楼主: pocket112
[讨论] 地电压做level shift用什么结构的电路好呢
 楼主| 发表于 2013-1-24 12:31:16 | 显示全部楼层
回复 19# semico_ljj
    应用就是如20楼所说的。现在问题是负载(数字时钟边沿)如果有电流抽取的话,我该如何稳定DVDD,DGND。
发表于 2013-1-24 13:22:31 | 显示全部楼层
“ 你数字工作电压1.2,模拟2.5,数字所有输出对模拟的控制端都接levelshift不就从0-1.2的电压域转变到0-2.5的电压域?
”,这个楼主没有回答!
总觉得你入了迷途。没见过这么做的!
为什么VSS要升压
 楼主| 发表于 2013-1-25 22:43:36 | 显示全部楼层
回复 22# semico_ljj
    其实数字工作电压并不是1.2V,而是数字电路用了1.2V的管子。但是我在应用中需要将共模拉回一个大于1.2V的电位上,假设1.5V吧。所以如果还是以0~1.2V作为栅压来控制开关的话,高电平1.2V并不足以使得开关开启。所以这时候就想到将数字电压往上抬。
    不知道这样的应用您遇到过吗
发表于 2013-1-26 07:08:23 | 显示全部楼层
回复 23# pocket112
请点这里查询相关文献和标准的IC:寻找“高侧驱动器”电路和适应自己的喜好您的需求。高侧驱动器在电源应用中经常遇到的开关负载接近高轨远离GND。既然你已经有2.5V电源,你会不会提供高压电荷泵电路,使你的电路,将是一个比一个高侧驱动器电路简单,没有一个高电压轨有一个电荷泵。祝你好运!
如果您尝试使用的运放比,你将有体重问题。它可以克服,但比单运放,做到这一点,你需要使用不同的技术。高侧驱动器是最好的选择。
Please search literature and standard Ic's: look for "High Side Driver" circuits and adapt one of your liking to your needs. High side drivers are commonly encountered in power supply applications to switch loads close to high rail away from gnd. Since you already have 2.5V supply you will not need to provide HV with a charge pump circuit so that your circuit would be a simpler one than a high side driver circuit without a high voltage rail having a charge pump.  Good luck!
If you try to use an opamp than you will have BW problem. It could be overcome but you need to employ different techniques than a single opamp to do it. High side drivers are your best bet.
GMT+8, 2025-12-25 07:34 , Processed in 0.013531 second(s), 3 queries , Gzip On, Redis On.
