CMOS Circuits for Optical Receivers
3.RF Microelectronics
4.Monolithic Phase Locked Loops and Clock Recovery Circuits
5.Fundamentals of Microelectronics
6.Design of ICs for Optical Communications
7.Design of Analog CMOS Integrated Circuits
8.Phase-Locking in High Performance Systems,书是论文集,Razavi主编
B.Thomas H.Lee
1.The Design of Low Noise Oscillators(Hajimiri&Lee,论坛上只有HajimiriPHD Dissertation,这本书也是我花了大功夫才找到的)
2.Multi-GHz Frequency Synthesis and Division(Rategh&Lee,非常难找,论坛上没有)
3.Feedback Linearization of RF Power Amplifiers
4.Low Power CMOS Radio Receivers
5.The design of CMOS RFIC 2nd
6.Planar Microwave Engineering: A Practical Guide to Theory, Measurement, and Circuits(2004,Cambridge)
7.Physics and Engineering of High Power Switching Devices  (1975,Cambridge)
C.Abidi
1.The Designer's Guide to High-Purity Oscillators
2.Integrated Circuits for Wireless Communications by Asad A. Abidi, Paul R. Gray, and Robert G. Meyer(1998,Wiley)
3. Effects of random & periodic excitations on relaxation oscillators(AbidiPHD Dissertation)(1981)
4. On the dynamics of Josephson junction circuits(1978)
D.Gray
1.Analysis and Design of Analog Integrated Circuits4th
2.Analog MOS Integrated Circuits, II by Paul R. Gray, Bruce A. Wooley, and Robert W. Brodersen(1989,Wiley)
3.Integrated circuits for telecommunications by Paul R Gray (1979)
E.Sansen
1.Analog Design Essentials
2.Design of Analog Integrated Circuits and Systems
3.Distortion Analysis of Analog Integrated Circuits
4.Design of Wireless Autonomous Datalogger IC’s by Wim Claes, Robert Pures, and Willy M.C. Sansen
5.Matching Properties of Deep Sub-Micron MOS Transistors by Jeroen A. Croon, Herman E. Maes, and Willy M.C. Sansen
6.Systematic Modeling and Analysis of Telecom Frontends and Their Building Blocks by Piet Vanassche, Georges Gielen, and Willy M.C. Sansen
7.Analog Layout Generation Performance and Manufacturability by Koen Lampaert,Georges Gielen, and Willy M.C. Sansen (1999,Springer)
8.Symbolic Analysis for Automated Design of Analog Integrated Circuits by Georges Gielen and Willy M.C. Sansen (1991,Springer)
9.Low-Noise Wide-Band Amplifiers in Bipolar and CMOS Technologies by Zhong Yuan Chong and Willy M.C. Sansen (1990,Springer)
10.Analog Interfaces for Digital Signal Processing Systems by Frank op 't Eynde and Willy M.C. Sansen (1993,Springer)
11.A Computer-Aided Design and Synthesis Environment for Analog Integrated Circuits by Van der Plas, Geert, Gielen, Georges, Sansen, Willy M.C. (2002,Springer)
F.Steyaert
1.Wireless CMOS Frequency Sythesizer Design(Craninckx&Steyaert,非常难找的经典,论坛上没有).
