查看: 5482|回复: 15
Front end circuitry for a Delta Modulator Analog-to-Digital Converter
发表于 2006-12-26 17:37:01 | 显示全部楼层 |阅读模式
abbr_ology] Front end circuitry for a Delta Modulator Analog-to-Digital Converter.pdf
1.77 MB, 下载次数: 71 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2006-12-26 18:16:31 | 显示全部楼层
Abstract
The purpose of this thesis work is to build analog circuitry for an Analog to Digital converter. This circuit was integrated on silicon and tested to measure the achieved results.  The Thesis work began with literature studies that are presented in this report. The results from the literature studies concluded that there were some problematic areas that needed further analysis. This analysis was done in the areas of semiconductors and amplifier theory. With this analysis as a backbone, a circuit was drawn as a Schematic. This Schematic was simulated in different conditions in order to understand how durable the circuit was for manufacturing. Layout was made, that is design of mask layers for the semiconductor manufacturing process, and the results were sent for manufacturing in Austria. The manufactured circuits were measured and compared to the specification and the simulated results. The outcome of the manufacturing was surprisingly successful. Life could actually be concluded from the circuit, and some simple measurements could be performed to validate the outcome of the manufacturing to the simulated results.  The Thesis work was conducted in the St. Jude Medical AB facilities in Stockholm, Sweden.
发表于 2006-12-26 22:43:35 | 显示全部楼层
一般还凑合
发表于 2007-2-14 14:32:08 | 显示全部楼层
发表于 2007-3-3 01:01:59 | 显示全部楼层
very good ,tk
发表于 2007-3-4 20:09:28 | 显示全部楼层
谢谢主~~~~
发表于 2007-4-26 03:08:48 | 显示全部楼层
thanks.
发表于 2007-4-26 09:00:12 | 显示全部楼层
is good for me
发表于 2007-9-19 16:00:22 | 显示全部楼层
谢谢!!!!!!!!!!!
发表于 2008-10-14 13:04:15 | 显示全部楼层
下下来看一下
GMT+8, 2025-12-24 17:12 , Processed in 0.022754 second(s), 6 queries , Gzip On, Redis On.
