查看: 33611|回复: 117
CST 2012 SP7更新说明及下载
发表于 2012-12-21 18:52:38 | 显示全部楼层 |阅读模式
CST STUDIO SUITE 2012 Service Pack 7 11月30日已发布。
Service Pack 2012.07主要更新:
EDA Import
ODB++ import: Fixed thickness computation of conductor layers from copper weight.
Zuken CR-5000 import: Fixed reading of *.ruf file.
Distributed Computing (DC)
Reduced CPU load when sending TCP data.
Fixed problem when viewing 1D results while a distributed parameter sweep is running.
CST MICROWAVE STUDIO - Transient Solver (TLM Mesh)
Added active S-Parameters when ports are excited simultaneously.
Fixed an issue in waveguide port identification.
CST MICROWAVE STUDIO - Frequency Domain (FD) Solvers
Repaired scaling problem of fields when using the Resonant: Fast S-Parameter solver (Tetrahedral Mesh)
together with curved elements and edge/face ports.
Fixed S-Parameter phase in the mesh adaptation folder.
CST CABLE STUDIO
Improvements and bug fixes for the statistical bundling dialog box.
Fixed inconsistent mesh number.
Fixed that electromagnetic coupling effects between different cable routes are not considered depending on
parameter minimum sample length.
2DTL: Repaired parser error when switching to schematic.
AC Radiation: Fixed wrong direction of rsd segments.
CST PCB STUDIO
IRDrop: Better visualization of current distribution at vias.
IRDrop: Repaired unit error in case of 'mil' when calculating the current distribution.
IRDrop: Group pins of different nets are considered in simulation correctly now.
PEEC: Changed UID of nodes in mesh output to avoid memory overflow during visualization.
2DTL: Fixed transmission problem if both new via modeling and consider pad shapes were specified.
3D meshing: problem with terminal of antipad fixed.
Improved zooming in for components graph. Fixed deleting of layers.
Fixed that 2DTL did not find terminals although some terminals are defined. Improved stability while smoothing.
CST DESIGN STUDIO Wrong handling of package RLC in IBIS Input models fixed.
Wrong calculation of min. pulse width of imported signals fixed. Fix bug in parsing SPICE voltage or current sources without excitation keyword.
IBIS: Wrong results for 'Fast'/'Slow' in case of different v_fixture/v_fixture_max/v_fixture_min fixed. Fixed phase of impedance for under cut-off waveguide CST MWS blocks.
Fixed issue when reading out port impedances computed by Transient Solver (TLM Mesh).Result Templates / VBA / Macros / External Data Access
Fixed memory issue while executing a SAR related result template.
CST_STUDIO_SUITE_2012__SP7.part01.rar (15 MB , 下载次数: 1084 )
CST_STUDIO_SUITE_2012__SP7.part02.rar (15 MB , 下载次数: 838 )
CST_STUDIO_SUITE_2012__SP7.part03.rar (15 MB , 下载次数: 791 )
CST_STUDIO_SUITE_2012__SP7.part04.rar (15 MB , 下载次数: 873 )
CST_STUDIO_SUITE_2012__SP7.part05.rar (15 MB , 下载次数: 731 )
CST_STUDIO_SUITE_2012__SP7.part06.rar (15 MB , 下载次数: 867 )
CST_STUDIO_SUITE_2012__SP7.part07.rar (15 MB , 下载次数: 643 )
CST_STUDIO_SUITE_2012__SP7.part08.rar (15 MB , 下载次数: 840 )
CST_STUDIO_SUITE_2012__SP7.part09.rar (15 MB , 下载次数: 1015 )
CST_STUDIO_SUITE_2012__SP7.part10.rar (15 MB , 下载次数: 920 )
CST_STUDIO_SUITE_2012__SP7.part11.rar (15 MB , 下载次数: 577 )
CST_STUDIO_SUITE_2012__SP7.part12.rar (15 MB , 下载次数: 754 )
CST_STUDIO_SUITE_2012__SP7.part13.rar (15 MB , 下载次数: 979 )
CST_STUDIO_SUITE_2012__SP7.part14.rar (15 MB , 下载次数: 847 )
CST_STUDIO_SUITE_2012__SP7.part15.rar (15 MB , 下载次数: 570 )
CST_STUDIO_SUITE_2012__SP7.part16.rar (14.4 MB , 下载次数: 794 )
 楼主| 发表于 2012-12-21 19:58:46 | 显示全部楼层
没人需要吗??
发表于 2012-12-21 20:23:24 | 显示全部楼层
楼主辛苦,赞一个.
发表于 2012-12-21 21:47:44 | 显示全部楼层
is the former crack useful as well?
发表于 2012-12-21 22:16:00 | 显示全部楼层
顶一个 好东西
发表于 2012-12-22 09:29:36 | 显示全部楼层
楼主辛苦
发表于 2012-12-26 20:42:50 | 显示全部楼层
Ding ding
发表于 2012-12-26 21:00:57 | 显示全部楼层
buzhinengbunengyong
发表于 2012-12-26 21:03:20 | 显示全部楼层
asdasdaads
发表于 2012-12-26 21:06:13 | 显示全部楼层
adsfdfddfad
GMT+8, 2025-12-12 23:08 , Processed in 0.110662 second(s), 6 queries , Gzip On, Redis On.