2.Systematic Design of Analog IP Blocks(论坛上没有)
3.Design and Analysis of High Efficiency Line Drivers for xDSL(论坛上没有)
4.CMOS FRACTIONAL-N SYNTHESIZERS Design for High Spectral Purity and Monolithic Integration
5.CMOS Cellular Receiver Front Ends-From Specification to Realization
6.Integrated CMOS Circuits for Optical Communications
7.Broadband Opto-Electrical Receivers in Standard CMOS
8.Low-Power Low-Voltage Sigma-Delta Modulators in Nanometer CMOS
9.LNA-ESD Co-Design for Fully Integrated CMOS Wireless Receivers
10.Design of multi-bit delta-sigma A/D converters
11.High Data Rate Transmitter Circuits: RF CMOS Design and Techniques for Design Automation
12.RF Power Amplifiers for Mobile Communications
13.Design of High Voltage xDSL Line Drivers in Standard CMOS, by Bert Serneels and Michiel Steyaert(2008,Springer)
14.Analog VLSI Integration of Massive Parallel Processing Systems,  by Peter Kinget and Michiel Steyaert(1997,Springer)
15.Static and Dynamic Performance Limitations for High Speed D/A Converters, by Anne van den Bosch, Michiel Steyaert, and Willy M.C. Sansen(2004,Springer)
16.Design of Low-Voltage Low-Power CMOS DeltaSigma A/D Converters, by Vincenzo Peluso, Michiel Steyaert, and Willy M.C. Sansen(1999,Springer)
17.CMOS Wireless Transceiver Design, by Jan Crols and Michiel Steyaert(1997,Springer)
18.High-Performance CMOS Continuous-Time Filters ,by José Silva-Martínez, Michiel Steyaert, and Willy M.C. Sansen(1993,Springer)
Analog Circuit Design(系列丛书有很多都是SansenSteyaert编辑,就全归入Styaert
1. Analog Circuit Design Volt Electronics; Mixed-Mode Systems; Low-Noise and RF PA for Telecommunication(论坛上没有)下载附带的吧;
2. Analog Circuit Design Fractional-N Synthesizers,Design for Robustness, Line and Bus Drivers
下载附带的吧;
3.High-Speed A-D Converters, Automotive Electronics and Ultra-Low Power Wireless
4. Analog Circuit Design :MOST RF Circuits, Sigma-Delta Converters and Translinear Circuits
5. Analog Circuit Design :RF Circuits Wide band, Front-Ends, DAC's, Design Methodology and Verification for RF and Mixed-Signal Systems, Low Power and Low Voltage
6. Analog Circuit Design :Structured Mixed-Mode Design, Multi-Bit Sigma Converters,Short Range RF Circuits
7. Analog Circuit Design :Operational Amplifiers, Analog to Digital Convertors, Analog Computer Aided Design by Johan H. Huijsing, Rudy J. van de Plassche, and Willy M.C. Sansen (1992,Springer)
8. Analog Circuit Design :RF Analog-to-Digital Converters; Sensor and Actuator Interfaces; Low-Noise Oscillators, PLLs and Synthesizers by Rudy J. van de Plassche, Johan H. Huijsing, and Willy M.C. Sansen(1997,Springer)
9. Analog Circuit Design :Low-Noise, Low-Power, Low-Voltage; Mixed-Mode Design with CAD Tools; Voltage, Current and Time References by Johan H. Huijsing, Rudy J. van de Plassche, and Willy M.C. Sansen (1995,Springer)
10. Analog Circuit Design :Mixed A/D Circuit Design, Sensor Interface Circuits and Communication Circuits by Willy M.C. Sansen, Johan H. Huijsing, and Rudy J. van de Plassche (1994,Springer)
11. Analog Circuit Design :Scalable Analog Circuit Design, High-Speed D/A Converters, RF Power Amplifiers by Johan H. Huijsing, Michiel Steyaert, and Arthur H.M. van Roermund (2002,Springer)
12. Analog Circuit Design :Sensor and actuator interface electronics, integrated high-voltage electronics and power management, low-power and high-resolution ADC's by Huijsing, J.H.; Steyaert, Michiel; van Roermund, Arthur H. M. (2004,Springer)
13. Analog Circuit Design : (X)DSL and other Communication Systems; RF MOST models; Integrated Filtersand Oscillators by Sansen, W.M.C., Huijsing, J.H., van de Plassche, R.J.  (1999,Springer)
14. Analog Circuit Design : Low-Power Low-Voltage, Integrated Filters and Smart Power by Plassche, R.J.v.d., Sansen, W.M.C., Huijsing, J.H. (1995,S[romger)
15. Analog Circuit Design :High-Speed Analog-to-Digital Converters, Mixed Signal Design; PLLs and Synthesizers by Plassche, R.J.v.d., Huijsing, J.H., Sansen, W.M.C.(2000,Springer)
The Design and Implementation of Low-Power CMOS Radio Receivers(共9卷)
发表于 2013-1-17 16:18:49 | 显示全部楼层
牛人多,资料多,学海无涯
发表于 2015-6-24 10:19:33 | 显示全部楼层
IC名人及著作
发表于 2015-7-9 10:41:39 | 显示全部楼层
thank you !
发表于 2015-10-4 21:44:16 | 显示全部楼层
thanks~
发表于 2015-10-5 08:30:43 | 显示全部楼层
good!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
发表于 2015-10-5 17:16:56 | 显示全部楼层
thank you !
发表于 2016-4-25 15:19:06 | 显示全部楼层
先mark一下,学海无涯,多学多仿~
发表于 2016-10-8 22:19:38 | 显示全部楼层
值得学习
发表于 2016-10-9 09:23:52 | 显示全部楼层
xuexi thanks
GMT+8, 2025-12-21 08:45 , Processed in 0.024991 second(s), 6 queries , Gzip On, Redis On.
